Critical Points & their Nature of a Multivariable Function
In summary: Thanks a lot for the welcome and the help. Greatly appreciated.Just a question:For both the equations:fx = 27*y*x^2 + 3*y^3 -16*y = 0and fy = 9*x^3 + 9*x*y^2 - 16*x = 0Am I supposed to solve both equations simultaneously to find the stationary points?Yes, you should solve both equations simultaneously to find the stationary points.
wowmaths
f(x,y) = xy(9x^2 + 3y^2 -16)
Find the critical points of the function and their nature (local maximum, local minimum or saddle)
I have partially differentiated the equation into:
fx = 27yx^2* + 3y^3 -16y
fy = 9x^3 + 9xy^2 - 16x
How do I go on from there though?
Hey there, welcome to the forum.
So, recall that a critical point of a function f(x) occurs when the derivative f'(x) = 0.
Now translating that to the multivariate case is not very different. Set fx = 0 and fy = 0 and then solve for your critical points.
You solve the equations
27*y*x^2 + 3*y^3 - 16*y = 0
9*x^3 + 9*x*y^2 - 16*x = 0.
The first one says either y = 0 or 27*x^2 + 3*y^2 - 16 = 0, and this last one is the equation of an ellipse in (x,y) space. The second one says either x = 0 or 9*x^2 + 9*y^2 -16 = 0. What kind of geometric figure does that describe in (x,y)-space?
RGV
RGV
Just a question:
and
I tried using a calculator to solve both equations simultaneously and I've gotten 9 stationary points.
Am I on the right track?
Ill give you a hint, use elimination to solve both. Solve for y in the first equation to get y=0 and y = ± something else.
Just a question:
and
Answer to both questions is yes. The geometric representation I suggested before shows why there are 9 solution points.
RGV
Related to Critical Points & their Nature of a Multivariable Function
1. What is a critical point in a multivariable function?
A critical point is a point in a multivariable function where the partial derivatives are equal to zero or do not exist. This means that the function is not changing in any particular direction at that point.
2. How do you find critical points in a multivariable function?
To find critical points, you must first take the partial derivatives of the function with respect to each variable. Then, set each partial derivative equal to zero and solve the resulting system of equations to find the values of the variables at the critical point.
3. What is the significance of critical points in a multivariable function?
Critical points help us identify the location of local extrema (maximum or minimum values) in a multivariable function. They also help us determine the nature of these extrema, whether they are local maxima, local minima, or saddle points.
4. How do you determine the nature of a critical point in a multivariable function?
To determine the nature of a critical point, we use the second derivative test. This involves taking the second partial derivatives of the function and evaluating them at the critical point. If the resulting value is positive, the critical point is a local minimum. If the value is negative, the critical point is a local maximum. If the value is zero, the second derivative test is inconclusive and further analysis is needed.
5. Can a multivariable function have multiple critical points?
Yes, a multivariable function can have multiple critical points. In fact, it is common for functions to have multiple critical points. These points may represent local extrema or saddle points.
