Cumulative Distribution Function problem
In summary, the problem asks to determine the cumulative distribution function of Y, which is defined as the middle value of the independent random variables X1, X2, X3 with the same cdf F(x). This can be calculated using the formula F(x) = P(X<=x) = ∫-inf to x f(y)dy, where f(y) is the probability density function of Y.
asd1249jf
Let the independent random variables X1,X2,X3 have the same cdf F(x). Let Y be the middle value of X1,X2,X3. Determine the cdf of Y.
I don't understand the question, what does it exactly mean when Y is the middle value of X1,X2,X3? I'm not exactly sure where to start. Can somebody help?
If one sample is [itex]X_1= -5[/itex], [itex]X_2= 3000[/itex], [itex]X_3= 500[/itex], then Y is the "middle value", 500. 500 is the "middle value" because -5< 500< 3000.
Oh.. Ok
I'm still a bit lost on how to tackle this problem..:confused:
Related to Cumulative Distribution Function problem
1. What is a Cumulative Distribution Function (CDF)?
A Cumulative Distribution Function (CDF) is a statistical function that shows the probability of a random variable being less than or equal to a given value. It is commonly used to describe the probability distribution of a continuous random variable.
2. How is a CDF different from a Probability Density Function (PDF)?
A Probability Density Function (PDF) describes the probability of a random variable taking on a specific value. In contrast, a CDF shows the probability of a random variable being less than or equal to a given value. Essentially, the CDF is the integral of the PDF.
3. What is the range of values for a CDF?
The range of values for a CDF is between 0 and 1. This represents the probability of a random variable being less than or equal to a given value. The CDF starts at 0 for the lowest possible value and ends at 1 for the highest possible value.
4. How is a CDF used in statistical analysis?
A CDF is commonly used in statistical analysis to calculate the probability of a random variable falling within a certain range of values. It is also used to compare different probability distributions and to determine the likelihood of a certain outcome.
5. How do you graph a CDF?
A CDF can be graphed by plotting the cumulative probabilities on the y-axis and the corresponding values of the random variable on the x-axis. The resulting curve is called a CDF curve and can be used to visualize the distribution of the random variable.
