B Curiosity on this infinite product
The discussion centers on the infinite product of twos, expressed as ##p_{n} = 2^n##, which diverges to infinity as ##n## approaches infinity. When considering the infinite case, the equation ##2 \cdot x = x## leads to the paradoxical conclusion that ##x = 0##, raising questions about the validity of this result. Participants highlight that assuming a limit exists for such divergent products is flawed, as it leads to contradictions, such as deriving that ##1 = 0## from other infinite sums. The conversation emphasizes the importance of recognizing the limitations of mathematical assumptions in infinite contexts. Ultimately, the discussion illustrates the complexities and potential pitfalls of manipulating infinite products and sums.
Ssnow
TL;DR Summary
Curiosity question on the infinite product ##2\cdot 2\cdot 2\cdots ##
Let us consider the infinite products ## p_{n}\,=\, 2\cdot 2\cdot 2 \cdot 2 \cdots 2 \,=\, 2^n## with ##n=1,\ldots ## . Clearly ##p_{n}\rightarrow +\infty## as ##n\rightarrow +\infty##. But if I put the infinity case ## 2\cdot 2\cdot 2 \cdot 2 \cdots \,=\, x## I have ##2\cdot x =x ## so ##x=0##. It is obvious I cannot put ##x=2\cdot 2\cdot 2 \cdot 2 \cdots ## and to try to seach the limit because the product diverges but has this "strange" algebraically formal result a conceptual reason to be (for example it is linked to the way to do the products ?) or it is only wrong and stop here ?
Thank you,
Ssnow
Mathematics news on Phys.org
Ssnow said:
Summary:: Curiosity question on the infinite product ##2\cdot 2\cdot 2\cdots ##
Or ##x=\infty##. If you rule out ##\infty## here, then you are biasing the result.
@FactChecker thanks, sure ##x=0 \vee x=\infty##. I ask for the absurd solution ##x=0## ...
Ssnow
This is a pretty classic thing where you can create fake math. The real issue is that you started off by assuming a limit exists. If there is a limit and it is L (L is a real number), then 2L=L so L=0. But this assumes the limit exists to begin with, which obviously it does not.
You can get more obvious contradictions. 1+1+1+..., If it has a limit of L then 1+L= L so 1=0.
@Office_Shredder I think ##1+L=L## imply that ##0L=-1## that is impossible!
In any case from something of false you can deduce everything ... :biggrin:
Thank you!
Ssnow
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
