fab13
- 318
- 6
- TL;DR Summary
- I try to approximate the cross-correlations between spectroscopic and photometric probes by taking same cosmological bias on the same redshift range. I would like to understand why one says that it is an approximation of 2D+3D cross-correlations (which is not yet performed from a theorical point of view).
I am interested, in the context of my work, in the cross correlations between a spectroscopic probe (which gives a 3D distribution of galaxies with redshifts, which is also called spectroscopic Galaxy clustering, GCsp) and a photometric probe (which gives an angular distribution, that is to say 2D thanks to the Weak Lensing "WL", which is the deformation of the image of galaxies along the line of sight, and at Galaxy photometric clustering (GCph) which is done by measuring magnitudes).
Currently, we are able to make cross correlations (understand "combine" to have better constraints on cosmological parameters) between weak lensing (WL) and photometric Galaxy clustering (GCph). When I say combine, as in the case where I have 2 sets of different measures (##\tau_1, \sigma_1##) and (##\tau_2, \sigma_2##), well, if I consider the Gaussian errors, it is shown quite easily (by Maximum Likelihood Estimation) that the estimator ##\sigma_{\hat {\tau}}## the most representative matches the relation:
$$\dfrac{1}{\sigma_{\hat{\tau}}^{2}}=\dfrac{1}{\sigma_1^2}+\dfrac{1}{\sigma_2^2}$$
Currently, we do not know how to make the correlation between the 2 probes (2D = GCph + WL) and the GCsp (3D).
A colleague suggests that I approximate this 2D + 3D cross-correlation by taking equal "b" cosmological biases in the 2 existing codes (one for the GCsp = 3D and the other for the 2D photo = WL + GCph).
I remind you that the cosmological bias "##b##" links the density contrast of galaxies to the density contrast of dark matter: $$\delta_{g} = b\, \delta_{DM}$$
By taking these equal biases for the same redshift interval covered by the 2 spectro and photo probes, I put strong constraints according to my colleague and I approximate according to him the 2D + 3D cross correlations which have not yet been established in such a way. precise from a theoretical point of view.
I don't see why he says that. To return to my comparison on the 2 series of measurements, let's say that the first one is made with a spectro sensor, gives an average ##\tau_1## and a ##\sigma_1## error, and that the other gives an average ##\tau_2## with a ##\sigma_2## error:
If the 2 measurements ##\tau_1## and ##\tau_2## have equal values (or at least, we force them to be equal as with my story of "cosmological bias", then how can we justify that we will obtain an approximation of what would be, if it existed? , a cross correlation of the 2 sensors (spectro and photo), that is to say a combined synthesis (2D + 3D)?
Ideally, if the sensors were "perfect", we would obtain the same average and standard deviation for the 2 sensors, which would correspond to the true value of the physical quantity measured, so there would be no gain in using the 2 sensors, only one would suffice.
But here, this is not the case, we must combine the spectro and the photo by sampling over the same redshift interval and we say that we approximate the cross correlation between the 2 sensors: I do not understand everything .
ps: by cross correlation, I mean the example I took with the variance estimator on 2 series of measurements assumed with a Gaussian error: the cross correlation is supposed to improve
constraints on the estimated quantity, i.e. having a smaller standard deviation.
If someone could explain this process and its interpretation to me a little better ... I hope I didn't take too long, if you need more details, don't hesitate! Any help is welcome.
