Current Source in Parallel with Short Circuit
In summary: KVL is not violated because the voltage drop across the short circuit is zero and any other branches would have a voltage drop of zero as well since there is no current going through them. In summary, the conversation discusses a circuit with a 2 Amp current source in parallel with a short circuit and whether or not it is a self-contradictory combination of circuit elements. The answer key states that it is not contradictory because an ideal current source provides a given current regardless of the load, and the voltage across a short circuit is zero. The conversation also mentions the equations KVL, KCL, and Ohm's Law, and the student's initial confusion about the concept. After further explanation, they understand that KVL is not
nickadams
182
Which of the following are self-contradictory combinations of circuit elements?
- A 2 Amp current source in parallel with a short circuit.
KVL- "the sum of voltages around a closed loop amounts to 0.
KCL- "the current into a node equals the current out of a node.
Ohm's Law- V= IR
The answer key says this is not contradictory, but I don't see how we can have such a circuit... If we had a short circuit parallel to a current source wouldn't all the current go into that short circuit branch and ignore the other branches? Then we'd just have a loop of 2 Amp current with no voltage drop... Why wouldn't that violate KVL?
An ideal current source provides a given current no matter what the load is. The voltage across it is equal to the generator current multiplied by the loading resistance, zero for a short-circuit. Where is contradiction?
Likes nickadams
What are the other choices you're given?
Likes nickadams
I just always thought that in order for current to flow between two points we need a voltage difference...
I understand the rest of them... It was only this one I was hung up on
What is the voltage difference across zero resistance according to Ohm's Law?
Likes nickadams
V=IR so V=I*0=0. Ok I think I see now
FAQ: Current Source in Parallel with Short Circuit
1. What is a current source in parallel with short circuit?
A current source in parallel with short circuit is a specific circuit configuration where a current source and a short circuit are connected in parallel. This means that the two components share the same nodes or connection points, allowing current to flow through both.
2. How does a current source in parallel with short circuit behave?
In this configuration, the current source will provide a constant current, while the short circuit will allow all the current to pass through it without any resistance. This results in the short circuit essentially "shorting out" the current source, causing the overall current in the circuit to be equal to the current source's value.
3. What are the applications of a current source in parallel with short circuit?
This circuit configuration is commonly used in electronic devices to provide a stable and regulated current to certain components. It is also used in testing and troubleshooting circuits, as the short circuit can be removed to isolate the current source and determine its function.
4. What are the advantages of using a current source in parallel with short circuit?
One advantage is that it provides a constant and stable current, which is useful in applications where precise current control is needed. Additionally, it allows for easy isolation and testing of the current source, making troubleshooting and maintenance more efficient.
5. Are there any limitations or drawbacks to using a current source in parallel with short circuit?
One limitation is that the short circuit will always consume all the current, making it difficult to control the overall current in the circuit. Additionally, the short circuit can also cause damage to the circuit if it is not properly sized to handle the current from the source.
