D'Alembert's Solution to wave equation
In summary, changing the variables ## \alpha = x + at , \quad \beta = x - at ## in the differential equation $$ a^2 \frac{ \partial ^2 y}{ \partial x^2 } = \frac{ \partial ^2 y} {\partial t ^2} $$ results in the simplified equation $$ \frac{ \partial ^2 y}{\partial \alpha \partial \beta } = 0$$. The proof involves using the fact that $$ \frac{ \partial \alpha}{\partial t} = a, \quad \frac{\partial \beta}{\partial t} = -a$$ and treating everything as a fraction in the wave equation.
pierce15
315
Hello,
How does the change of variables ## \alpha = x + at , \quad \beta = x - at ## change the differential equation
to
? I'm having a hard time following the proofs on wolfram alpha, etc
I think I've got it, although I don't think this is a legitimate proof:
$$ \frac{ \partial \alpha}{\partial t} = a, \quad \frac{\partial \beta}{\partial t} = -a \implies \frac{1}{-a^2} \frac{ \partial \alpha \partial \beta}{\partial t^2 } = 1 $$
By the same logic,
$$ \frac{ \partial \alpha \partial \beta}{ \partial x^2} = 1$$
From the wave equation:
$$ a^2 \frac{ \partial ^2 y}{\partial x^2} \frac{\partial x^2}{\partial \alpha \partial \beta } = \frac{ \partial ^2 y}{\partial t^2} \frac{\partial t^2}{\partial \alpha \partial \beta} (-a^2) $$
$$ \implies \frac{ \partial ^2 y}{\partial \alpha \partial \beta } = 0 $$
Is that OK? It's cool to just treat everything like a fraction?
Related to D'Alembert's Solution to wave equation
What is D'Alembert's solution to the wave equation?
D'Alembert's solution is a mathematical formula used to solve the wave equation, which describes the behavior of waves in a given medium. It is named after the French mathematician Jean le Rond d'Alembert who first introduced it in the 18th century.
What is the wave equation?
The wave equation is a partial differential equation that describes the propagation of waves in a medium. It relates the spatiotemporal variations of a wave with its frequency, wavelength, and speed of propagation.
How does D'Alembert's solution work?
D'Alembert's solution involves breaking down the wave equation into two simpler equations, one for the wave's amplitude and one for its velocity. These equations can then be solved using standard mathematical techniques to find the solution for the wave at any point in time and space.
What are the limitations of D'Alembert's solution?
D'Alembert's solution assumes that the medium in which the wave is propagating is uniform and linear, meaning that the wave's amplitude and speed do not change with time or distance. This may not always be the case in real-world situations, so the solution may not accurately describe the behavior of waves in all scenarios.
What are some real-world applications of D'Alembert's solution?
D'Alembert's solution has been used in various fields, including acoustics, electromagnetics, and fluid dynamics. It has practical applications in the design of musical instruments, prediction of earthquake motion, and understanding the behavior of sound and light waves.
  • Differential Equations
