Curious about the uniform electric field between metal plates
In summary, the uniform electric field between metal plates is created when a voltage is applied across the plates, resulting in a consistent electric field strength and direction throughout the space between them. This field is characterized by parallel lines and is directly proportional to the voltage and inversely proportional to the distance between the plates. Understanding this concept is essential in applications such as capacitors, where the behavior of electric fields influences energy storage and circuit design.
hongseok
TL;DR Summary
How is there a uniform electric field between two parallel metal plates? Okay, I can understand it through electric field lines. But how can this be quantitatively confirmed? My intuition is that as the charge approaches the metal plate, r becomes very small, so according to Coulomb's law, a much larger electric field must be applied. Is it perhaps canceled out by the assumption that it is an infinite sheet of metal? Please provide detailed explanation.
hongseok said:
TL;DR Summary: How is there a uniform electric field between two parallel metal plates? Okay, I can understand it through electric field lines. But how can this be quantitatively confirmed? My intuition is that as the charge approaches the metal plate, r becomes very small, so according to Coulomb's law, a much larger magnetic field must be applied. Is it perhaps canceled out by the assumption that it is an infinite sheet of metal? Please provide detailed explanation.
Are you asking about the uniform field inside a parallel-plate capacitor in the electrostatic case? If so, there is no magnetic field involved whatsoever.
Likes hongseok
I assume you wrote "magnetic" when you actually meant to say "electric" field.
What charge approaches the metal plate? Are you charging a parallel plate capacitor? The electric field is approximately uniform between the plates. Most notably, there is fringing at the edges.
Likes hongseok
The electric field between parallel plates is assumed uniform because the constant separation between the plates is small, when compared to the extent of the plates.
While changing voltage and charge, the plates of a parallel capacitor, can be modelled as a transmission line. During a change of voltage, there will be a temporary magnetic field associated with the charge that propagates.
Likes hongseok
Yes, I wanted to talk about electric fields. Sorry
Has your question been answered?
Likes hongseok
I think your intuitive mental model is based on an array of charges spaced all over the plate. Each charge will contribute to the force on your test charge. As the test charge is brought closer: 1. The nearby charges will cause a greater and greater charge in the Normal direction. 2. Charges elsewhere on the plate (away from the normal) will produce Coulomb's Law forces but symmetry will cause the tangential component of forces to cancel. The Normal componens of those forces will tend to zero. Only the charge directly under the test charge will produce a net Normal force. So the net Coulomb's Law forces will remain the same for all distances from the plate.
That's what the Maths says, too.
Likes hongseok
hongseok said:
My intuition is that as the charge approaches the metal plate, r becomes very small, ...
What also becomes very small is the amount of charge (or area) on the plate, within any given angle range, off the normal vector, which determines the relevant normal component of the Coulomb forces by those charges.
Since that area is proportional to r2, while the Coulomb force is proportional to 1/r2, the two effects cancel.
Likes sophiecentaur and hongseok
