Cylinder parallel to a constant external B field
In summary, the strength and direction of the magnetic field inside a cylinder of permeability ##\mu## placed in an external field ##B_0## can be determined by solving the Laplace equation with the boundary condition that the tangential component of the magnetic field is continuous at the surface of the cylinder. For part a, when the axis of the cylinder is parallel to the external field, the Laplace equation reduces to $$\frac{1}{\rho}\frac{\partial}{\partial{\rho}}(\rho \frac{\partial \phi}{\partial{\rho}})+\frac{\partial^2\phi}{\partial z^2}=0$$ and the boundary condition helps determine the first-order term in ##z##
sayebms
33
A cylinder of permeability ##\mu## is placed in an external field ##B_0##. find the strength and direction of magnetic field inside the cylinder for:
a) when axis of cylinder is parallel to external field.
b) when axis of cylinder makes an angle ##\theta _0## with external field.
Conditions of magneto statics:$$\nabla \times H =0\\H=-\nabla{\phi}\\\nabla^2{\phi}=0$$
the Laplace operator is in cylindrical coordinates
for part a I take B to be in x direction. its clear from the problem that there is a symmetry in the ##\phi## direction so this means that the magnetic scalar potential does not depend on ##\phi##. hence the Laplace equation reduces to $$\frac{1}{\rho}\frac{\partial}{\partial{\rho}}(\rho \frac{\partial \phi}{\partial{\rho}})+\frac{\partial^2\phi}{\partial z^2}=0$$ but here is the problem; I know that the magnetic field outside and far from cylinder must be a constant (##B_0##) which means that potential must have a term first order in ##z## but as we see from the Laplace equation we don't get such a thing. what am I doing wrong here? is this even the right approach for solving this problem? [/B]
Your approach is correct, but you are missing a boundary condition. In order to determine the magnetic scalar potential, you need to specify the boundary conditions at the surface of the cylinder. In this case, the boundary condition is that the tangential component of the magnetic field (i.e. the component parallel to the surface of the cylinder) must be continuous across the surface. This means that the magnetic scalar potential must satisfy the equation $$\frac{\partial \phi}{\partial z}\bigg|_{z=0} = \frac{\partial \phi}{\partial z}\bigg|_{z=h}$$ where ##h## is the height of the cylinder. This condition will help you determine the first-order term in ##z## that you are missing. Once you have that, you can solve the Laplace equation to find the magnetic scalar potential and then use it to determine the magnetic field inside the cylinder.
Related to Cylinder parallel to a constant external B field
1. What is a cylinder parallel to a constant external B field?
A cylinder parallel to a constant external B field refers to a cylindrical object that is placed in a magnetic field where the field lines are parallel to the axis of the cylinder. This means that the magnetic field has the same direction and magnitude at all points along the length of the cylinder.
2. How does a cylinder behave when placed in a constant external B field?
When placed in a constant external B field, a cylinder will experience a torque that causes it to align itself with the direction of the magnetic field. The cylinder will rotate until its axis is parallel to the field lines of the external B field.
3. What is the effect of increasing the strength of the external B field on a cylinder?
The stronger the external B field, the stronger the torque on the cylinder. This means that the cylinder will rotate more quickly and align itself with the field lines at a faster rate.
4. Can a cylinder parallel to a constant external B field move in a different direction?
No, a cylinder parallel to a constant external B field will always align itself with the magnetic field lines. It will not move in any other direction, as the torque will always cause it to rotate and align with the field.
5. How is a cylinder parallel to a constant external B field used in scientific experiments?
A cylinder parallel to a constant external B field can be used to study the behavior of magnetic materials in different environments. It is also used in devices such as compasses and motors, where the alignment of the cylinder with the magnetic field is essential for their functioning.
