Critical speed of a vertical shaft
In summary: Rayleigh's method is based on the assumption that the inertia of the shaft is a function of radius, and that the deflection of the shaft is a function of radius squared. This is a simplification, of course, and in practice the deflection will be a function of the radius cubed and even higher order terms. Nevertheless, the principle is sound, and the Rayleigh equation is the most common way to find the shaft's critical speed.
okinaw
Hi everyone,
I have to calculate the critical speed of a vertical shaft. I have been looking on internet how to calculate, and I have found that this critical speed is based on the type of the supports of the shaft. The type of supports determine the deflection of the shaft (δ) and for this reason a fixed-fixed shaft has a higher critical speed than a supported-supported shaft.
If it is correct, how can I determine the critical speed of a vertical shaft?
Knowing that the deflection of the vertical shaft is lower than the horizontal one, I suppose that the critical speed is going to be higher. Am I correct?
Whether vertical or horizontal, the deflection will be the same. It only depends on the type of supports.
The deflection is actually the static deflection under gravitational loading only when the shaft is horizontal. It is used with ##g## to find the ratio ##k/m (= g/y)## which is the relationship between stiffness and mass of the shaft such that we can evaluate its response to vibrations.
Likes Baluncore
Thanks to both of you,
I read the article of wikipedia but I have some doubts. The article says that the critical speed is calculated approximately as:
ω≈√g/ymax
being:
g=gravity
ymax= static deflections (under gravitational loading only)
Depending on the orientation of the shaft, the deflection is going to be different.(In vertical cases, the deflection is going to be much lower), and this implies higher critical speed. So I can not undertand why the relationship is valid no matter what the orientation of the shaft is.
I did some tests, and the critical speed in vertical shafts is higher but i do not know how to quantify how much higher.
Thanks in advance and happy new year.
The critical speed for any shaft is ##\omega = \sqrt{\frac{k}{m}}##. It relates the stiffness of the shaft (elastic restoring force) vs the inertia of the shaft (centripetal force). It comes from ##kr = m\omega^2r## where the mass of the shaft is assumed to be concentrated at one point where there is a shaft deflection ##r##.
Values for ##k## in a bending shaft can be difficult to measure. But when you take an horizontal beam, you can easily evaluate how it will deform under its own load, usually it's a function ##y(x)## where a ##y_{max}## can be identified. If we assume the mass of the beam is concentrated at one point, say ##x_c##, the only forces involved for a none rotating shaft are ##mg = ky(x_c)## where necessarily ##y(x_c) = y_{max}##. This is the same equation than for our rotating shaft, but with a different acceleration. So we can rearrange the equation to ##\frac{k}{m} = \frac{g}{y_{max}}##.
Therefore, you don't need to know ##k##, as ##y_{max}## is a lot easier to determined.
There is a vast literature available regarding the critical speed of shafts. Look under "rotor dynamics" in a search engine.
There are many different approaches to finding shaft critical speeds. The simple equation proposed by Jack above does not help understanding very much because it relates a single discrete stiffness (k), a single discrete mass (m), to the simple system natural frequency. Actual beams are invariably continuous distributions of both mass and flexibility.
The most common approach to realistic shaft geometries (numerous diameter changes, disks, etc) is via Rayleigh's method. This is detailed in the text by Mischke (Elements of Mechanical Analysis, Addison-Wesley, 1963, p. 279).
Related to Critical speed of a vertical shaft
1. What is the critical speed of a vertical shaft?
The critical speed of a vertical shaft is the rotational speed at which the shaft experiences resonance. This means that the natural frequency of the shaft's vibration matches the frequency of the rotating force, causing excessive vibrations and potential damage.
2. How is the critical speed of a vertical shaft calculated?
The critical speed of a vertical shaft can be calculated using the formula: N = (C * g * L) / 2π, where N is the critical speed in rotations per minute (RPM), C is the stiffness of the shaft, g is the acceleration due to gravity, and L is the length of the shaft.
3. What factors can affect the critical speed of a vertical shaft?
Several factors can affect the critical speed of a vertical shaft, including the length and stiffness of the shaft, the material it is made of, and any additional loads or forces applied to the shaft.
4. How does the critical speed of a vertical shaft impact its performance?
If a vertical shaft operates at or near its critical speed, it can experience excessive vibrations, which can lead to premature wear and failure of the shaft and other connected components. This can result in decreased efficiency and increased maintenance costs.
5. How can the critical speed of a vertical shaft be managed?
The critical speed of a vertical shaft can be managed by carefully designing and selecting the material and dimensions of the shaft, considering any potential additional loads or forces, and implementing proper maintenance and monitoring practices to detect and address any vibrations or resonance issues.
  • Mechanical Engineering
9K
