MHB Cube Roots: Solve A+B=C Problem Easily
  • Thread starter Thread starter JamieLam
    Cube Roots
When solving the equation A^3 + B^3 = 22C^3, it is necessary to cube root both sides, including the 22. The correct transformation is C = ∛((A^3 + B^3)/22), which simplifies to C = (∛(A^3 + B^3))/∛(22). It's important to note that ∛(A^3 + B^3) does not equal A + B. Understanding these cube root properties is crucial for correctly solving the equation.
JamieLam
This is a simple question. The problem I'm facing is A cube plus B cube = 22 C cube
A cube plus B cube over 22 = C cube
At this junction I like to ask if I want to cuberoots both sides, will the 22 be cube root as well? I'm sorry to bother since I forgot my basics. I don't want solutions to the problem. I only want to know about the cube rooting. Thanks!
Mathematics news on Phys.org
Yes, you will have to cube the 22 as well. What you have is
$$\frac{A^3 + B^3}{22} = C^3.$$
If you cube both sides you realize that 22 can't be neglected. :)
Fantini said "cube" but I am sure he meant "cube root".
If C^3= \frac{A^3+ B^3}{22}
then C= \sqrt[3]{\frac{A^3+ B^3}{22}}= \frac{\sqrt[3]{A^3+ B^3}}{\sqrt[3]{22}}.
I hope you understand that \sqrt[3]{A^3+ B^3} is NOT the same a A+ B!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
