Cross section - scattering of light by light
Your Name]In summary, the problem involves two lasers with different wavelengths and power directed towards each other at an angle. The cross section for scattering is estimated by using the equation σ = (NRED + NGREEN) / (NRED + NGREEN)*π*0.0005^2, where NRED and NGREEN are calculated using the intensity of the beams (not the power) and taking into account the 10% decrease in intensity for each beam after the collision. Minor corrections need to be made to the equation used for σ, as well as the calculation of NRED and NGREEN.
wavingerwin
98
Red and green laser (wavelength of 650 nm and 532 nm respectively) are directed towards each other at 20 degrees.
Each laser has 5 mW power, with diameter of 1mm.
Assuming the intensity of the beams are decreased by 10% each after the 'collision',
estimate the upper limit on the cross section, σ, for the scattering.
σ = 0.1*(NRED + NGREEN) / (NRED + NGREEN)*π*0.0005^2
where N is the number of photons per second
N = 5e-3 / (hc/λ)
I'm just unsure whether the equation I used for σ is correct or not.
Can somebody confirm?
Many thanks in advance!
Thank you for your question. Your attempt at a solution is on the right track. However, there are a few things that could be clarified and some minor corrections that need to be made.
Firstly, the equation you used for σ is not quite correct. The correct equation for the cross section of scattering is σ = (NRED + NGREEN) / (NRED + NGREEN)*π*0.0005^2. This is because the intensity of the beams is already taken into account in the calculation of NRED and NGREEN, so it does not need to be included again in the final calculation of σ.
Also, in your calculation of NRED and NGREEN, you used the power of the lasers (5 mW) instead of the intensity. The intensity is given by I = P/A, where P is the power and A is the area of the beam. In this case, the area of the beam is π*0.0005^2, so the correct calculation for NRED and NGREEN would be NRED = 5e-3 / (hc/650e-9)/π*0.0005^2 and NGREEN = 5e-3 / (hc/532e-9)/π*0.0005^2.
Lastly, the equation you used for σ assumes that the intensity of the beams is decreased by 10% each after the collision. However, the homework statement states that the intensity is decreased by 10% for each beam, not for both beams combined. Therefore, the correct equation for σ would be σ = (0.9*NRED + 0.9*NGREEN) / (NRED + NGREEN)*π*0.0005^2.
I hope this helps clarify your solution. If you have any further questions, please don't hesitate to ask. Keep up the good work!
Related to Cross section - scattering of light by light
What is cross section in relation to the scattering of light by light?
Cross section is a measure of the probability that a particle will interact with another particle in a given area. In the context of scattering of light by light, it represents the likelihood that a photon will collide with another photon and change direction.
How is cross section calculated for the scattering of light by light?
Cross section for the scattering of light by light is calculated using quantum electrodynamics, which describes the interactions between photons. It takes into account factors such as photon energies and polarization states.
What is the significance of the cross section in studying the scattering of light by light?
The cross section is an important parameter in understanding the behavior of photons and their interactions with each other. It allows scientists to make predictions about the behavior of light and to test theories about the fundamental nature of particles and their interactions.
How does the cross section vary with different types of light?
The cross section for the scattering of light by light can vary depending on the energy and polarization state of the photons involved. Higher energy photons and those with different polarization states will have different cross sections.
What are some real-world applications of studying the cross section in light scattering experiments?
Studying the cross section in light scattering experiments can help in the development of new technologies such as advanced communication systems and high-energy lasers. It can also aid in understanding the properties of materials and their interactions with light, which has applications in fields such as solar energy and optical imaging.
  • Atomic and Condensed Matter
