Cylinder rolling down a wedge - wedge should not slip
In summary, the least value of the coefficient of friction between the inclined plane and the horizontal ground is if the slope doesn't slip.
Saitama
4,243
93
The height of the slope shown in the figure is 30 cm, and its base is 40 cm. A solid cylinder of uniform density, which has the same mass as the slope, rolls down along the slope without slipping. What is the least value of the coefficient of friction between the inclined plane and the horizontal ground if the slope does not slip?
I understand that this is a simple problem but I cannot reach the specified answer though I did a similar problem recently.
The forces acting on the wedge are the normal reaction from cylinder (N), normal reaction from ground (N'), weight (mg) and the frictional force (f).
Balancing forces on the wedge in the vertical direction:
$$N'=mg+N\cos\theta$$
where ##\theta## is the angle made by the slope with the horizontal.
Since the wedge doesn't slip,
$$f \geq N\sin\theta \Rightarrow \mu N' \geq N\sin\theta$$
Using ##N=mg\cos\theta## and solving the equations, I don't get the right answer.
Any help is appreciated. Thanks!
How many friction forces act on the wedge?
Likes 1 person
The cylinder has to spin up as it rolls down without slipping, which means there is some torque on it, which is provided by a force. By Newton's third law, the wedge will experience the opposite force.
Likes 1 person
Silly me, thanks a lot both of you! :)
Your approach to this problem is correct. It seems that there may be an error in your calculations. Here is a step-by-step solution:
1. Draw a free body diagram of the wedge to identify the forces acting on it.
2. Apply Newton's second law in the horizontal and vertical directions separately to find the normal reactions N and N'.
3. Use the condition for no slipping, which states that the friction force f must be greater than or equal to the component of the weight of the cylinder along the slope, which is mgsinθ.
4. Substitute the expression for N found in step 2 into the inequality from step 3.
5. Simplify the inequality and solve for the coefficient of friction μ.
If you follow these steps, you should arrive at the correct answer. Remember to double check your calculations to ensure accuracy. Keep up the good work!
Related to Cylinder rolling down a wedge - wedge should not slip
1. How does the wedge prevent the cylinder from slipping?
The wedge creates a frictional force that acts on the cylinder, preventing it from slipping down the wedge. This frictional force opposes the motion of the cylinder and keeps it in place.
2. What factors affect the stability of the cylinder rolling down the wedge?
The stability of the cylinder depends on several factors, including the angle of the wedge, the mass of the cylinder, and the coefficient of friction between the wedge and the cylinder. A larger angle, higher mass, and lower coefficient of friction will result in a more stable cylinder.
3. Can the wedge slip even if the cylinder does not?
Yes, it is possible for the wedge to slip even if the cylinder does not. This can occur if the frictional force between the wedge and the ground is not strong enough to prevent the wedge from moving. In this case, the wedge will slide down the surface rather than the cylinder rolling down it.
4. What is the relationship between the height of the wedge and the distance the cylinder rolls?
The height of the wedge and the distance the cylinder rolls are directly proportional. This means that as the height of the wedge increases, the distance the cylinder rolls also increases. This relationship is based on the principle of conservation of energy, where the potential energy of the wedge is converted into kinetic energy as the cylinder rolls down.
5. How does the shape of the wedge affect the motion of the cylinder?
The shape of the wedge can significantly impact the motion of the cylinder. A wider and flatter wedge will result in a slower and more stable motion, while a narrower and steeper wedge will cause the cylinder to roll faster and potentially slip. This is because the angle of the wedge determines the amount of frictional force acting on the cylinder.
