Current Dividing in an Electrical Circuit
In summary, the total resistance of a circuit with a 7.5V d.c power supply and three resistors is 30 ohms. The largest current will pass through the 18 ohm resistor, while the smallest current will pass through the 60 ohm resistor. This is because current flows from high potential to low potential, and the potential difference over the 60 ohm and 15 ohm resistors is the same. Additionally, current divides as it flows into resistors connected in parallel, with the ratio of the resistances determining the distribution of current.
Muhammad Danish
70
Member advised to use the formatting template for all homework help requests
A circuit contains a 7.5V d.c power supply and three resistors. The total resistance of the circuit is 30 ohms. Why will the largest current in the 18 ohm resistor? As far as I know is that the smallest current will be in 60 ohm resistor because it has the maximum resistance. Please explain.
Thanks.
(regards)
Hi,
I don't see a contradiction in your statements: All the current that the supply delivers to the circuit will have to go through the 18 ##\Omega## resistor. And yes, the 60 ##\Omega## resistor will have a smaller amount of current than the 15 ##\Omega## resistor.
BvU said:
Hi,
Why won't the largest amount of current pass through 15 ohm resistor? Because lower the resistance, higher will be the current..
Current flows from high potential (voltage) -- the + of the power supply -- to low potential -- the ##-## of the power supply. On its path it has to go through resistor 18 ##\Omega## and after that it can and will branch over the other two. From the power supply + to the other end of the 18 ##\Omega## resistor there is a potential drop.
The left sides of the 60 ##\Omega## and the 15 ##\Omega## resistors are connected by a wire. So are the right sides.
In other words: the potential difference over the 60 ##\Omega## and the 15 ##\Omega## resistors is the same.
Can we say that current divides as it flows into the resistors connected in parallel?
Yes. I used the word branching. All the current that comes into a connection point has to go out again (or else it would build up a huge potential in no time)
Related to Current Dividing in an Electrical Circuit
1. What is current dividing in an electrical circuit?
Current dividing is a phenomenon that occurs in electrical circuits where the total current flowing through a circuit is divided among multiple parallel paths. This means that the current flowing through each path is less than the total current, but the sum of the currents in each path is equal to the total current.
2. How does current dividing affect the voltage in a circuit?
Current dividing does not affect the voltage in a circuit. The voltage across each parallel path remains the same, and the total voltage across the circuit is equal to the sum of the individual voltages in each path.
3. What factors affect the amount of current in each parallel path?
The amount of current in each parallel path is affected by the resistance of the path. Paths with lower resistance will have more current flowing through them, while paths with higher resistance will have less current.
4. How is current dividing calculated in a circuit?
Current dividing is calculated using Ohm's Law, which states that current is equal to voltage divided by resistance. By using this equation for each parallel path in the circuit, the amount of current in each path can be determined.
5. What is the purpose of current dividing in a circuit?
Current dividing is used to distribute the total current among multiple parallel paths, allowing for the efficient use of electrical energy. It also helps to prevent overloading of individual paths, which could result in damage to the circuit or its components.
