MHB Current Through A half-wave rectifier
  • Thread starter Thread starter aNxello
    Current Rectifier
The discussion focuses on solving a Fourier Series problem involving an alternating current represented by i(t) = A sin(ωt) passed through a half-wave rectifier. The user attempts to derive the output current using a half-range sine Fourier Series but finds discrepancies between their calculated coefficients and the provided answer. Key points include the correct definition of the function for the half-wave rectifier and the need for integration by parts to resolve repeating integrals. Additionally, there is confusion about whether to use the half-range or full Fourier series for different parts of the problem. The conversation emphasizes the importance of correctly applying Fourier series formulas to achieve accurate results.
aNxello
Hello!
So I'm stuck in yet another problem, I've been going through some Fourier Series problems (including one that I already asked about around here, and go great help!) and I've managed to get past most, but I got once again stuck on one.
So for this one we got an alternating current of the form
$$i(t) = A\sin(\omega t)$$
that is passed through a half-wave rectifier, which the current when it is flowing in the positive direction only.
So I assumed to do a half-range sine Fourier Series
I approached it by taking the range and re-defining it, realizing that the period was $$2\frac{\pi }{\omega}$$ so from $$-\frac{\pi }{\omega}$$ to $$\frac{\pi }{\omega}$$
So since it is only on the positive side I made it so
$$f(t)=\begin{Bmatrix}A\sin(\omega t) & 0 \leq t\leq \frac{\pi}{\omega } \\
0 & -\frac{\pi}{\omega } \leq t \leq 0
\end{Bmatrix}$$
However the problem also told me the answer, but the coefficients I get are nothing like the answer, this is the answer:
$$i_{out} = \frac{A}{\pi } + \frac{A}{2}\sin(\omega t )- \frac{2A}{\pi}\sum \frac{\cos[(n+1)\omega t ]}{n(n+1)}$$There's also a second part, which is what would happen if the same current went through a full-wave rectifier, and for that the solution is:
$$i_{out} = \frac{2A}{\pi } -\frac{4A}{\pi}\sum \frac{\cos(n \omega t)}{n^{2}-1}$$I really hope you guys can help, this is driving me crazy (Whew)
Mathematics news on Phys.org
Can you show some of your work , to see what goes wrong ?
This is a picture of my work, but if you can't read it I got
$$a_{0} = \frac{4 \omega A}{\pi }$$
$$a_{n} = 0 $$
$$b_{n} = 4n^{2} \int \sin(\omega t)\sin(2nt\omega ) $$
And then that integral keeps repeating :/ (any tips on how to deal with partial integrals that repeat like btw?)
thank you!
I certainly cannot read that , can you try to write $$A_n , B_n $$ to solve them together ?
Assuming your integral is correct: first of all, your integrand is even. So simplify by saying $\int_{-a}^{a}=2\int_{0}^{a}$. Then try by-parts until you get your original integral back:
\begin{align*}
b_{n}&= 8n^{2} \int_{0}^{ \pi/ \omega} \underbrace{ \sin( \omega t)}_{u} \underbrace{ \sin(2n \omega t) \, dt}_{dv}\\
&= 8n^{2} \left[ \left(- \frac{ \sin( \omega t) \cos(2n \omega t)}{2n \omega} \right) \Bigg|_{0}^{ \pi/ \omega} + \frac{ \omega}{2n \omega} \int_{0}^{ \pi/ \omega} \cos( \omega t) \cos(2n \omega t) \, dt \right]\\
&= 4n \int_{0}^{ \pi/ \omega} \cos( \omega t) \cos(2n \omega t) \, dt.
\end{align*}
Do this again, with $u= \cos( \omega t)$ and $dv= \cos(2n \omega t)\, dt$, until you get back to your original integrand. Then you should be able to solve for $b_{n}$. Done.
Let me try this, I will update with my results, thank you!
Also the range was already from 0 to Pi/Omega!
Ok , if you are confused about integration by parts recall :
$$\cos\left( x+y\right) - \cos\left(x-y\right) = -2\sin(x)\sin(y)$$
Then you don't have to do integration by parts
So guys, I'm still lost, for the second part tho I found the answer,, I just have to do a full Fourier series of |sinx|, but for the first time I'm still confused if I should use the half range form or the regular form, and if I have o use the half range, how do I apply it to a function in the range -omega/pi to omega/pi
I'm really confused, and although I went and finished other problems, I still can't finish this one, and it's killing me:(
I just can't get to that answer
aNxello said:
Hello!
\end{Bmatrix}$$
Hi aNxello! :)
You seem to have mixed up your constants a bit.
From mathworld:
$$f(t) = \frac {a_0}{2} + \sum a_n \cos \frac {n \pi t} {L} + \sum b_n \sin \frac {n \pi t} {L}$$
where
$$\begin{aligned}
a_0 &= \frac 1 L \int_{-L}^L f(t) dt \\
a_n &= \frac 1 L \int_{-L}^L f(t) \cos \frac {n \pi t} {L} dt \\
b_n &= \frac 1 L \int_{-L}^L f(t) \sin\frac {n \pi t} {L} dt \\
\end{aligned}$$
Since you have $L=\dfrac \omega \pi$ and $f(t)=A\sin \omega t$ on the interval from $0$ to $L$, you get:
$$\begin{aligned}
a_0 &= \frac \omega \pi \int_0^{\pi/\omega} A \sin \omega t dt \\
a_n &= \frac \omega \pi \int_0^{\pi/\omega} A \sin \omega t \cos n \omega t dt \\
b_n &= \frac \omega \pi \int_0^{\pi/\omega} A \sin \omega t \sin n \omega t dt \\
\end{aligned}$$
Let's pick $a_0$. This one yields:
$$\begin{aligned}
&= \left. \frac \omega \pi (-\frac A \omega \cos \omega t) \right|_0^{\pi/\omega} \\
&= \frac A \pi (-\cos \pi - -\cos 0) \\
&= \frac {2A} \pi \\
\end{aligned}$$
So the first term is:
$$\frac {a_0} {2} = \frac A \pi$$
11K
