Cube collision (with a pivot) and Angular momentum
In summary, the cube has mass M and moves with a velocity of v0. It collides with a small object that pivot over its side due to the impact. The angular momentum is L and is equal to the product of the mass and the velocity. The linear momentum is also equal to the product of the mass and the velocity, but the unknown force (impulse) on the pivot point is F.
fblin
Hi everybody some help needed here!
A cube, mass M move with v0 collide with small object "fixed" to the surface in Point P that make it pivot over its side
So far I think I understand:
During the impact there is no conservation of KE
L Angular Momentum : there is an unknown force F (Impulse) on the pivot point
p Linear Momentum : there is a Impulse = F*t in the pivot point (or I should have to consider the mass of the earth)
Known data:
mass M, velocity v0 or v, Side 2a (note that is 2a just for simplification), cm center of mass, rcm vector distance from P to cm, rp distance from P to P (only for completeness)
Before (around Point P of pivot):
[tex]\vec{L} = \vec{r_{cm}}\times M\vec{v_{0}}[/tex]
in this case [tex]|r_{cm}||v_{0}|sin(\theta)=av_0[/tex]
[tex] L_{i} = aMv_{0}[/tex]
After:
[tex]\vec{L_{f}} = \vec{r_{p}} \times \vec{F}*t + \vec{r_{cm}} \times M\vec{v_{cm}} +I\vec{\\w}[/tex]
Where I is the Moment of Inertia of the cube and
[tex]v=\\wr_{cm}[/tex] and [tex]r_{cm} = a\sqrt{2} [/tex]
Note that [tex] r_{p} =0[/tex] so
[tex]L_{f} = 0*F*t + a\sqrt{2}M\\wa\sqrt{2}+I\\w[/tex] So
[tex]L_{i} = L_{f} [/tex]
[tex] aMv_{0} = 2a^2M\\w +I\\w [/tex]
[tex]
\\w = \frac{aMv_{0}}{2a^2M+I}
[/tex]
After the collision It is posible to use Conservation of energy:
E = KE+ V = mgh and KE is 0 and the higher point (the min velocity).
[tex] \frac{1}{2}Mv_{cm}+\frac{1}{2}I\\w^2 = Mga(\sqrt{2}-1)[/tex]
It that ok?
What does the question ask for?
I have doubts with KE after the collision.
Is posible that in
[tex] \frac{1}{2}Mv_{cm}^2+\frac{1}{2}I\\w^2 = Mga(\sqrt{2}-1)[/tex]
The term
[tex] \frac{1}{2}Mv_{cm}^2[/tex] is OK? or It's enough with [tex] \frac{1}{2}I\\w^2 = Mga(\sqrt{2}-1)[/tex]?
I am not clear so some help would be great
I think I have the answer.
It depends on I (moment of inertia)
If I is taken from the point of pivot P then I is including all the efect of the movement of the CM (center of mass). On the other hand, if I is referred to the CM then It is necessary to use :
including the KE of the CM.
same is true for the angular momentum L:
[tex]\vec{L_{f}} = +I\vec{\\w}[/tex]
If I is referred to P then [tex]\vec{r_{cm}} \times M\vec{v_{cm}}[/tex] is not necessary (It is included in I)
Notice that [tex]v_{cm}=a\sqrt{2}\\w[/tex] and adding it in the [tex]\vec{L_f}[/tex] and in KE It should be, by Parallel axis theorem, equivalent. So
[tex]I_p = I_{cm} + Md^2\ in\ this \ case \ I_p =I_{cm}+M2a^2}[/tex]
FAQ: Cube collision (with a pivot) and Angular momentum
What is cube collision with a pivot?
Cube collision with a pivot refers to the interaction between two or more cubes, where one of the cubes acts as a fixed point or pivot. This means that the pivot cube remains stationary while the other cubes collide with it and rotate around it.
How does cube collision with a pivot affect angular momentum?
Cube collision with a pivot can affect the angular momentum of the colliding cubes. When a cube collides with a pivot, the force applied causes the cube to rotate around the pivot, resulting in a change in its angular momentum. This can be calculated using the formula L = Iω, where L is the angular momentum, I is the moment of inertia, and ω is the angular velocity.
What factors influence the outcome of cube collision with a pivot?
There are several factors that can influence the outcome of cube collision with a pivot, including the mass and velocity of the colliding cubes, the distance between the pivot and the point of collision, and the shape and orientation of the colliding cubes. These factors can affect the resulting angular momentum and rotation of the cubes after collision.
How does the angle of collision affect cube collision with a pivot?
The angle of collision between two cubes can affect the outcome of cube collision with a pivot. When the cubes collide at an angle, the force applied to each cube is not directly in line with the pivot, causing the cubes to rotate and potentially changing their angular momentum. This can result in a different trajectory and rotation of the cubes after collision compared to a head-on collision.
Are there any real-world applications of cube collision with a pivot and angular momentum?
Yes, cube collision with a pivot and angular momentum have real-world applications in fields such as physics, engineering, and game development. For example, understanding the mechanics of cube collision with a pivot can help in designing more realistic simulations and games, as well as in predicting the outcomes of collisions in real-world scenarios such as car crashes or collisions between celestial bodies.
