Crust on old Battery -- What happens when you drop Vinegar on it?
  • Thread starter Thread starter Mikestone
    Battery Drop
The discussion centers around the chemical reaction between vinegar (acetic acid) and the whitish encrustation found on an old Duracell battery, which is likely potassium carbonate. When vinegar is applied, it reacts with the alkaline substance, resulting in fizzing and the disappearance of the crust. The main by-products of this reaction are water and carbon dioxide. The potassium from the battery's electrolyte, which is typically concentrated potassium hydroxide (KOH), may convert to potassium acetate during this process. There is a caution against assuming that the composition of acetic acid directly leads to the production of water and carbon dioxide; rather, it is the acidic nature of acetic acid that facilitates the reaction with carbonates. The potassium may either remain in the battery as potassium acetate or be washed away with the vinegar.
Mikestone
I had an old Duracell battery with the bottom covered by a whitish encrustation. When I dropped some vinegar on this, there was a vigorous fizzing, and the encrustation disappeared.
Any idea what the encrustation was (presumably soething alkaline, since vinegar is acidic) and what the likely by-products were?
Chemistry news on Phys.org
A quick Google 'crust on battery' suggests some likely candidates. Why don't you kick start the discussion with some initial facts?
Thanks for the suggestion.
I've seen online that the crust may well be potasssium carbonate. I've also checked and found that acetic acid is an elaborate combination of hydrogen carbon and oxygen.
This being so I should guess that the main products would be water and carbon dioxide. Only thing I'm unsure about is what happens to the potassium Might it just get deposited aon the bottom of the battery, or would it combine with something?
Quite likely. Batteries contain concentrated KOH as an electrolyte, if it leaks it absorbs atmospheric CO2 producing carbonate.
Beware: just because it is a combination of these elements doesn't mean it will decompose during the reaction to produce water and carbon dioxide, which you seem to be suggesting:
Yes, but it has nothing to do with the composition of acetic acid. Actually the important part here is not the "acetic", but "acid". Any acid reacting with any carbonate will produce water and carbon dioxide.
Potassium is all the time there, just converted to potassium acetate. Could be it was washed away with the acetic acid (I suppose you used a vinegar, which is a diluted solution of the acid).
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
