Curiosity about why this is not a Function composition
In summary: But, I'll give a brief summary.First, note that the solutions to the functional equation [itex]f:[a,b]\to[a,b],\,f(f(f(x))) = x[/itex] are just the permutations of [itex][a,b][/itex]. So there are [itex](b-a+1)! = 3! = 6[/itex] solutions. If you want to find the solutions to the functional equation [itex]f:[a,b]\to[a,b],\,f(f(f(x))) = x[/itex] more generally, then you'd have to consider the group [itex]S_n[/itex] and its subgroups. But I
ecastro
254
If ##f\left(x\right) = x^2 + 2x + 2##, find two functions ##g## for which ##\left(f \circ g\right)\left(x\right) = x^2 - 4x + 5##.
If ##f\left(x\right) = x^2 + 2x + 2##, then ##\left(f \circ g\right)\left(x\right) = g\left(x\right)^2 + 2g\left(x\right) + 2##, so ##g\left(x\right)^2 + 2g\left(x\right) + 2 = x^2 - 4x + 5##
By solving for ##g\left(x\right)##,
\begin{align*}
g\left(x\right)^2 + 2g\left(x\right) + 2 - 2&= x^2 - 4x + 5 - 2 \\
g\left(x\right)^2 + 2g\left(x\right) &= x^2 - 4x + 3 \\
g\left(x\right)\left[g\left(x\right) + 2\right] &= \left(x - 3\right)\left(x - 1\right)
\end{align*}
From here ##\left(x - 3\right)## is a solution, but ##\left(x - 1\right)## is not. Now, according to the answers provided, another function ##g## is ##1 - x##, which is the negative of ##x - 1##. How do you arrive at this solution?
I know that it is possible to let ##\left(x - 3\right)\left(x - 1\right) = -\left(x - 3\right)\left(1 - x\right)##, but what is the intuition behind it?
Likes Leo Consoli
Well, you have ##g(x) \left [ g(x) + 2 \right ] = (x - 3)(x - 1)## but you could flip the signs and also write ##g(x) \left [ g(x) + 2 \right ] = (3 - x)(1 - x)## and since ##(3 - x)## = ##(1 - x) + 2## you can then identify ##g(x)## with ##(1 - x)## and ##g(x) + 2## with ##(3 - x)##
Likes SammyS, Leo Consoli and mfb
\begin{align*}
g\left(x\right)^2 + 2g\left(x\right) + 2 - \color{red}2 & = x^2 - 4x + 5 - \color{red}2 \\
\end{align*}
That's a good start.
Rather than subtracting 2, subtract 1. That gives the following.
## \left(g(x)\right)^2 + 2g\left(x\right) + 1 = x^2 - 4x + 4 ##​
The expression on each side of the equation is a perfect square.
Likes Leo Consoli and mfb
RPinPA said:
Well, you have g(x)[g(x)+2]=(x−3)(x−1)g(x)[g(x)+2]=(x−3)(x−1)g(x) \left [ g(x) + 2 \right ] = (x - 3)(x - 1) but you could flip the signs and also write g(x)[g(x)+2]=(3−x)(1−x)g(x)[g(x)+2]=(3−x)(1−x)g(x) \left [ g(x) + 2 \right ] = (3 - x)(1 - x) and since (3−x)(3−x)(3 - x) = (1−x)+2(1−x)+2(1 - x) + 2 you can then identify g(x)g(x)g(x) with (1−x)(1−x)(1 - x) and g(x)+2g(x)+2g(x) + 2 with (3−x)
Is there any particular reason why we should flip signs?
Oh, I never thought of this. Thanks!
Because it gives another solution. It's just a thing to try, an equivalent equation with potentially a different solution. Which turns out to be the case.
Sorry if this is too far of an aside, but I always wondered how to determine the number of solution to functional equations, or a method that exhausts all solutions. What if we, e.g., have the equation f(x)^3 =Id, aka, find all f with fofof(x) =x (where o means function composition).
To further answer OP's question:
Rather than saying "flip the signs", consider the following.
You can write ##\ (x-3)\ ## as ##\ -(-x+3)\ ##.
Similarly write ##\ (x-1)\ ## as ##\ -(-x+1)\ ##.
So, ##\ (x-3)(x-1) =(-(-x+3))(-(-x+1)) = (-x+3)(-x+1) \ ##.
To finish things off:
Write this as ##(-x+1)(-x+3) = ((-x+1))((-x+1)+2) \ ##.
Combine this with what you have done in the OP.
Likes Leo Consoli
This is complicated and way beyond the scope of this thread if treated properly.
Likes WWGD
Related to Curiosity about why this is not a Function composition
1. Why is it important to understand function composition in science?
Function composition is a fundamental concept in mathematics and science that allows us to break down complex systems into smaller, more manageable parts. By understanding function composition, scientists can better analyze and model real-world phenomena, make predictions, and develop new theories.
2. What is the difference between a function and a composition of functions?
A function is a rule that maps one set of values to another set of values. A composition of functions is the combination of two or more functions, where the output of one function becomes the input of another. In other words, a composition of functions is a function within a function.
3. How do you determine if a given set of functions can be composed?
To determine if a given set of functions can be composed, you need to check if the output of one function matches the input of another function. If the output of one function can be used as the input of another, then the functions can be composed.
4. Can any two functions be composed?
No, not all functions can be composed. For two functions to be composed, the output of one function must match the input of the other function. Additionally, the domain of the first function must contain the range of the second function.
5. How can understanding function composition help in problem-solving?
Understanding function composition can help in problem-solving by breaking down a complex problem into smaller, more manageable parts. By identifying the functions involved and how they can be composed, scientists can approach problem-solving in a systematic and logical manner, leading to more accurate and efficient solutions.
