Criticising the scientific method
In summary, the author is arguing that the scientific method is flawed because it's based on assumptions which could be disproven. He's providing an analogy which is problematic because it doesn't accurately reflect the scientific method. He's providing an oversimplification of the scientific process which is inaccurate.
hadeka
32
Criticising the scientific method !
Hi all
Quoting a part of prof. Michael Shermer's book: Why people believe weird things?, about some problems of scientific thinking, made me a bit confused.
"Let us suppose that an ichthyologist is exploring the life of the ocean. He casts a net into the water and brings up a fishy assortment. Surveying his catch, he proceeds in the usual manner of a scientist to systematise what it reveals. He arrives at two generalisations: No sea-creature is less than two inches long. (2) All sea-creatures have gills. These are both true of his catch, and he assumes tentatively that they will remain true however often he repeats it.
In applying this analogy, the catch stands for the body of knowledge which constitutes physical science, and the net for the sensory and intellectual equipment which we use in obtaining it. The casting of the net corresponds to observation; for knowledge which has not been or could not be obtained by observation is not admitted into physical science.
An onlooker may object that the first generalisation is wrong. "There are plenty of sea-creatures under two inches long, only your net is not adapted to catch them." The icthyologist dismisses this objection contemptuously. "Anything uncatchable by my net is ipso facto outside the scope of icthyological knowledge. In short, "what my net can't catch isn't fish." Or — to translate the analogy — "If you are not simply guessing, you are claiming a knowledge of the physical universe discovered in some other way than by the methods of physical science, and admittedly unverifiable by such methods. You are a metaphysician. Bah!
My question is:
Is this really explaining the scientific method ?! If yes, so how we're relying on such method ?!
What is the appropriate way to criticize these claims and ensure that the scientific method is the best knowledge method that does not have such holes ?!Thank you !Hadeka
hadeka said:
My question is: Is this really explaining the scientific method ?!
The post you quoted (I don't deign to lend it support by quoting it yet again) employs two logical fallacies, minimum. He first set up a parody of the scientific method in his ichthyologist example, and then proceeded to argue against this parody. He then extended this false description of the scientific method to the physical sciences. This is a red herring argument.
Scientists know that their measuring devices and the measurements from them are incomplete and somewhat erroneous. That does not mean the scientific method itself is flawed. It merely means scientists should strive to improve their techniques (which they do, by means of research into new and improved measuring devices), double check their results (which they do, by means of peer review and independent replication of experiments), and be careful of overgeneralization (which they try to do).
The quoted argument does have one thing right: Science treats explanations which cannot be possibly observed as inadmissible to the body of science. Science is predicated on the existence of reality. For example, an argument that we are all in a computer simulation is untestable and unscientific.
It might be an oversimplification, but I think it's generally accurate.
Of course it sounds silly to believe that there are no sea-creatures smaller than 2 inches long. But from the perspective of the analogy, it's a reasonable conclusion to draw.
The key is this statement -
By definition, the body of knowledge is EVERYTHING we know about a topic. If everything we know about sea-life is in the net in front of us (meaning we've never seen a tadpole or a minnow in pond, etc.), then we don't know very much. And if all of the fish we see are longer than 2 inches, then as far as we know (from observation) that's true for all sea-life, until we observe otherwise. It's important to note that the 2inch fish assumption is tentative -
which means it could change at a later time. The Scientific Method is an iterative process. (Like washing your hair - lather, rinse, repeat)
After thinking about it a little bit, we can postulate that there might be smaller fish that fall through the holes in the net. We then create a new test (build a tighter net), and gather more data using the new test (catch more fish with the new net). If we catch something shorter than 2 inches, then we've just disproved (or modified) our original hypothesis. Rinse, repeat. Welcome to the scientific method.
The problem is when things are outside of what is currently testable. If a person says to us "I KNOW that there are smaller fish" without any evidence, and with no way to test and observe (maybe we don't have the technology to build a better net), then it can't be added to the body of knowledge. After all, with no observable evidence, what proof does he have? How can he know? Maybe he just made it up. We can't apply the scientific method to something that isn't testable.
Once something becomes testable (maybe we invent a new technology, or maybe someone simply thinks up a new test that works), then the scientific method can be applied, and the data could become part of the body of knowledge.
Honestly, I'm not sure what claims you want to criticize or what holes you see. The analogy that Shermer used could have been a little clearer, but I think it works. And if done correctly, the scientific method works, albeit slowly (lots of iterations).
The first is correct. The latter is not. Because the author could not argue with the scientific method as it is, he (or she) intentionally oversimplified and overgeneralized to the extent as to make a parody - a straw man - of the scientific method. While this overly simplified and overly generalized parody is subject to attack, what he is attacking is not the scientific method. He is attacking his own parody of the method. In short, the author constructed a straw man argument.
By my understanding of the scientific method that story does not depict it at all. The "scientist" in that story looks at a bunch of information and makes some guesses about the implications of patterns he sees. That might qualify as scholarship but not as science.
A scientific approach would begin with the hypotheses about the size and gills of sea-dwelling creatures. Then there would be design and execution of experiments to rigorously test those hypotheses through direct, counterfactual, and other methods. The experiments would need to be thoroughly documented so that they could be accurately reproduced by other scientists. The initial findings and experimental method would be published and reviewed by other scientists.
If the method and hypotheses were deemed sound by the scientific community, at that point the hypothesis wouldn't be regarded as fact but simply some interesting initial findings. In subsequent years other scientists would reproduce the experiments, perhaps with some adjustments to the experimental method. If the subsequent experiments produced the same results there would be more and more confidence in the hypotheses.
But the hypotheses would never reach the status of "truth" like you might have in religion or philosophy. You never really have more than "confirmed findings" in science: an idea, the results of earlier tests of that idea, and instructions on how to reproduce those tests to examine the subject yourself.
(So I think it's pretty obvious that the two hypotheses from the story - that no sea-dwelling creature is less than two inches long and that all sea-dwelling creatures have gills - would never successfully pass through the rigor of the scientific method as I've described it. (Unless, as Bill_B suggests, the net is really only a metaphor for everything that's directly perceivable. But that would be dumb, as if Shermer were trying to explain science with the language of dream interpretation or something.))
I think we disagree on what the argument is about. I don't believe Shermer is trying to argue against the scientific method (or any strawman facsimile thereof) at all. The way I read it, he is talking about why scientists don't automatically believe any willy-nilly idea offered to them, but instead require testable evidence. I think my wife has a copy of the book - when she gets home I'll see if she knows where it is. Perhaps there's more context that would be helpful.I also think that the reason the analogy exists is to attempt to make the explanation more accessible to an average audience (to which his books are usually targeted). I'll concede that the analogy may not be the best possible one, but I think you're reading too much into it (or perhaps taking it too literally).
I agree that it doesn't qualify as the whole of science, but I think it is very much a part of the scientific method. You have to be able to analyze the data and draw conclusions, as a basis for your next hypothesis. If your hypothesis is disproved, you drew an incorrect (or an incomplete) conclusion.
How do you begin with a hypothesis? Do you think up totally a new hypothesis without basing it on some preexisting body of knowledge? Don't you usually start with a question about a peculiarity or pattern in existing data?
-- snipped for brevity --
Except as noted, I don't disagree with your description of the scientific method - it's a more realistic picture of the way science works in the real world. However, I don't think Shermer was trying to build an exhaustive model of the scientific method, but a layman's model that could be used to explain why scientists often dismiss non-testable phenomena as hokum.
I agree that if taken literally, it wouldn't stand up to rigor. But it's an analogy, it's not supposed to be taken literally.
And yes, the way I read it, the net is a metaphor for our observational tools and processes - microscopes, accelerometers, our eyes, etc., while everything in the net (the catch) is a metaphor for everything we know about science.
As far as I can tell, all Shermer is trying to say is that because of the scientific method, if something can't be tested, we can't say it is "known" (in the usual scientific meaning of the term).
And reading it again, I think he may also be trying to point out the problems that may arise if a scientist entirely dismisses a hypothesis that cannot be tested at the present time (but might be in the future). Unfortunately, I'd need more context to be sure. I'll see if my wife can find her copy of the book. Or perhaps the original poster can post more snippets.
Well ... It is written here:
http://www.skywise711.com/Skeptic/WPBWT/index.html
Twenty-five Fallacies That Lead Us to Believe Weird Things.It's number three: Equipment Constructs Results, which is under the section of: Problems of scientific thinking.Thanks to all of you !
Looking for more participation to shed more light on the topic..
Many thanks
Hadeka.
@Bill_B: Yeah, I think all of what you're saying is true there. Analysis is of course part of the scientific method - but it's pretty much part of every epistemological approach. In the excerpt above there's no distinction made between observation and analysis and it appears to me that science is presented as no different from deep thought. Within the excerpt it doesn't mention testing hypotheses or conclusions at all.
...okay, I've just noticed that I was probably confused by an unmatched quotation mark in that last paragraph. I hadn't realized that the scientist was the one calling the onlooker a metaphysician; initially I thought it was the other way around. So what you're saying makes more sense.
Still though, I think the answer to hadeka's question "Is this really explaining the scientific method ?!" is that no, that excerpt is not explaining the scientific method. It's more explaining what the epistemological domain of science is (with a confusing and inexact analogy, in my opinion).
In reading the original source it appears that Bill_B's inference of the purpose of the story is dead-on: the title of that section is "Equipment Constructs Results" and the story is preceded with the assertion that scientific understanding of the nature of intelligence has been screwed up by the inexact and limited nature of IQ tests.
So hadeka, I would maintain that the excerpt is not trying to explain the scientific method. It's making a different point entirely, that the conclusions of a scientific investigation can be flawed by insufficient experimental design that does not account for the limitations of the experimental equipment. (Which is basically what Bill_B said, I think.)
Shermer Fallacy #1: Imply that there's a singular scientific method.
There's no such thing. Lots of scientific discoveries did not go through the prototypical scientific method.
I don't think that's what I said, but I wish it was :biggrin: since I think you hit the nail on the head
hadeka said:
"Anything uncatchable by my net is ipso facto outside the scope of icthyological knowledge. In short, "what my net can't catch isn't fish." Or — to translate the analogy — "If you are not simply guessing, you are claiming a knowledge of the physical universe discovered in some other way than by the methods of physical science, and admittedly unverifiable by such methods. You are a metaphysician. Bah!"
If the existence of sea creatures below 2" is supposed to represent things beyond the researcher's equipment, but within the realm of science, then the experiment is simply inadequate to determine the existence of small sea creatures and the claim 'such knowledge is metaphysical' is wrong. If it's supposed to represent things literally beyond the ability of science, then the claim 'no creatures under 2" exist' is not falsifiable and cannot be claimed under the scientific method.
Either way the analogy fails as a criticism of the scientific method. If it's a criticism of researchers drawing untoward conclusions, though, it could work.
I agree with this ... We cannot prove that there are no sea creatures smaller than 2 inches except by using experiments that prove that such creatures does not exist [ A net that can catch sea creatures that are less than 2 inches long will either prove or disprove that such creatures exist ]
I mean, if i want to prove that there are no sea creatures less than 2 inches long, i should use a net that can catch such creatures to either prove or disprove their existence.
Thank you :D
You cannot prove the general case that something does not exist.
Yes, but the crucial part of the analogy is when someone objects to the Ichthyologist that there are sea creatures under 2 inches long and he asserts that any thing he cannot catch in his net is not a sea creature. That is a Parody. As D H said, any good scientist- or anyone using the scientific method- would respond "That may well be true but it hasn't been proved. Do you have any suggestions for improving the net?"
Which, in the analogy it wasn't. That was where Schermer "cheated". He said, at first, that the concusions were "tentative" but later had the Ichtyologist say, '"Anything uncatchable by my net is ipso facto outside the scope of icthyological knowledge. In short, "what my net can't catch isn't fish."'
I would say, though, that NO ONE who did not have other means of obtaining evidence than the ichtyologist in question are to be given more authority than that ichtyologist.
For example, a blind desert dweller has even less intelligent to say about life in the ocean than the ichtyologist..
That's not scientific either, though - that's giving the ichthyologist a priori authority simply because he's the one who obtained the evidence. Him collecting the evidence doesn't make his conclusions / guesses about the nature of sea life any more authoritative.
Wow, this is getting a little too philosophical for me. If you want a physical explanation for why scientific predictions are often flawed, it is called entropy. If you don't have a complete set of data points, but only say, a and b, you can't make that good of a prediction about what will happen "between" a and b, because the statistics of the system are unknown. At least, that's the way I look at it.
What are you talking about?
Relative to the one having NO evidence whatsoever, sure the ichtyologist has the authority.
No. Anyone who has access to the evidence he has collected could draw conclusions and might be more successful in deducing the significance of the evidence or extrapolating patterns from the evidence than the ichthyologist. The ichthyologist having been the person who collected the evidence does not by itself make him more authoritative or more correct.
Or, to put it a different way, the ichthyologist is only an authority on his own evidence and that evidence itself - on the fact that "On this day, at this time, I did X and Y happened." He isn't automatically an authority on X or Y or their relationship to each other or whether the same thing might or might not happen at a different day and time.
No. The ichthyologist has an expertise in his particular field of study, and is therefore able to draw more accurate conclusions on the data than a non-expert in his field of study. The only other people who are capable of drawing conclusions on this data set would be other ichthyologists.
Other ichthyologists are included in the group of people other than the guy collecting the evidence, of course, even if they haven't collected their own evidence on the same subject of study. But - the only other people capable of drawing conclusions based on the list of stuff caught in a net are ichthyologists?
I think that basically sets up scientists as priests in the temple of Science. If you believe that scientists have special access to the truth that is beyond the questioning of mere mortals, that's up to you. But I think that one of the basic principles of science and empiricism is that ideas stand on their own and that the virtue of a theory is that it testable and has been vetted through scientific rigor, not the reputation of the ideas author or his or her resume.
This example - the ichthyologist drawing a conclusion that any fisherman (or sea-shore-dweller) can see is patently false, while humorous, is not entirely unknown in the history of science. And conversely, someone who isn't an expert or specialist being the one to draw the scientifically important conclusions isn't uncommon either. I wonder how many people at the beginning of the last century would have said "A mere patent clerk barely out of school, who couldn't even get a job teaching much less as a professional researcher, isn't capable of drawing conclusions about the most profound questions of theoretical physics!" (Referring to the flagship case of this sort of thing, Einstein.)
I have never stated that the validity comes from the reputation of the author. What I am saying is that in this context it is not appealing to authority by deferring to the expert in this field of study. It is very likely that the expert in the field of study is going to have a better grasp on drawing conclusions from the data set than a layman would.
I'm not sure what point you're trying to make with this? I don't think anyone is suggesting that an expertise is an innate ability. It is something that is earned. In Einstein's case, he earned it by having his theories withstand the scientific process.
That's a change in your tune - before you said "The only other people who are capable of drawing conclusions on this data set would be other ichthyologists." (emphasis mine)
You noted "very likely" in that last bit but likelihoods aside, it's the idea that matters. That is why I asserted "Anyone who has access to the evidence he has collected could draw conclusions and might be more successful in deducing the significance of the evidence or extrapolating patterns from the evidence than the ichthyologist." As you mention below with Einstein, it is the virtue of the theories themselves that is important within science, not the reputation or resume of the theorist.
Conversely, take an example from religion: per the Roman Catholic doctrine of Papal Infallibility, the pope's pronouncements upon certain types of Catholic spiritual matters are infallible - not because of any quality of the ideas themselves but because he's the pope. Before empiricism the attitude in academics was often similar: Livy's interpretation of the meaning of events in Roman history was the correct one because Livy was the most reputed Roman historian.
You've got no idea what this would have to do with the current discussion, huh? :wink:
The point I am making is that Einstein did not possesses the title "theoretical physicist" yet he was far more capable of and successful in his analysis of the contemporary evidence than many of his peers who officially held the title, men would would have won far more regard as specialist experts than a patent clerk. It is not the case, as you stated, that only the specialist like the ichthyologist is capable of drawing conclusions from his data. And that's the case regardless of whether the specialist's expertise is innate or acquired.
Depth of experience certainly can aid in scientific analysis as it can with any skill. And as a matter of practicality scientists are going to primarily spend their time contemplating and working on new ideas from people who have "earned their chops" as opposed to pursuing any new idea at all which they're exposed to. But an important feature of empiricism and the scientific approach to knowledge, distinct from the forms of epistemology that preceded them, is that the validity (or "truth", to get old school) of an assertion is vested solely in the assertion itself and has absolutely nothing to do with the prestige or other characteristics of the author of that assertion.
I did not change my tune at all. My last quote reflects my previous quote of "the only other people who are capable of drawing conclusions on this data set would be other ichthyologists." To use an analogy, would a dentist be more qualified in classifying and dating rocks than a geologist? This is where I'm going with my point, that in this context it wouldn't be committing the fallacy of appealing to authority.
I think that's stretching it. If I don't know what aspects to analyze or more generally what to even look for, how am I going to even have a remote chance of being more successful at deducing significant information than an expert would? This is why the title of "expert" is earned.
Again, you're proving my point that the title of "expert" is earned.
There is nothing that would prevent a dentist from successfully classifying and dating rocks. Or even correcting a mistake a geologist made. And yes, it would commit the fallacy of appealing to authority to assert that only someone designated "expert geologist" could classify and date rocks.
Like I said, it's pretty obvious that a fisherman or probably anyone who lives on a seashore would know that there are sea creatures less than two inches long and could analyze an ichthyologist's stuff-I-caught-in-a-net data. The data's in a written report? Make it a literate fisherman. The report's clouded up with technical terminology from Latin and Greek root words? Make it a fisherman who's literate in Latin and Greek. Or a fisherman with an ichthyology glossary at his disposal. Saying you need a professorship in ichthyology to determine whether or not there are sea creatures shorter than two inches long is what's a stretch.
You're now trying to imply that anyone who is not an expert automatically "doesn't know what aspects to analyze or more generally what to even look for". This is as fallacious as implying that being an expert (even an "earned" expert) automatically makes you correct.
If the evidence for a scientific finding is so cryptic that it's incomprehensible to anyone who isn't a specialist in the exact same field then it's probably not very good science. Or there's another Bogdanov Affair going on.
No, you're pretending to not notice the fact that Einstein was already capably drawing successful conclusions at a point when he'd earned no such thing and was still a patent clerk.
Only an expert is capable of successfully drawing conclusions from the evidence but you know in 2008 that Einstein was an expert in 1904 because his conclusions were later confirmed? Appealing to authority isn't the only fallacy you're indulging in.
Give it up, man. "The only other people who are capable of drawing conclusions on this data set would be other ichthyologists" was a silly statement to make, one that can only be fixed with circular reasoning like you're trying to get away with in the case of Einstein there - by saying something like "but anyone who successfully draws a conclusion from an ichthyologist's data is an ichthyologist herself."
That's a silly statement to make. It's not the dentist's line of work to be dating and classifying rocks. It is, however, the geologists line of work, therefore making him more qualified. Why is that so hard for you to grasp? Better yet, let's reverse the analogy, would a geologist be more qualified in fixing your teeth than a dentist?
We are not talking about fishermen. We are talking about layman.
So is the term "expert" meaningless to you? Science will always keep its doors open, however, there hasn't been one scientific illiterate that has made a major scientific discovery, and please don't try to refute me with Einstein. Einstein was obviously scientifically literate.
He's still an expert though.
It's entirely possible that some specific person with the title "geologist" could be more successful in fixing a particular dental problem than some other specific person with the title "dentist". You tried to present a good rule of thumb generalization as absolute fact because you were really gung-ho to sharply contradict me. Without "maybe" or "probably" involved it was a goof on your part.
No, we're talking about anyone who is not an ichthyologist. You very clearly said "only... ichthyologists". Unless you're going to retract that, a fisherman who is not an ichthyologist but is capable of drawing conclusions from an ichthyologist's experimental data easily falsifies your assertion.
Nope, it's not meaningless, it just doesn't have the definition that you're trying to pass off with, adding an epistemological meaning and using circular logic, so as to make it consistent with your earlier statements.
"Expert" does not mean "the only type of person who can draw conclusions from evidence" nor "someone whose conclusions are correct" nor even "someone whose conclusions are likely to be correct"; as an ordinary English word it doesn't have any epistemological significance.
Bzzzt, you're trying to change your story again. You have not mentioned scientific literacy up until this point, your previous statements had nothing to do with scientific literacy.
Not that you'd even remotely be able to prove this new absolute claim "there hasn't been one scientific illiterate that has made a major scientific discovery." I can name a couple right off the top of my head: ever heard of Augusto and Michaela Odone? Another good example of people who drew conclusions more successfully than the people who collected the evidence. And there are many more (unless, again, you adopt some sort of circular logic and say "If someone has made a major scientific discovery they're automatically scientifically literate.")
Except that by the circular definition you've boxed yourself into, an expert can successfully draw conclusions and anyone who can successfully draw conclusions is an expert. So it's tautological to say "experts (people who draw conclusions from data at some point in the future or past) are the only ones who can draw conclusions from data."
"We all know that conclusions drawn from evidence by person X cannot be correct" simply does not pass muster as a scientific approach. It violates the basic principles of empiricism.
  • #31
You're trying to refute me on "maybe there's some guy out there." It's a pretty weak refutation on your part.
You're using an absolute now by implying that "all fisherman are not ichthyologists." How do you know this?
If you know how to accurately apply concepts of a certain field in any situation to discover new findings then yes I'd consider you an expert in that particular field of study.
No, expert does not mean that, but I am trying to show you why deferring to an expert in this situation is not fallacious in reasoning at all. What I mean by my statement is that the expert is more qualified in extracting information out of the data set because he's trained to know what to analyze and look for. Therefore, his conclusions and other ichthyologists conclusions should be given more credence than a layman's contradictory conclusion.
The link you provided states they had no medical background, but that doesn't imply they were scientifically illiterate. Someone could have no astronomical background, but still be scientifically literate, so your case example doesn't really stand much ground here.
  • #32
I think our arguments rest solely on discerning between merely "unqualified of drawing conclusions" and "unqualified of drawing accurate conclusions." Anyone can draw all sorts of conclusions on a data set, which is why you have so many conspiracy theories roaming around out there. I'm talking more specifically about experts in a particular field being more qualified on drawing accurate conclusions from the data set than a non expert. I hope that clears the air somewhat.
  • #33
I saw your most recent comment there, response is down at the bottom, but not until I'd written my response to the preceding comment.
No, it's an extremely strong refutation against absolute statements like the ones you made. Only a single exception is necessary to disprove a rule stated absolutely.
Certainly, I don't know what definitions you're working with. By "ichthyologist" you might have meant "an all-knowing, omnipotent being." A (retconned) definition like that could make your statement correct, too. Or perhaps all biologists are ichthyologists at the same time... indeed, maybe every person who is scientifically literate is an ichthyologist! Oh, the wonders of rhetorical legerdemain!
Certainly, as I have pointed out, if you adopt a circular definition such that anyone who is capable of successfully drawing a conclusion from an ichthyologist's experimental evidence is an ichthyologist themselves, that works as well. It just makes your initial statement a tautology.
LightbulbSun said:
If you know how to apply concepts of a certain field in any situation to discover new findings then yes I'd consider you an expert in that particular field of study.
So, if you're subsequently going to say that the only way to draw a correct conclusion from evidence is to fulfill the criteria for that definition of expert you could get away with all this, but again you'd be making invalid generalizations to build up a self-supporting a circular definition. You can stack as many steps into the definition as you want, but if the way you're getting your original statement to be true is by adjusting the definitions involved in this manner, it's still circular reasoning.
Your statements do not literally say what you now claim they mean. You said that an expert's conclusions are "more accurate" and you didn't talk about non-ichthyologists being less qualified, you said that they aren't capable of drawing conclusions based on the data. (Qualified, by the way, means "attested to", again not "correct" or "likely to be correct." For example a "qualified sales lead" is a lead that goes to a genuine opportunity for a salesman rather than someone who hasn't got any money but is asking questions. A qualified person has credentials or references that attest to his or her abilities or achievements.)
And beside that... "given credence"? You mean if we aren't trying to be scientific about evaluating the various conclusions and we're just sort of guessing which one is valid? Yeah, sure, you could do that and I agree that it's a good basis for a guess about which one's correct. But as I've said from the very beginning it wouldn't be scientific.
If there were two conflicting, untested hypotheses presented that both explained the same set of data it would not be scientific to dismiss one of them based on anything about the person who proposed the hypothesis. It would be scientific to point out reasoning flaws within a hypothesis or inconsistency with data from another source - but you would do that with any hypothesis, to the same degree, no matter who came up with it.
If you did handle two different hypotheses differently based upon the qualities of the individuals they originated from, as you are proposing to do, that would be known in science as "bias".
I didn't say "there is no reasonable basis to ever defer to the best guesses or opinions of someone with experience." I said that doing so isn't science. It might be good science journalism or good science public relations or a good move in a career in science to show bias in favor of respected sources, but to include such bias in the scientific method or process itself is regarded as an error or mistake. A theory or an aspect of a theory which relied upon deference to an authority to select the correct explanation of experimental data would be regarded as resting upon an untested and hence unconfirmed assumption.
If, when I said "that's not scientific" to arildno up above, you thought by "scientific" I meant "generally related to science somehow" as in the company name "Boston Scientific" or as in the statement "the Bogdanov Affair was a scientific embarrassment", rather than "pertaining to the scientific method" as is the subject of this thread, I apologize for not being clearer. (However, I'd be pretty skeptical if you claimed that, of course.)
Oh! Good trick trying to ignore the part where I pointed out that your preceding statements had nothing to do with scientific literacy, and pretend that you aren't completely contravening your previous insistence that being a specialist and expert was necessary. Cherry picking too - this thread is becoming a gallery of deceptive rhetoric! The trick of derailing me by making an additional untenable absolute statement, about science literacy this time, almost worked.
Those would have been great points to make but I reiterate that this is not what you said. You asserted that an expert's conclusions are more accurate and that non-experts are incapable of analyzing data. (See also my remarks about the meaning of "qualified" up above.)
I think that the sort of attitude which was literally articulated in those first statements is as rampant as conspiracy theories and is potentially more harmful because it can lead to many more people believing an invalid theory than a wacko fringe conspiracy theorist might.
I also think it's bad because many scientists (and science journalists) don't distinguish very well between the science, the data and the hypotheses their work and the scientific community's work has produced confirmation of, and the ideas they come up with when they're thinking about stuff. I wouldn't be surprised if many of the wacko internet theories originate from someone with scientific authority carelessly or confusingly talking about an idea he's had.
There are also scientists who intentionally treat these sorts of ideas as if they do have the same sort of backing as the real science, the confirmed stuff. I've seen this done for the sake of deception, not just simplification, when someone knows that their interlocutors don't have the expertise to easily check the facts. Not entirely unlike the various rhetorical tricks you've tried to pull to avoid admitting that your original statements, as literally written, contravene empiricism and scientific principles. I think it's partly because some people are so casual about this that science is often distrusted.
Bias is necessary in everyday lives. You can't apply scientific rigor to any, or really even most, of the decisions you make. But bias has no place in the body of knowledge that the scientific community vouches for. So I think that in a thread in a scientific skepticism forum, a thread that's about the scientific method, this is a very significant distinction between what is science and what is not science. A distinction that should not be swept under the rug.
  • #34
Ok, so in our analogy say the geologist was an amateur dentist. Who would you trust more to fix your teeth? An amateur or a professional?
Now you're just creating a strawman argument. I never said every person that's scientifically literate is an ichthyologist. How you even came up with this is beyond me.
You could have someone start from square one and not learn about any of the previous concepts ascertained in that particular field, but that wouldn't be progressing our body of knowledge at all. Eventually the person starting from square one would have to learn about the already ascertained concepts.
Lets not turn this into a semantics argument. The non-expert is less qualified of drawing accurate conclusions from the data set than an expert. The non-expert can certainly censure those conclusions and ask questions, but as far as extracting information from the data set they would be less qualified than the expert. This is why in my last post I attempted to clear the air on this distinction.
Again, my contention has nothing to do with whether the science is accurate or not. My contention is you found it fallacious in reasoning to give more credence to the relevant experts conclusions on the data seat over a non-experts conclusions on the data set. Appealing to authority would be more like saying democracy is true because scientist X said so. Yes, it is fallacious and appealing to authority to say theory X is true because scientist X concluded so. However, it isn't appealing to authority to give more credence to expert X's conclusions on a data set over layman Y's conclusions on the data set.
As you've pointed out, we can't be experts in everything. At some point, all of us are going to have to appeal to some authority. This is all I'm really trying to say in the broader spectrum of things. Maybe I should have started out with that statement and delve from there with you.
  • #35
If this was in any way an analogy to your original statements - if you had asked a question like "Wouldn't you trust an ichthyologist more to do a do a marine survey for you?" I would entertain this.
But you didn't even ask any questions - you flat out, without hesitating, stated that an expert is more accurate and that only experts can draw conclusions from their data.
Beyond you, huh? Suggesting fishermen might be ichthyologists - that makes perfect sense. But scientifically literate people as ichthyologists, that's crazy! Nothing so insane would ever even occur to you!
I think you feigned innocence a couple of times before but this is a pretty egregious specimen of it.
You brought up scientific literacy for the same reason you proposed that fishermen might be ichthyologists, because you're trying to muddy the discussion with tangentially related claims you can pretend were what you really meant. You were hoping to scam your way into making arguments about your original statements that replaced "expert" with "scientifically literate".
Your entire schtick has been casting around desperately trying to conjure up some definition of the words you used such that what you said makes sense. But now you want to avoid talking about semantics?
Your last post attempted to claim that your words meant something different than they said. "Less qualified" means nothing at all like "not capable". Muddying the water, not clearing the air.
You're kinda, well, flat-out lying there:
"The ichthyologist has an expertise in his particular field of study, and is therefore able to draw more accurate conclusions on the data than a non-expert in his field of study."
You could certainly retract or correct that statement but pretending that you didn't say it isn't going to get me to accept a revisionist history of your contentions.
No one, not you or I, said anything about credence.
Nor did I say anything specifically about non-experts; I simply said that being the ichthyologist who collected the evidence does not make one more correct in one's conclusions.
I said that anyone with access to the evidence might be able to draw more correct conclusions and I stand by that. Your response, in which you said that being an expert makes one more correct, is untrue.
...or that theory X is more accurate because expert X concluded so. Therefore, your statement that this is the case was fallacious.
Like I said, it would have been great if you had said that - sure, it's true - but you didn't say anything about credence. You made some unempirical generalizations that aren't sound logic and which would not be accepted in science.
? I don't think I said anything like that. In fact, this pretty much simply appears to be another rhetorical gambit.
Seriously, you can get away with feigning innocence or twiddling with definitions or laying out circular logic once or twice, and probably convince people it was really an accident, especially with a mea culpa. But doing it again and again and again, and getting caught without responding or skipping a beat, is just an alert that you're willing to shamelessly pull those sorts of theatrics.
Unless, y'know, you're engaged in science.
So you're sticking by "experts' conclusions are more accurate" and "only experts can draw conclusions from their data", huh? You're going to pretend that those were simply innovative phrasings and that they're logically equivalent to the positions you've pulled back to?
I can't say what you should've done because it does not appear to me that your aim is to be truthful or accurate. But playing all of these rhetorical games to avoid admitting that the generalizations you made weren't valid definitely was not any way to convince me that you wanted to talk straight about anything.
  • General Discussion
  • Art, Music, History, and Linguistics
