Critically Damped Harmonic System
In summary: So x_0=-x_0 or x_0=-x_d/2 since x_0=-x_0+dx_d/2. This gives you x_0=-x_d/2, so now you can solve for x.
sTrEsSeD
John the door-stopper man sells and installs door-stoppers. He prides himself as being the world's best stopper and guarantees your money back if you can install a better stopper than him.
John's secret to door-stopping is that he remembers from his lectures that the best way to stop doors is by fine tuning the stopper such that it is critically damped.
Trick John (and ask for your money back) by showing him that if you open a critically damed door and release it without also pushing it, it will never ever close again.
The equation of motion is a second order differential equation in the form: mx"+cx'+kx=0; then let x=e^(zt);
I realize that for a critically damped system, the determinent for the characteristic equation z^2 + (c/m)z + (k/m) = 0 equals to (c/m)^2 - 4(k/m) = 0;
Then solving for x to find the equation in the form of x(t) = (A + Bt)e^(-t(k/m)^0.5)
However, the problem is that this solution converges to the equilibrium position under critically damped conditions.
How can I show that the door will never close again?? (It seems impossible!)
Your help is much appreciated! :smile:
Careful, you are looking at the discriminant, which is different from the determinate. Also, your solution should be
[tex]x(t) = (A+Bt)e^{-\frac{c}{2m}t}[/tex]
But you might as well save same writing and just call c/2m beta or gamma. Those are just some notational issues, and stupid mistakes. They don't really pertain all that much to the solution, but should be corrected nonetheless. (Edit: Oh wait, I see what you (or your instructor) did. You can leave your solution how you have it.)
You have a couple initial conditions, one is that the door is open some amount x_0 at time = 0. The other is that there is no initial velocity so x'(0) = 0. Then you want to know when the door stops moving, when it is closed.
See if this gets you anywhere.
You have to set the equilibrium position to the open position. In that case the door will stop there.
Thanks you guys! I see, so the trick is to have the initial condition as being opened already.
FAQ: Critically Damped Harmonic System
What is a critically damped harmonic system?
A critically damped harmonic system is a type of oscillator that is characterized by a rapid decay of its amplitude without any oscillation. It is considered the ideal damping for a system, as it allows for the quickest return to equilibrium without any overshoot or oscillation.
How is a critically damped harmonic system different from an overdamped or underdamped system?
An overdamped system is characterized by a slower return to equilibrium, while an underdamped system results in oscillations around the equilibrium point. A critically damped system falls between these two extremes, allowing for a quick return to equilibrium without any oscillation.
What factors affect the damping of a critically damped harmonic system?
The damping of a critically damped harmonic system is affected by the mass, spring constant, and damping coefficient of the system. These factors determine the rate at which the system returns to equilibrium and the presence of any oscillations.
How does a critically damped harmonic system behave over time?
A critically damped harmonic system will return to equilibrium in the shortest amount of time possible without any oscillation. This behavior is ideal for systems that require quick and precise responses, such as in shock absorbers or electronic circuits.
What are some real-world applications of critically damped harmonic systems?
Critically damped harmonic systems have a wide range of applications in various fields, including engineering, physics, and biology. Some examples include shock absorbers in cars, seismometers for measuring earthquakes, and pacemakers for regulating heart rate. They are also commonly used in electronic circuits and control systems.
