Crystal Goblet-Opera Singer Frequency Problem
To shatter a crystal goblet through resonant vibration, an opera singer must produce a frequency that matches the goblet's natural frequency, determined by its dimensions and the speed of sound in the glass. The goblet has four nodes and four antinodes, indicating a specific harmonic mode. The relationship between wave speed, frequency, and wavelength is crucial, with the formula V=F*wavelength guiding the calculations. Understanding how nodes and antinodes relate to wavelength is essential for determining the correct frequency needed to achieve resonance. Accurate calculations are necessary to avoid failure in the final attempt.
pc21
Standing-wave vibrations are set up in a crystal goblet with four nodes and four antinodes equally spaced around the 15.0 cm circumference of its rim. If transverse waves move around the glass at 920 m/s, an opera singer would have to produce a high harmonic with what frequency to shatter the glass with a resonant vibration?
V=F*wavelength
if someone could explain how to do this or do it out it would be good because i have one more chance to get it right otherwise its wrong
Hi pc21,
How are the nodes and antinodes related to the wavelength of a wave?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
