D'Alembert equation and Galilean transformation
In summary: A perfect solid has no boundaries and the wave equation is invariant. But, when you start making cuts into a solid, the wave equation ceases to be invariant.
Francescob
The D'Alembert equation for the mechanical waves was written in 1750. It is not invariant under a Galilean transformation.
Why nobody was shocked about this at the time? Why we had to wait more than a hundred years (Maxwell's equations) to discover that Galilean transformations are wrong? Couldn't we see that they wrong already by looking at the D'Alembert equation for the mechanical waves?
Am I missig something?
Thanks,
F.
Thanks,
F.
D'Alembert's equation for sound waves through air is only valid in the rest frame of the air. If you are moving relative to the air, then the equation as described in your rest frame is modified. It was assumed that Maxwell's equations were similarly modified if you are moving relative to the rest frame of whatever medium electromagnetic waves propagate through.
If you consider mechanical waves in a medium, there is nothing strange with the wave equation not satisfying Galilei invariance because the presence of the medium itself violates it. There is really nothing to be upset about in that respect, e.g., sound waves carried by air travel at different velocities to you depending on your motion relative to the medium and this can be confirmed by experiment.
The new thing in relativity is that there seemingly was no medium and the speed of light turned out to be invariant and the same regardless of the state of motion of the observer. There is now no medium to break Galilei invariance.
Likes PeroK
Maybe, it is worth to mention that exact dynamical equations for media, say, continuity and Euler ones, are invariant under Galilean transformations. D'Alembert equation for sound waves is just approximation for small perturbations of homogeneous non-moving background. It is background, not physical laws themselves, which makes wave equation non-invariant.
The same is true for solids.
Related to D'Alembert equation and Galilean transformation
1. What is the D'Alembert equation?
The D'Alembert equation, also known as the wave equation, is a partial differential equation that describes the behavior of waves in a medium. It relates the second partial derivatives of a function to its first partial derivative with respect to time.
2. What is the significance of the D'Alembert equation in physics?
The D'Alembert equation is significant in physics because it is used to describe a wide range of wave phenomena, such as sound, light, and water waves. It is also a fundamental equation in classical mechanics and is closely related to the principle of least action.
3. How does the Galilean transformation relate to the D'Alembert equation?
The Galilean transformation is a mathematical tool used to relate the coordinates of an event in one inertial reference frame to another inertial reference frame. It is closely related to the D'Alembert equation because it allows us to transform the wave equation from one reference frame to another, which is essential in studying the motion of waves in different frames of reference.
4. Can the D'Alembert equation and Galilean transformation be applied to all types of waves?
Yes, the D'Alembert equation and Galilean transformation can be applied to all types of waves, as long as they are linear and follow the principle of superposition. This includes electromagnetic waves, acoustic waves, and even quantum mechanical waves.
5. Are there any limitations to the use of the D'Alembert equation and Galilean transformation?
While the D'Alembert equation and Galilean transformation are powerful tools in studying waves, they do have limitations. They are only valid for linear waves in an ideal, homogeneous medium, and do not take into account factors such as dispersion, absorption, and nonlinearity. In some cases, more complex equations and transformations may be necessary to accurately describe wave behavior.
9K
