TyroneTheDino
- 46
- 1
A highway has an exit ramp that beings at the origin of a coordinate system and follows the curve
##y=\frac{1}{32}x^{\frac{5}{2}}## to the point (4,1). Then it take on a circular path whose curvature is that given bt the curve ##y=\frac{1}{32}x^{\frac{5}{2}}## at the point (4,1). If the curve is smooth at (4,1), (that is differentiable at (4,1)), find the equation of the circle who arc fomrs the path after (4,1)
Radius of Curvature: 1/K
##R= \frac{(1+(y')^{2})^{3/2}}{y''}##
I basically used the equation for radius of curvature to find what the radius of the circle would be.
First I derive the original equation to get: y'=##\frac{5}{64}x^{\frac{2}{3}}##
and then y''= ##\frac{10}{192}x^{\frac{-1}{3}}##
I then put these into the Radius of Curvature equation and got:
##R= \frac{(1+(\frac{5}{64}x^{\frac{2}{3}})^{2})^{3/2}}{\frac{10}{192}x^{\frac{-1}{3}}}##
The value that they said they were viewing the curve at was x=4. So I evaluate the equation I made at x=4.
The value I end up with is 32.24 for the radius.
This is where I run into trouble. Trying to find the equation of this circle perplexes me.
I realize because the point we looked at was x=4 so I should shift the circle right that many units. I know that the circle should be tangent to the line ##y=\frac{1}{32}x^{\frac{5}{2}}##. So I believe it should be shift up 1+R. I come up with the equation (x-4)^2+(y-32.24)^2=1039.4176. Graphing this with the original line gives something that looks nothing like what I expect. the circle is definitely not tangent to the curve so I am wondering where I went wrong.
