D'Alembert Problem for 1-D wave equation
In summary, to find u(t, x) for all t, x ≥ 0 for the given conditions, we use the d’Alembert solution and the boundary condition to solve for t and then plug it back into the expression.
rexasaurus
For the 1-D wave equation, the d’Alembert solution is u(t, x) = f (x + ct) + g(x − ct) where f , g are each a function of 1 variable.
Suppose c = 1 and we know f (x) = x^2 and g(x) = cos 2x for x > 0.
Find u(t, x) for al l t, x ≥ 0 if you are also given the BC: u ≡ 1 at x = 0, all t.
2. See problem statement
3.
Do we simply "plug" into the D'alembert solution?
I started with:
so: f(x)=x^2 or f(x)=(x+t)^2
so: g(x)=cos2x or g(x)=cos(2x-2t)
next: plug f(x), g(x) into u(t,x)
u(t,x)=x2+2xt+t2+cos(2x-2t)
Is this all that needs to be done? I am not sure where to go from here or what to do with the BC of u(t,0)=1. Please help.
Thank you.Yes, the next step is to use the boundary condition to solve for t. Since u(t, 0) = 1, we have:1 = x^2 + 2xt + t^2 + cos(2x - 2t)This is a quadratic equation in t that can be solved for t. Once you have the value of t, you can plug it back into the original expression for u(t, x).
Related to D'Alembert Problem for 1-D wave equation
What is the D'Alembert Problem for 1-D wave equation?
The D'Alembert Problem for 1-D wave equation is a mathematical problem that involves finding a solution to the 1-D wave equation with specific initial and boundary conditions. It is named after the French mathematician Jean le Rond d'Alembert.
What is the 1-D wave equation?
The 1-D wave equation is a partial differential equation that describes the behavior of waves propagating in one dimension. It is often used in physics and engineering to model various phenomena such as sound, light, and water waves.
What are the initial conditions for the D'Alembert Problem?
The initial conditions for the D'Alembert Problem include the initial position and velocity of the wave at a given time. These conditions are used to determine the solution of the 1-D wave equation at any point in time.
What are the boundary conditions for the D'Alembert Problem?
The boundary conditions for the D'Alembert Problem specify the behavior of the wave at the boundaries of the domain. These conditions are essential for finding a unique solution to the problem.
What are some applications of the D'Alembert Problem for 1-D wave equation?
The D'Alembert Problem has many applications in physics and engineering, including the study of sound and vibrations, electromagnetic waves, and fluid dynamics. It is also used in the field of signal processing for analyzing and manipulating signals.
