Current flow in semiconductors
In summary, current flow in semiconductors is determined by the movement of both electrons and holes. Valence bands and conduction bands are energy states within an atom, with valence bands containing electrons that do not contribute to current flow. Holes are not present in the conduction band, but rather can be created when electrons move from the valence band to the conduction band. The movement of electrons and holes combined creates current flow.
beyondlight
65
I have big trouble understanding how current flows in semiconductors.
As i have understood it it has to do with "valence" and "conduction" bands.
I see valence bands as an discrete energy level within an atom that are possessed by electrons. These electrons do not contribute to a net current if there is a electrif field applied over the semiconductor.
However I am confused about the conduction bands. Are they supposed to be viewed as an outer layer of the atom or as energy states, that if an electron can be in those energy states they are completely free from the atoms and just float around in the semiconductor??
The confusing thing is that is if the latter option is true, then it doesn't matter if the valence band is full or empty because they don't contribute to the condution. But if even holes float around in the conduction band then they cancel each other out and so there is not current?
And another confusing thing is that why is there needed to be holes in the valence band in order to enable the electrons to jump down into the holes and thus create a current flow? What is the need for electrons to exploit holes in the valence band if they are already in the conduction band?
How does holes in the valence band enable condution? Isn't it a state where particles are trapped inside atoms? And so can't support conduction??
beyondlight said:
However I am con fused about the conduction bands. Are they supposed to be viewed as an outer layer of the atom or as energy states, that if an electron can be in those energy states they are completely free from the atoms and just float around in the semiconductor??
I'd think of them as energy states. Trying to think about which electrons are where is confusing, as any electron can be just about anywhere in the atom since the orbitals are probability densities, not set paths through space.
Holes don't exist in the conduction band, they exist in the valence band.
Electrons jumping back down from the conduction band to the valence band isn't what gives you electrical current. The movement of the electrons and the movement of the holes combined give you current flow. A hole on one side of a diode can move to the other side, acting as if it were a positive charge. Since the hole has moved, the location it was originally at is now more negatively charged, as it was replaced by an electron in the valence band (this is not recombination, its just electrons moving around in the valence band). So you have the movement of the original electron that was excited into the conduction band, plus the movement of electrons in the valence band (which is modeled as if the hole were a positive charge moving in the opposite direction).
See here: https://en.wikipedia.org/wiki/Electron_hole
Related to Current flow in semiconductors
1. What is current flow in semiconductors?
Current flow in semiconductors refers to the movement of electric charge through a semiconductor material. This flow of charge is what allows semiconductors to be used in electronic devices such as transistors and diodes.
2. How does current flow in semiconductors differ from other materials?
The flow of current in semiconductors differs from other materials because of their unique properties. Unlike conductors, which have high conductivity, and insulators, which have low conductivity, semiconductors have a moderate level of conductivity that can be controlled by adding impurities or applying an external electric field.
3. What factors affect the flow of current in semiconductors?
The flow of current in semiconductors is affected by several factors, including the type and concentration of impurities, the temperature, and the strength of the electric field applied. These factors can alter the number of charge carriers in the material and their ability to move, thereby affecting the conductivity of the semiconductor.
4. How is current flow in semiconductors measured?
Current flow in semiconductors is typically measured using an ammeter, which measures the amount of electric current passing through a material. The resulting measurement is usually in units of amperes (A).
5. What are the applications of current flow in semiconductors?
The ability to control the flow of current in semiconductors has made them essential in modern electronic devices such as computers, smartphones, and televisions. They are also used in solar cells, which convert sunlight into electricity, and in sensors for various applications such as detecting temperature, pressure, and light.
  • Atomic and Condensed Matter
  • Electrical Engineering
  • General Engineering
