Criticism of the doctrine of infinity
In summary, the criticism of the doctrine of infinity encompasses various philosophical, mathematical, and scientific arguments questioning the coherence and applicability of infinite concepts. Critics argue that infinity leads to paradoxes and contradictions, complicates mathematical foundations, and challenges empirical understandings of the universe. Some suggest that reliance on infinity can obscure practical reasoning and hinder advancements in mathematics and physics, prompting calls for a more finite-oriented approach. Overall, the debate highlights the tension between abstract theoretical constructs and their real-world implications.
Kekkuli
On the one hand, Cantor showed that not all real numbers can be enumerated, while on the other hand he showed that rational numbers can. Cantor demonstrated this with a grid. In the picture below, a natural number (yellow) is assigned to each rational number in order, but since the natural number is also a rational number, a fractional number that has not yet been listed has been constructed in each listing step. In the picture below, the largest number among the rational numbers is 11/1=11, while the largest natural number is already 45, it follows that all fractions can never be listed. Enumeration always produces only more numbers that have not yet been enumerated.
  • Skeptical
Likes PeroK
Mathematics news on Phys.org
Your criticism is incorrect. Consider the following grid. Only part of it is shown, as the rows extend infinitely far off to the right and there are an infinite number of rows.
##\begin{vmatrix}1/1 & 1/2 & 1/3 & 1/4 & 1/5 & \dots \\
2/1 & 2/2 & 2/3 & 2/4 & 2/5 & \dots\\
3/1 & 3/2 & 3/3 & 3/4 & 3/5 & \dots \\
\cdot & \cdot & \cdot & \cdot & \cdot & \dots\\
\end{vmatrix}##
Surely you would agree that this would list all the positive rational numbers. To pair them with the positive integers, weave through them just as you showed in your diagram. If you want to count 0 and the negative rationals, create a similar grid with the negative rationals. You could then start the count with 0 as the first in your list, and then hop back and forth between the two grids, thereby placing all of the rational numbers in one-to-one correspondence with the counting numbers.
Likes Dale
\end{vmatrix}##
The fact that the set of rational numbers would be numberable would mean that there would be a bijection from the set of rational numbers to the set of natural numbers. But you have, for example, the numbers 1/1, 2/2, 3/3,...,n/n=1 among the rational numbers, but the bijection should have a goal and the starting set should have a number only once. Your grid is wrong.
  • Wow
  • Skeptical
Likes phinds and PeroK
What do you mean that it "should have a goal". Normally, bijections have no motivation or emotions at all. ;-)
So if you just skip any later duplicates, doesn't that leave you with a bijection between the rational numbers and the natural numbers?
Likes Mark44
Well, if there was a bijection f from the set of natural numbers to the set of rational numbers, would you tell me what f(4895569879832983429893449999) is? You don't know it, and you can't find it out without an algorithm, and algorithms are always finite. There is no clause.
  • Skeptical
Likes PeroK
I can't tell you off the top of my head which rational number pairs with the integer you apparently typed at random, but because of the grid pattern, it wouldn't be hard to find a formula that gives it.
What does having an algorithm (or not) have to do with anything? And so what if algorithms are finite? This doesn't make any sense.
Nobody said that the bijection has to be a simple one that is easy to follow. But it is easy to see that there is a bijection. That is good enough. QED
Likes PeroK
And with that last comment, the thread is closed.
