- #36
Drakkith
Mentor
- 23,022
- 7,410
Joseph Chikva said:• Bending magnetic field does not required energy for bending if not considering synchrotron radiation but this is not that case.
Bending? Just generating the field takes power. Same with the electric fields.
• Elastic collisions causing scatterings also will accelerate slower moving ions decelerating faster moving ions. Ions energy losses occur only via transferring the little part of gained via scattering before ion will return to right direction.
Again, I am not referring solely to energy losses from the ions, but also to the increased time it takes for each ion to fuse because of these collisions.
This is not you lovely Polywell in which scattered ion does not return back then scattered again and again. And so all energy losses for fusion.
Provide me with some evidence that your device will cause ALL scattered ions to return.
• Concept can provide near 100% particles the fusing capability. But for that infinitely long confinement duration is required. But 80 % fusion will occur during acceptable time.
I see absolutely nothing that says that. You haven't provided any estimated time, you haven't calculated used power for that period of time, and you don't seem to understand the basics of the Fusion Gain Factor or the cross section. In fact, this entire thread tells me that you seriously need to go back and look at your device. I'm done wasting my time here.
