HTML/CSS [CSS] Why do my containers shrink at screen widths <347px?
  • Thread starter Thread starter Darkmisc
    Css
The discussion centers on issues with a mobile responsive webpage that experiences layout problems when the screen width drops below 347px. The outer and inner containers shrink unexpectedly, causing misalignment and loss of center alignment for components like the hero section and "Our Services." Despite attempts to adjust the width, margin, and padding settings, the problem persists. The user notes that while the text, buttons, and images remain unaffected, the containers do not respond as intended.Several solutions were explored, including hardcoding widths for smaller screens and using media queries, but these approaches either compromised responsiveness or did not resolve the shrinking issue. The conversation also touches on the differences between CSS grid layouts and Java's grid bag layout, with suggestions to isolate components to identify the cause of the issue. Ultimately, the user found success by adjusting the parent container's width and ensuring proper media query syntax, highlighting the importance of correctly applying CSS properties for responsive design.
Darkmisc
TL;DR Summary
I'm making a mobile responsive page. It works fine until the screen width is <347px. After that, the container that holds everything starts to shrink and stops being centre aligned.
Hi everyone
I'm making a mobile responsive page. It's pillarboxed for wider screens, so I'm holding everything in an outer and inner container. This works fine until the screen width is < 347px.
After this, it seems like the containers shrink. The dark background for the hero section shrinks and so do all the components held in the container (e.g. Our Services). They also stop being centre aligned.
The text, buttons and image within the hero section do not seem to be affected by this. I can't seem to work out why. I thought it might be because they use a grid layout and specify the width to be grid: 1/2.
I tried doing this in the inner/outer container (with width as 1fr and auto). Neither of these options fixed the problem.
I've also set the margin and padding to 0 for screen widths <347, but that doesn't seem to work either.
I set the width to be 100%, but the issue still remains.
[CODE lang="css" title="Inner/outer container" highlight="33, 34, 35, 36, 38, 11-15,"]const OuterContainer = styled.div`
width: 100%;
position: relative;
overflow: hidden;
background: #f7f7f7;
display: flex;
justify-content: center;
@media screen and (min-width: 347) {
display:grid;
grid-template-columns:1fr;
grid-template-rows:1fr;
grid-column: 1/2;
grid-row: 1/2;
width: 100%;
max-width: 100%;
margin:0;
padding:0; }
const InnerContainer = styled.div`
width: 100%;
max-width: 1300px;
background: white;
margin: 0 auto;
display:grid;
grid-column: 1/2;
grid-row: 1/2;
margin:0;
padding:0;
width: 100%;
max-width: 100%; }
[/CODE]
Here's the full code for the file.
[CODE lang="css" title="home.js" highlight=""]
import React from 'react';
import '../../App.css';
import './BodyText.css';
import styled from 'styled-components';
import FooterWithColumns from "./FooterWithColumns.js";
import BCarousel from './BCarousel.js';
import { useGlobals } from "../../Globals.js";
import BAccordion from './BAccordion.js';
import WhyChooseUs from './WhyChooseUs.js';
import LTextHeader from './LTextHeader.js';
import BServices from './BServices.js';
const Parent = styled.div`
width:100%;
@media screen and (max-width: 347px) {
width:347px;
const HeaderWrapper = styled.div`
width: 100%;
position: relative;
overflow: hidden;
display: flex;
display:flex;
width: 100%;
max-width: 100%;
margin:0;
padding:0; }
width: 100%;
max-width: 1300px;
background: white;
margin: 0 auto;
display:flex;
margin:0;
padding:0;
width: 100%;
max-width: 100%; }
const TestimonialsContainer = styled.div`
padding: 20px;
background-color: ${props => props.background || 'transparent'};
const FAQsContainer = styled.div`
padding: 20px;
const OurServicesContainer = styled.div`
padding: 20px;
padding-bottom:0;
margin: 0 auto;
margin-bottom:0;
const Testimonials = ({ globalFont, background }) => (
<TestimonialsContainer background={background}>
<BCarousel/>
</TestimonialsContainer>
const FAQs = ({ globalFont, background }) => (
<FAQsContainer background={background}>
<BAccordion/>
</FAQsContainer>
const OurServices = ({ globalFont, background }) => (
<OurServicesContainer background={background}>
<BServices/>
</OurServicesContainer>
export default function Home() {
const { GlobalFont } = useGlobals();
const ColorA = "white";
return (
<Parent>
<HeaderWrapper style={{ marginTop: '80px' }}>
<LTextHeader />
</HeaderWrapper>
<OuterContainer>
<InnerContainer>
<OurServices background={ColorA} />
<WhyChooseUs/>
<Testimonials globalFont={GlobalFont} background={ColorA} />
<FAQs background={ColorA} />
</InnerContainer>
</OuterContainer>
<HeaderWrapper>
<FooterWithColumns />
</HeaderWrapper>
</Parent>
[/CODE]
EDIT: I tried rendering it without the containers (and no pillarboxing) and the same thing still happens.
I put everything inside <Parent> and then hardcoded the width for smaller screens at 347px. This stops the components inside from shrinking, but my page is no longer responsive.
If I set the width to 100% or 100vw in the media query of <Parent>, the components start shrinking again.
I tried the below code and it works. I could just continue with the string of media queries all the way down to 320px, but I'd prefer a more elegant solution if one exists.
[CODE lang="css" title="Parent"]const Parent = styled.div`
width:100%;
width:347px;
@media screen and (max-width: 346px) {
width:346px;
@media screen and (max-width: 345px) {
width:345px;
@media screen and (max-width: 344px) {
width:344px;
@media screen and (max-width: 343px) {
width:343px;
@media screen and (max-width: 342px) {
width:342px;
@media screen and (max-width: 341px) {
width:341px;
@media screen and (max-width: 340px) {
width:340px;
`[/CODE]
Does anyone know why it's doing this?
Thanks
Technology news on Phys.org
Is there an option to use a grid bag layout? In Java, we tended to use that layout for GUI components as it resized well when windows were changed.
The grid layout always boxed components into the grid with each cell the same dimensions, and in some cases, a component refused to shrink beyond a certain point.
You could isolate the component that refuses to be resized to a smaller size.
UPDATE: Javascript/CSS/HTML doesn't have a gridbaglayout container as the grid layout can handle those features
There's grid layout in CSS, but I'm not sure if that's the same as grid bag layout.
Some components behave like they should. Others don't. I'm still trying to work out the difference between them.
It may be more than one component.
You can try commenting out one component at a time or components of the same type to see when it starts working.
Or comment them all out and add one at a time to see when it fails.
Why are you using a container with a grid of 1 column X 1 row? That is not a grid, it is a simple container. grid-template-columns:1fr; grid-template-rows:1fr;
And then you specify that the grid items must span from column 1 to column 2, and from row 1 to row 2, but there are no column 2 nor row 2. grid-column: 1/2; grid-row: 1/2;
Plus, you are mixing grid container attributes with grid item attributes in both the container and items.
If you want to achieve what I think you want to achieve, you should be able to do that by using display: flex; and fixing the width of your flex items.
These are my goto reference guides for flex and grid displays:
Likes berkeman, Darkmisc, DaveC426913 and 1 other person
Fixed it.
I put everything in this
[CODE title="Parent"]const Parent = styled.div`
width:100vw;
display: grid;
width:100%;
[/CODE]
I'd also forgotten the "px" in my media queries for the inner and outer containers :s
Likes jack action and jedishrfu
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
