Current on Infinite Periodic LC Circuit
The discussion revolves around deriving the equation of motion for an infinite periodic LC circuit and its relation to an infinite spring-mass system. The user is attempting to match the motion equations, specifically looking for a way to define the equilibrium length (A) in the context of the LC circuit. They seek guidance on transforming their current current function In(t) into a form that aligns with I(nA,t). Additionally, there is a request for clarification on symbols and the definition of "infinite periodic LC circuit." The user indicates they may have resolved their issue and inquires about closing the thread.
Kyuubi
Show that the current on an infinite periodic LC circuit obeys the wave equation in the long wavelength limit with the speed of the wave being the speed of light.
Equations of motion of current in an LC circuit.
(In)''=1/LC(-2In +In+1 +In -1)
Note here In means i sub n. As in the current on the nth inductor.
I wrote down the equation of motion for In(t) and I'm trying to match it with infinite spring mass system equation solution. In the spring mass system, we consider A to be the equilibrium length of the springs, and we can thus write Xn(t) = X(nA,t) and put it back into the equation of motion while taking a Taylor Expansion. This allows us to model the system as a long thin rod that's been pushed. But in the infinite periodic LC Circuit, what exactly is my A? What will help me turn my In(t) to I(nA,t)? In other words, how can I change my equation of motion
Sorry I'm new to this. Is there a way to delete a thread or close it? I think I've solved my problem.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
