nope,they form a special covalent bond called coordinate covalent bond with cn- and d-d transition happens within a transition metal or ion only.d-d transition doesn't happen between two atoms especially not with c.DrDu said:The d-orbitals form a covalent 2-electron bond with the sp hybrid orbitals on C. So in each bond there are 2 orbitals involved which can take up up to 4 electrons.
but there can only be two electrons in an hybridized orbitalDrDu said:The dative bond looks like ## \mathrm{Fe \quad C \uparrow\downarrow \longleftrightarrow Fe \uparrow \quad C\downarrow \longleftrightarrow Fe \downarrow \quad C \uparrow }##.
If you excite a d electron into that bond, you get a weaker 3 electron bond ## \mathrm{Fe\uparrow \quad C \uparrow\downarrow \longleftrightarrow Fe \uparrow \downarrow \quad C\uparrow } ##.
A D-d transition mechanism refers to the process in which an electron in a transition metal ion moves from one d-orbital to another. This movement of electrons can lead to the absorption or emission of light, resulting in the characteristic colors of transition metal compounds.
D-d transitions occur due to the energy differences between the d-orbitals of transition metal ions. When an electron is excited to a higher energy level, it can absorb a photon of light and transition to a different d-orbital. This results in the characteristic color of the compound.
The color of transition metal compounds is a result of the D-d transition mechanism. When electrons in the d-orbitals are excited, they can absorb certain wavelengths of light, giving the compound its characteristic color. Different transition metals have different energy levels and therefore, different colors.
The intensity of D-d transitions is affected by several factors, including the transition metal ion's oxidation state, coordination number, and ligand type. These factors determine the energy differences between the d-orbitals and therefore, the absorption or emission of light.
D-d transitions are useful in spectroscopy because they provide information about the electronic structure of transition metal compounds. The absorption or emission of light can be measured and used to identify the type of transition metal present and its coordination environment. This is particularly useful in identifying unknown compounds or studying the effects of different ligands on transition metal complexes.
