Curve C is the Common denominator of two surface
In summary, the problem is that there is no single intersection curve between the surfaces s1: z= xy and s2: x^2+ y^2- z^2= 1 at the point (1, 1, 1). This is because the two surfaces are parallel at that point, meaning their normal vectors are parallel and there is no unique tangent vector. Additionally, when trying to find the intersection curve, there is no solution because y= 1- x^2, meaning there are multiple values for y at a given x.
imana41
36
hi please help about this:
Curve C is the Common denominator of two surface s1:z=xy and s2:x^2+y^2-z^2=1 find Tangent vector on curve C in dot p(1,1,1) ?
i think Tangent vector on curve C is External Multiply of gradient s1 and s2 in (1,1,1)
but i get it
begin{vmatrix}%20i%20&%20j%20&%20k\\%202%20&%202%20&%20-2\\%201%20&%201%20&%20-1%20\end{vmatrix}.gif
=(0,0,0)
[URL]http://latex.codecogs.com/gif.latex?\bigtriangledown%20s1=(2x,2y,-2z)[/URL]
[URL]http://latex.codecogs.com/gif.latex?\bigtriangledown%20s2=(y,x,-1)[/URL]
what is my problem ?? please help
You mean "intersection" not "common denominator". Also you mean "at point p(1,1,1)" not "dot p(1,1,1)".
You have s1 and s2 reversed but yes, (2x, 2y, -2z) is normal to s2 and (y, x, -1) is normal to s1. At the given point, (1, 1, 1) those are (2, 2, -2) and (1, 1, -1). But notice that (2, 2, -2)= 2(1, 1, -1) which means the two normal vectors are parallel and the two surfaces are parallel at that point. There is no single curve of intersection at that point.
Look what happens when you try to find that curve: since z= xy, [itex]x^2+ y^2- z^2= x^2+ y^2- x^2y^2= 1[/itex]. Then [itex]y^2- x^2y^2= 1- x^2[/itex], [itex]y^2(1- x^2)= 1- x^2[/itex] so that for any x except 1 or -1, y= 1- again there is no single intersection curve.
Related to Curve C is the Common denominator of two surface
1. What is a common denominator?
A common denominator is a number that can be divided evenly by all the denominators in a given set of fractions. It is the smallest number that can be used as a common base for the fractions.
2. How is a common denominator used in math?
In math, a common denominator is used to simplify fractions and make them easier to compare and perform operations on. It is also used to find equivalent fractions by making sure they have the same denominator.
3. How does curve C act as the common denominator of two surfaces?
Curve C acts as the common denominator of two surfaces by intersecting both surfaces at the same point, creating a common point of reference for both surfaces. This allows for easier comparison and analysis of the two surfaces.
4. What is the significance of finding the common denominator of two surfaces?
Finding the common denominator of two surfaces is significant because it allows for a better understanding of the relationship between the two surfaces. It also helps in finding the points of intersection and determining the overall shape of the surfaces.
5. Can there be more than one common denominator for two surfaces?
Yes, there can be more than one common denominator for two surfaces. This occurs when the surfaces have multiple points of intersection or when the surfaces have different degrees of complexity that require different common denominators.
