Curvature of space and spacetime
In summary: However, if the space-time is in a moving frame of reference, then it is not time translation invariant.
qtm912
38
i am trying to understand the relationship between the two on a local and global scale and how these two concepts are related to the Ricci scalar.
Is it correct to say that as far as we know on a global scale, spacetime is flat so that the Ricci scalar is zero. If so, what can be said about the curvature of space alone at a global level, is it also flat?
Locally my understanding is that spacetime may be curved due to the presence of massive bodies. In this case is it true to say that both space as well as space time is curved near these bodies? I would assume than the nature of the curvature would depend on the form of the metric that applies locally.
Finally, my understanding is that the Ricci tensor and scalar is applicable to spacetime. (is this true?) If so is there an analagous concept in relation to space alone, if that means anything.
Are any of the above related to the choice of coordinates? I would have thought not as choice of coordinates should not change the physical reality.
If space-time is flat then the Ricci scalar vanishes. The converse however doesn't hold.
No. Also keep in mind that the concepts of "space" and "space curvature" have no unambiguous meaning in GR: there are many different ways to slice up space-time into surfaces representing "space at a given instant of time" and these correspond usually to the different ways distinct families of observers perceive "space at a given instant of time".
In general yes. Keep in mind that space-time may be curved due to any stress-energy-momentum source, not just massive bodies.
Yes to both questions. One just goes from the Lorentzian signature to the usual signature.
No.
Likes 1 person
If by "spacetime" you mean the actual spacetime of our universe, no, this is not correct. The spacetime of the universe is not flat. See below.
Our best current models indicate that the universe is spatially flat--more correctly, spacelike hypersurfaces in which the universe appears homogeneous and isotropic are flat. As WannabeNewton pointed out, whether "space" is flat depends on how you divide up spacetime into space and time.
The reason spacetime is not flat, even though we can cut flat spatial slices out of it, is that spacetime includes time, and the universe is changing in time: it is expanding.
Likes 1 person
Changing over time is usally called "not static". But how does this imply "not flat"?
It's got a nonzero mass density, hence a nonzero Ricci tensor. However it is conformally flat. (Easy to see this just by symmetry)
Just a small clarification: a space-time can be non-static but still be time translation invariant as long as it is stationary.
Related to Curvature of space and spacetime
What is the curvature of space and spacetime?
The curvature of space and spacetime is a concept in physics that describes the bending or warping of space and time due to the presence of massive objects, such as planets, stars, or even galaxies. It is a fundamental aspect of Einstein's theory of general relativity and has been confirmed through various experiments and observations.
How is the curvature of space and spacetime measured?
The curvature of space and spacetime is measured by calculating the curvature tensor, which is a mathematical object that describes the curvature of a particular point in space and time. This is done using mathematical equations derived from Einstein's field equations, which relate the curvature of space and time to the distribution of matter and energy.
What is the significance of the curvature of space and spacetime?
The curvature of space and spacetime is significant because it explains how gravity works. According to general relativity, massive objects create a curvature in spacetime, and this curvature is what we experience as the force of gravity. It also predicts the behavior of objects in the presence of massive bodies, such as the bending of light around a massive object like a star.
Can the curvature of space and spacetime be observed?
Yes, the curvature of space and spacetime can be observed through various phenomena, such as the gravitational lensing of light and the precession of the orbit of Mercury. It has also been confirmed through precise measurements of the orbit of binary pulsars, which have provided strong evidence for the existence of gravitational waves.
Does the curvature of space and spacetime affect the motion of objects?
Yes, the curvature of space and spacetime affects the motion of objects by altering their trajectories. In the presence of a massive object, the curvature of spacetime causes objects to follow curved paths, which we experience as the force of gravity. This is why objects in freefall, such as planets orbiting a star, follow curved trajectories instead of straight lines.
