Current In Coil Around A Capacitor
In summary, the conversation discusses a problem with understanding the connection between a capacitor and a loop. The thought processes considered include the relationship between energy stored in the capacitor, charge on the capacitor, voltage difference, and current in the loop. The attachment mentioned in the conversation will take a day to be approved, but it is suggested to upload it to a photo site and share the link for easier viewing.
darkchild
155
1. Homework Statement
See attachment.
2. Haven't gotten there yet.
3.
The problem I'm having with this is seeing the connection between the capacitor (at least, that's what I assume that square thing is) and the loop. Frankly, I don't see why there would be or why there must be current in the loop at all. These are thought processes I've followed so far:
1. Energy stored in the capacitor implies there's a charge on the capacitor.
2. Charge on the capacitor implies that there is a voltage difference across the capacitor.
3. Voltage across capacitor causes a current in the loop...?
OR
1. Charged up capacitor means the current in the capacitor has stopped/is stopping.
2. Dwindling current implies a changing electric field.
3. Changing electric field induces a magnetic field in loop.
4. ? somehow that relates to current in the loop?
  • can any body answer it......doc
It will take a day for your attachment to be approved. It would be better to upload the diagram to a free photo site like photobucket.com, then post a link to it here. If you put IMG before the link and /IMG after (both in square brackets), the diagram will appear right in the post.
Hello,
Thank you for sharing your thought processes and concerns about the given problem. Let me try to address them and provide some insights as a scientist.
Firstly, you are correct in your understanding that the square object is a capacitor. A capacitor is a device that stores electrical energy in the form of an electric field. It consists of two conductive plates separated by an insulating material, known as the dielectric. When a voltage is applied to the capacitor, it charges up, meaning that one plate becomes positively charged and the other becomes negatively charged.
Now, to answer your question about the current in the loop, let's break it down step by step.
This is correct. As mentioned earlier, when a voltage is applied to the capacitor, it charges up, meaning that one plate becomes positively charged and the other becomes negatively charged. This charge is what stores the energy in the capacitor.
Again, this is correct. The charge on the capacitor creates a voltage difference between the two plates. This voltage difference is what causes the electric field in the capacitor.
This is where things get interesting. You are correct in thinking that a voltage difference causes a current to flow. However, in this case, the current is not flowing through the capacitor, but rather through the loop surrounding the capacitor. This is because the changing electric field in the capacitor induces a changing magnetic field in the loop, which in turn induces a current in the loop. This phenomenon is known as electromagnetic induction.
4. Charged up capacitor means the current in the capacitor has stopped/is stopping.
This is not entirely accurate. When a capacitor is fully charged, it does not mean that the current has stopped. It means that the current has reached a steady state, where the rate of charging is equal to the rate of discharging. This means that the current is still flowing in the circuit, but it is not changing.
5. Dwindling current implies a changing electric field.
This is correct. As the current in the capacitor decreases, the electric field also decreases. This changing electric field then induces a changing magnetic field in the loop, which, as mentioned earlier, induces a current in the loop.
I hope this helps to clarify the connection between the capacitor and the loop and how current
FAQ: Current In Coil Around A Capacitor
What is the purpose of having a current in coil around a capacitor?
The current in coil around a capacitor serves to create a magnetic field that interacts with the electric field of the capacitor, resulting in the storage of energy.
How does the current in coil affect the capacitance of a capacitor?
The current in coil has no direct effect on the capacitance of a capacitor. However, it can indirectly affect the capacitance by altering the electric field strength and therefore the amount of charge that can be stored.
Can the current in coil around a capacitor be varied?
Yes, the current in coil can be varied by changing the strength of the magnetic field, which can be done by adjusting the number of turns in the coil or by changing the current flowing through the coil.
What type of capacitors are typically used with a current in coil?
Any type of capacitor can be used with a current in coil, but typically electrolytic or film capacitors are used due to their ability to handle high voltages and currents.
How does the current in coil affect the energy stored in a capacitor?
The current in coil increases the energy stored in a capacitor by creating a stronger magnetic field and therefore a stronger interaction with the electric field of the capacitor. This results in a higher amount of energy being stored in the capacitor.
