Crossover help for Genetic algorithm
  • Thread starter Superposed_Cat
  • Tags
    Algorithm
In summary: Use the matrix representation and see if the GA converges faster. If not, try the parameterisation with the order and see if that makes a difference.In summary, we're making a robot that teaches itself to walk using a genetic algorithm. The GA works like this "A++,B---,D+" would mean motor A's angle increase by 2*num, and B's angle decrease by 3*num value, angle D's, will be increased by 1*num. But now we can't use standard crossover otherwise they will be a HUGE change between the new and old chromosomes, So our current idea is to cross just the +'s and -'s ieA++,B---A--,B++
Superposed_Cat
388
Hey all, we're making a robot that teaches itself to walk using a genetic algorithm(took a hiatus with this but have returned).
So i coded a simulator that to see why the GA wasn't working well with realistic physics.
A++,B---
A--,B++
Would cross to
A+-,B-+
But then motor changes have to be in a specific order, so unless they're in the optimum configuration which is cheating) it can never get to an optimum, Any advice? this is like the traveling salesman Genetic algorithm, which needed its own unique crossover and mutation. Any help appreciated.
Technology news on Phys.org
The paramétrization of your problem is bad, you can change it now ! By using the one you explain, the convergence of the genetic algorithm will be extremely long for multiple reason :
- random mutation change sequence leight.
- random mutation have a great probability to make a very bad individu.
- cross over is hard to write
- A small change on the entry give a very high change of the cost function.
- Angle are discrete so optimisation is combinatorial AND localy discrete (Haaaard to optimise !)
The simpler and perfect way :
for each motor (joint) create a vector, each element at index i of the vector is the value of the motor at time i. Optimise this set of vector as the term of a matrice.
T1 T2 T3 T4
Motor 1 : 0.22 0.44 1.02 0.002
Motor 2 : 0.04 0.00 2.0 8.59
Motor 3 : 3.25 4.5 4.8 20.1
with this solution mutating a solution is just adding random value to an élément. Crossing over is selecting a part of the matrix and remplace from another : Easy !
Likes hamid91dehnavi
Thanks kroni! Was hoping you'd reply. We had this other idea to help it get to the solution faster,
assume we have population of 5 (i know its small its hypothetical). then we take top percentile, so 2
now we look for "patterns" in them, to try find what makes them good.
ie in strings
abcdabcdabcd
abbabdbabda
the pattern would be:
ab,ab,da,bd
Second question, that matrix form means that the order which the motors are activated would be the same every time, can you think of a way that we could avoid that and still get to a solution?
No no no ! Why there is an order to activate motors ?
In my solution, motor are all activated at the SAME TIME for each collumn of the matrix.
do you understand it ?
Oh, I see now, initially i thought t represented the generation at time t, but why would that make a difference?
Because in your solution motor order is important so this add a lot of combinaison for équivalent solution, this is more complex for the Genetic Algorithm to converge. In the matrix representation of the parameter to optimize, you don't have this order, you have only continuous value in each case, so a small variation of the parameter make a small variation of the score. In you parameterization, small variation of the parametre (A to D, or permutation) imply a great variation of the score. Genetic algorithm will have great difficulty to converge.
I think you need to try the both.
Related to Crossover help for Genetic algorithm
1. What is a crossover in a genetic algorithm?
A crossover in a genetic algorithm is a process of combining genetic material from two parent solutions to create a new offspring solution. This is based on the idea of natural selection and mimics the way genes are passed down from parents to their offspring in biological evolution.
2. Why is crossover important in genetic algorithms?
Crossover is important in genetic algorithms because it introduces new genetic material and promotes diversity in the population. This helps the algorithm to explore a larger search space and potentially find better solutions to the problem at hand.
3. How does crossover work in a genetic algorithm?
In crossover, a random point is chosen in the genetic sequence of the parent solutions. The genetic material before this point is taken from one parent and the material after this point is taken from the other parent. This creates a new offspring solution with a combination of genetic material from both parents.
4. What are the different types of crossover in genetic algorithms?
The most commonly used crossover methods in genetic algorithms are single-point crossover, two-point crossover, and uniform crossover. Single-point crossover involves choosing one random point in the genetic sequence, while two-point crossover involves choosing two random points. Uniform crossover involves selecting genetic material from each parent with equal probability.
5. Can crossover be applied to any type of problem in a genetic algorithm?
While crossover is a widely used technique in genetic algorithms, it may not be suitable for every type of problem. In some cases, a problem may require a more specialized form of crossover or may not require crossover at all. It is important to consider the problem and its constraints before deciding on the use of crossover in a genetic algorithm.
  • Mechanical Engineering
