Curl of the curl of E or B field
In summary, the standard way of deriving the EM wave equation from Maxwell's equations involves taking the curl of the E and B fields and using vector identities. This is justified by the fact that the curl of a vector field provides information about its rotation. Taking the curl of the curl of a field gives the rate at which its angular acceleration changes, which is crucial in obtaining a wave equation. This approach may seem like a random idea, but it is a valid and accepted method in mathematics, known as an ansatz. By decoupling the coupled first-order partial differential equations in Maxwell's equations, we can obtain second-order equations for each of the fields, ultimately leading to a vector wave equation. This method is similar to how a charged
DoobleD
259
A modern standard way of deriving the EM wave equation from Maxwell's equations seems to be by taking the curl of curl of E and B field respectively, and use some vector identity. See for instance on wikipedia.
So, I have a basic understanding of the curl of a vector field. Defined as the closed loop line integral divided by the infinitesimal area it encloses, curl is a vector field itself, offering some "rotation related" information of the vector field from which it is derived.
For a velocity field, the curl of the field at a point would be proportional to the field angular velocity at this point. For a force field, it would be proportional to the angular acceleration of the field at this point.
So far so good. Now, what means taking the curl of the curl of a force field ? Why is this justified when deriving EM waves ? Let's say you never looked at the EM wave equation derivation, and you just know what the curl of a field is. You stare at Maxwell's equation in their differential form, in vacuum.
Why would you take the curl of the curl of the fields ? What's the reason behind that move ? Can't just be a random idea.
The only logical interpretation I can see is that the curl of the curl of say the E field, is the rate at which the angular acceleration of the field changes at the given point. But that doesn't tell me why one would be interested with that.
Why can't it just be a random idea? Regardless of the motivation, the analysis is valid.
Often they call this an ansatz, which is basically an educated guess. It is a standard and accepted approach to math.
Well that's true it can actually be a random try. I just thought there was a particular reason or clue I wasn't aware of. Thanks for answering.
It can be random, but in this case it's not entirely random. If you want a wave equation, you need another derivative. If you want a vector wave equation, you need a vector operator. So curl is a good starting point.
Makes sense.
The two curl equations in Maxwell equations are coupled first order partial differential equations. So you can wonder if we can decouple them and write second order PDEs for each of the fields, by using the standard method of differentiating one of them again and then substituting from the other. For a more elementary example, for a charged particle in a magnetic field, moving in the xy plane, with the magnetic field along the z-axis:
dv/dt = (q/m) (v x B)
This is two first order coupled differential equations:
dvx/dt = (q/m) vy B (1)
dvy/dt = - (q/m) vxB (2)
To decouple these, differentiate (1) again wrt t, giving the first derivative of vy on the right. Now substitute for this from (2), and that gives you a de-coupled second order differential equ. for vx.
Likes EmilyRuck
Nice! At some point I was thinking one could maybe think using the curl of curl in order to "combine" Maxwell's equations to get equations with a single unknown (E or B). But I couldn't express this idea with enough formalism. You did just that, thank you. :D
Likes EmilyRuck
Related to Curl of the curl of E or B field
1. What is the Curl of the Curl of E or B field?
The Curl of the Curl of E or B field, also known as the second derivative of the electric or magnetic field, is a measure of how the field lines are changing in space. It describes the rotation of the electric or magnetic field around a point and is an important concept in the study of electromagnetism.
2. Why is the Curl of the Curl of E or B field important?
The Curl of the Curl of E or B field plays a crucial role in Maxwell's equations, which are fundamental equations in the study of electromagnetism. It helps us understand the behavior of electric and magnetic fields in different situations and is essential in many applications, such as in the design of electronic devices and communication systems.
3. How is the Curl of the Curl of E or B field calculated?
The Curl of the Curl of E or B field can be calculated using vector calculus operations, specifically the double cross product. It involves taking the Curl of the electric or magnetic field and then taking the Curl of the resulting vector again. The resulting vector is the second derivative or the Curl of the Curl of E or B field.
4. What are the physical interpretations of the Curl of the Curl of E or B field?
The Curl of the Curl of E or B field has two physical interpretations. Firstly, it represents the amount of rotational force experienced by a charged particle in the electric or magnetic field. Secondly, it describes the rate of change of the magnetic or electric flux density, which is a measure of the number of field lines passing through a given area.
5. Are there any real-world examples of the Curl of the Curl of E or B field?
Yes, the Curl of the Curl of E or B field has many real-world applications. For example, in the study of electromagnetics, it is used to analyze the behavior of electromagnetic waves, such as radio waves and light. It is also important in the design of electric motors and generators, as well as in medical imaging techniques such as magnetic resonance imaging (MRI).
  • Electromagnetism
  • Classical Physics
  • Electromagnetism
