Cylinder with piston separating two sections containing two gases.
In summary, the gases in the cylinder reach equilibrium at 300K and 20bar. The pressure and temperature are the same in both compartments.
sploder
A closed, insulated cylinder is divided into two equal parts by a piston. One compartment contains Nitrogen at T=300K, P1=5bar, the other Carbon Dioxide at T=300K, P2=20bar. The cylinder contents then reach mechanical and thermal equilibrium.
1. Assuming that the gases can be treated as ideal gases with heat capacities at constant volume of 5R/2 and 7R/2, obtain the final temperature and pressure.
2. Obtain the final temperature and pressure using accurate thermodynamic properties for N2 and C02
PV=nRT
ΔU=Q-W
Q=Uf-Ui
Ui=m1u(T1)+m2u(T2)
Uf=(m1+m2)u(Tf)
1. Usually for problems like this the first thing you do is find the mass. Since volume is not given, I'm not sure how to even start this problem.
Well, then all you can do is use a symbol, for example V, and express the mass (if needed at all) in V and the other variables. They do tell you, however, that the two volumes are equal...
If the system reaches thermal and mechanical equilibrium, how do the temperatures and pressures in the two compartments compare at final equilibrium?
How much work do the two gases in the rigid container do on the surrounding environment outside the rigid container?
How much heat is transferred from the two gases inside the insulated container to or from the surrounding environment outside the container?
What is the change in total internal energy for the combination of the two gases inside the container?
Can you write an equation for this combined change in internal energy in terms of the number of moles in each compartment, the heat capacity of the gas in each compartment, and the initial and final temperatures in the compartments?
What is the final temperature?
If the container is rigid, how does the total volume of the two compartments compare between the initial and final equilibrium states?
How does the number of moles of gas in each of the two compartments change between the initial and final equilibrium states?
Chet
Related to Cylinder with piston separating two sections containing two gases.
1. What is a cylinder with piston separating two sections containing two gases?
A cylinder with piston separating two sections containing two gases is a scientific apparatus used to study the properties and behaviors of gases. It consists of a cylindrical container with a movable piston that divides the container into two sections, each containing a different gas.
2. How does a cylinder with piston separating two sections containing two gases work?
The two gases in the cylinder will be in separate sections, with the piston acting as a barrier between them. As the piston moves, the volume of each gas will change, allowing for the study of gas behavior under different pressures and volumes.
3. What is the purpose of using a cylinder with piston separating two sections containing two gases?
The purpose of using this apparatus is to study the properties of gases, such as how they behave under different pressures, volumes, and temperatures. This can provide valuable insights into the physical and chemical properties of gases and their practical applications.
4. Can any two gases be used in a cylinder with piston separating two sections?
Yes, any two gases can be used in this apparatus. However, it is important to consider the properties of the gases being used, such as their reactivity and compatibility, to ensure accurate and safe experimentation.
5. Are there any limitations to using a cylinder with piston separating two sections containing two gases?
One limitation is that the gases must be able to be contained in a cylinder and not react with the materials of the apparatus. Additionally, the temperature and pressure conditions inside the cylinder may not perfectly simulate real-world conditions, so results should be interpreted with caution.
9K
