I Cylindrical coordinates -Curvilinear
chwala
TL;DR Summary
Why are the coordinates seemingly used when the symmetry is around ##z## axis? Any particular reason why not ##x## or ##y##. In transforming from Cartesian to cylindrical form; I can see that ##z## is not considered when determining ##r##.
Can we also use ##x## and ##z## assuming that the symmetry is about ##y##? Sorry using phone to type ...will put this into context later. I hope my query is clear enough.
The directions of the cartesian axes in space are not absolute, but can be chosen to fit the geometry of the particular problem; by convention in axisymmetric geometries the z-axis is placed on the axis of symmetry, giving an obvious extension of plane polar coordinates (x,y) = (r \cos \theta, r \sin \theta).
It is clearly possible to set \begin{split}<br /> x &amp;= w \\<br /> y &amp;= u \cos v \\<br /> z &amp;= u \sin v\end{split}<br /> or \begin{split}<br /> x &amp;= u \sin v \\<br /> y &amp;= w \\<br /> z &amp;= u \cos v \end{split} if you want.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
