James Kidder
- 3
Could a crystal radio use a lead sulfide or lead selenide antenna an pick up in the infrared?
A crystal radio in the infrared is a type of radio receiver that uses crystals to detect and amplify infrared light signals. It is typically used in communication systems and remote controls.
A crystal radio in the infrared works by using a crystal detector, which converts the incoming infrared light signals into electrical signals. These signals are then amplified by a series of tuned circuits and can be heard through a speaker or headphones.
One advantage of using a crystal radio in the infrared is that it does not require an external power source, as it uses the energy from the incoming light signals to operate. It also has a simple design and is relatively inexpensive to produce.
One limitation of a crystal radio in the infrared is that it can only receive signals in the infrared frequency range, which is limited compared to other types of radio receivers. Additionally, it may be affected by interference from other light sources or electronic devices.
A crystal radio in the infrared differs from other types of radio receivers in that it uses crystals to detect and amplify infrared light signals, while other receivers may use different components such as antennas and transistors. It also has a limited frequency range compared to other receivers.
