Daily output of NO from power plant.
In summary: I need to get this for a homework.In summary, Homework Statement:If a power plant burning 10,000 metric tons of coal per day with 10% excess air emits stack gas containing 100 ppm by volume of NO, what is the daily output of NO?
eddzzz_2011
Homework Statement :
Q.If a power plant burning 10,000 metric tons of coal per day with 10% excess air emits stack gas containing 100 ppm by volume of NO, what is the daily output of NO? (Assume coal is pure C).
The attempt at a solution:
A. C + O2 → CO2
(10000 metric tons of C) / 12.0108 g/mol x (1/1) x (44.0096 g/mol) x (100/ 1000000) = 3.66 metric tons of NO
Please can someone check this is correct for me. If incorrect please show me. Thanks,
Ed
- You forgot the 10% excess air
- the atmosphere is only 21% oxigen (by volume)
- you calculated 100 ppm by weight and not by volume
start with calculating how many moles of C are present. You can then compute
how many moles of NO are present without using the weight of anything, and then
finally compute the weight of the NO.
Moles of C present:
10,000 / 12.0108 = 832.58 moles of coal. (do i need to convert 10,000 metric tons into grams? Other than that I have no clue what to do with the 100ppm by the volume. Please show me the working out to receive the correct answer then I can go through it and understand better. Thanks
eddzzz_2011 said:
Moles of C present:
Yes, 1 mole of carbon is 12.0108 g,and not 12.0108 metric tons.
the volume of 1 mole is the same for all the gases, so if 100 ppm by volume is NO, there's one 1 mole of NO, for every 10000 moles of gas coming out of the pipe.
you need to add a volume of air that contains enough oxygen to react with the coal. Air is 21% oxygen by volume, so you need 100 moles of air to get 21 moles of oxygen and then you need 10% extra air.
10,000 metric tons = 10 000 000 000 grams. (1.0 * 10^10)
1 mole of C = 832.58 moles
1 mole of NO = 832.58 moles
So the equation would be:
(1.0*10^10 grams of C) / 12.0108 g/mol x (1/1) x (44.0096 g/mol) x (100/ 10000) = 366416891.5 grams of NO?? Sorry I really don't understand this one
don't try to write everyting in one equation, that way I don't understand it either.
there are 10^10 / 12.0108 = 8.33 *10^8 moles of C present.
these need 8.33 *10^8 moles of oxygen to burn
1 mole of air contains 0.21 moles of oxygen so
... moles of air contain 8.33 *10^8 moles of oxygen
there's 10% extra air, so you need .... moles
100/1000000 parts of the exhaust is NO, so this is ... moles, which weigh ... g, so you get ... kg of NO
Yeah shouldn't of put it in that way. Ill put it in a clearer way in future.
3.9*10^9 moles of air contain 8.33 *10^8 moles of oxygen
there's 10% extra air, so you need 3.57*10^9 moles
100/1000000 parts of the exhaust is NO, so this is 3.57*10^5 moles,
which weigh 10713570g, so you get 10713.570 kg of NO.
Ignore post above (wrong)
3.9*10^9 moles of air contain 8.19*10^8 moles of oxygen
there's 10% extra air, so you need 1.209*10^9 moles
100/1000000 parts of the exhaust is NO, so this is 1.209*10^5 moles,
which weigh 3.638*10^6g, so you get 3628kg of NO. Willem2 please check :)
Assume air is 21% O2 and is at STP (273 K, 1.00 atm)
From the stoichiometry of the reaction C + 02 --> CO2 the mass of 02 needed is given by:
Mass O2 = 10,000 tonne x (32 tonne O2/ 12 tonne C) 2.67 x 10^4 tonne O2
Stoichiometric mass air 2.67 x 10^4 tonne/0.21 = 1.27 x 10^5 tonne air 1.27 x 10^11 g air, To account for 10% excess air:
Mass air = 1.27 x 10^5 tonne x 1.10 = 1.40 x 10^5 tonne air 1.40 x 10^11 g air
Using 1.29 g/L for the density of air, its volume is given by
V 1.40 X 10^11 g/1.29 g/L = 1.09 x 10^11 L
Mol air = 1.09 x 10^11 L/(22.4 L/mol) = 4.84 x 10^9 mol air
At 100 ppm NO, the mol fraction of NO is 1.00 x 10^-4
Mol NO = 1.00 x 10^-4 mol NO/mol air x 4.84 x 10^9 mol air = 4.84 x 10^5 mol NO
Mass NO = 4.84 x 10^5 mol NO x 30.0 g NO/mol NO = 1.45 x 10^7 g NO
The daily output of NO is 14.5 tonne/day.
This seems an easier way.
Could anyone check please.
Related to Daily output of NO from power plant.
1. What is the daily output of NO from a power plant?
The daily output of NO from a power plant varies depending on the type of power plant and its operating conditions. However, on average, a coal-fired power plant can emit around 200-250 tons of NO per day.
2. How is the daily output of NO from a power plant measured?
The daily output of NO from a power plant is measured using continuous emissions monitoring systems (CEMS). These systems use advanced technology to continuously measure and record the amount of NO emitted from the power plant.
3. What factors can affect the daily output of NO from a power plant?
The daily output of NO from a power plant can be affected by various factors such as the type of fuel used, the efficiency of the plant, the age of the plant, and the type of emission control technology installed. Weather conditions and plant maintenance can also have an impact on the daily output of NO.
4. How does the daily output of NO from a power plant affect the environment?
The daily output of NO from a power plant contributes to air pollution and can have harmful effects on the environment and human health. NO reacts with other pollutants in the atmosphere to form smog and acid rain, which can damage crops, forests, and aquatic ecosystems.
5. What measures are being taken to reduce the daily output of NO from power plants?
Power plants are required to comply with emission regulations set by the government, which includes limits on the amount of NO that can be emitted. Many power plants also use advanced emission control technologies, such as selective catalytic reduction, to reduce the amount of NO released into the atmosphere. Additionally, there is a shift towards renewable energy sources, which do not emit NO, to reduce the overall output of NO from power plants.
