MHB Dale's questions via Facebook about Riemann Sums
The discussion focuses on calculating Riemann sums and their associated errors for a function defined over a specified interval. The calculations demonstrate that with a given width of rectangles, the area approximated using Riemann sums results in a value of 66/25 units², while the exact area calculated through integration is 8/3 units². The error between these two values is found to be -2/75, leading to a percentage error of -1%. Additionally, for a cubic function, the approximation using 100 rectangles yields a very small percentage error of 0.005%, indicating high accuracy. The thread emphasizes the relationship between Riemann sums and definite integrals in estimating areas under curves.
Prove It
MHB
(a) Since a = 2, that means $\displaystyle \begin{align*} \Delta x = \frac{2}{5} \end{align*}$
(b)
$\displaystyle \begin{align*} f \left( \frac{7\,\Delta x}{2} \right) &= f \left( \frac{7}{5} \right) \\ &= \left( \frac{7}{5} \right) ^2 \\ &= \frac{49}{25} \end{align*}$
(c)
$\displaystyle \begin{align*} A_4 &= f \left( \frac{7}{5} \right) \cdot \Delta x \\ &= \frac{49}{25} \cdot \frac{2}{5} \\ &= \frac{98}{125} \,\textrm{units}^2 \end{align*}$
(d)
$\displaystyle \begin{align*} A_i &= f \left( x_i \right) \cdot \Delta x \end{align*}$
(e)
$\displaystyle \begin{align*} S_5 &= \sum_{i = 1}^5{ \left[ f \left( x_i \right) \cdot \Delta x \right] } \\ &= f \left( x_1 \right) \cdot \Delta x + f \left( x_2 \right) \cdot \Delta x + f \left( x_3 \right) \cdot \Delta x + f \left( x_4 \right) \cdot \Delta x + f \left( x_5 \right) \cdot \Delta x \\ &= \left( \frac{1}{5} \right) ^2 \cdot \frac{2}{5} + \left( \frac{3}{5} \right) ^2 \cdot \frac{2}{5} + \left( \frac{5}{5} \right) ^2 \cdot \frac{2}{5} + \left( \frac{7}{5} \right) ^2 \cdot \frac{2}{5} + \left( \frac{9}{5} \right) ^2 \cdot \frac{2}{5} \\ &= \frac{1}{25} \cdot \frac{2}{5} + \frac{9}{25} \cdot \frac{2}{5} + \frac{25}{25} \cdot \frac{2}{5} + \frac{49}{25} \cdot \frac{2}{5} + \frac{81}{25} \cdot \frac{2}{5} \\ &= \frac{2}{125} + \frac{18}{125} + \frac{50}{125} + \frac{98}{125} + \frac{162}{125} \\ &= \frac{330}{125} \\ &= \frac{66}{25} \,\textrm{units}^2 \end{align*}$
(f)
$\displaystyle \begin{align*} A &= \int_0^a{f\left( x \right) \,\mathrm{d}x} \\ &= \int_0^2{ x^2\,\mathrm{d}x } \\ &= \left[ \frac{x^3}{3} \right] _0^2 \\ &= \frac{2^3}{3} - \frac{0^3}{3} \\ &= \frac{8}{3} \,\textrm{units}^2 \end{align*}$
(g)
$\displaystyle \begin{align*} \textrm{Error} &= \frac{66}{25} - \frac{8}{3} \\ &= \frac{198}{75} - \frac{200}{75} \\ &= -\frac{2}{75} \end{align*}$
So the percentage error is
$\displaystyle \begin{align*} \frac{-\frac{2}{75}}{\frac{8}{3}} \cdot 100\% &= -\frac{2}{75} \cdot \frac{3}{8} \cdot 100\% \\ &= -\frac{600\%}{600} \\ &= -1\% \end{align*}$
Mathematics news on Phys.org
(a) Since the distance along the x-axis is "b" and it is being divided into "n" rectangles, that means $\displaystyle \begin{align*} \Delta x = \frac{b}{n} \end{align*}$.
(b) Each interval can be written as $\displaystyle \begin{align*} \left[ \left( i - 1 \right) \Delta x , i\,\Delta x \right] \end{align*}$, so that means the midpoint of each interval is
$\displaystyle \begin{align*} x_i &= \frac{\left( i - 1 \right) \Delta x + i\,\Delta x}{2} \\ &= \frac{\left( i - 1 + i \right) \Delta x}{2} \\ &= \frac{\left( 2\,i - 1 \right) \Delta x}{2} \end{align*}$
(c) Since we have found $\displaystyle \begin{align*} \Delta x = \frac{b}{n} \end{align*}$ that means
$\displaystyle \begin{align*} x_i &= \frac{\left( 2\,i - 1 \right) \Delta x}{2} \\ &= \frac{\left( 2\,i - 1 \right) \frac{b}{n}}{2} \\ &= \left( 2\,i - 1 \right) \frac{b}{2\,n} \end{align*}$
(d) The length of each rectangle is $\displaystyle \begin{align*} \Delta x \end{align*}$ and the width is $\displaystyle \begin{align*} g \left( x_i \right) \end{align*}$ so the area of each rectangle is $\displaystyle \begin{align*} A_i = g \left( x_i \right) \Delta x \end{align*}$
(e) Since $\displaystyle \begin{align*} x_i = \left( 2\,i - 1 \right) \frac{b}{2\,n} \end{align*}$ that means $\displaystyle \begin{align*} g \left( x_i \right) = g \left( \left( 2\,i - 1 \right) \frac{b}{2\,n} \right) \end{align*}$ and $\displaystyle \begin{align*} \Delta x = \frac{b}{n} \end{align*}$ that means $\displaystyle \begin{align*} g \left( \left( 2\,i - 1 \right) \frac{b}{2\,n} \right) \frac{b}{n} = g \left( x_i \right) \Delta x \end{align*}$, so
$\displaystyle \begin{align*} \sum_{i = 1}^n{ \left[ g\left( \left( 2\,i - 1 \right) \frac{b}{2\,n}\right) \Delta x \right] } &= \sum_{i = 1}^n{ \left[ g \left( x_i \right) \Delta x \right] } \\ &= \sum_{i = 1}^n{A_i} \end{align*}$
(f) (i) If $\displaystyle \begin{align*} g \left( x \right) = x^3 \end{align*}$, that means
$\displaystyle \begin{align*} \sum_{i = 1}^n{ A_i } &= \sum_{i = 1}^n{ \left[ g \left( \left( 2\,i - 1 \right) \frac{b}{2\,n} \right) \Delta x \right] } \\ &= \sum_{i = 1}^n{ \left\{ \left[ \left( 2\,i - 1 \right) \frac{b}{2\,n} \right] ^3 \,\frac{b}{n} \right\} } \end{align*}$
so when $\displaystyle \begin{align*} n = 100 \end{align*}$ we have
$\displaystyle \begin{align*} \sum_{i = 1}^{100}{ \left\{ \left[ \left( 2\,i - 1 \right) \frac{b}{100}\right] ^3\,\frac{b}{100} \right\} } &= \frac{19\,999\,b^4}{80\,000} \end{align*}$
Wolfram|Alpha: Computational Knowledge Engine
(ii)
$\displaystyle \begin{align*} A &= \lim_{n \to \infty}{ \left\{ \left[ \left( 2\,i - 1 \right) \frac{b}{n} \right] ^3 \,\frac{b}{n} \right\} } \\ &= \frac{b^4}{4} \end{align*}$
View attachment 7145(g) The exact area under the curve $\displaystyle \begin{align*} g(x) = x^3 \end{align*}$ between x = 0 and x = b is
$\displaystyle \begin{align*} A &= \int_0^b{x^3\,\mathrm{d}x} &= \left[ \frac{x^4}{4} \right] _0^b \\ &= \frac{b^4}{4} - \frac{0^4}{4} \\ &= \frac{b^4}{4} \,\textrm{units}^2 \end{align*}$
(i) so the error in using 100 rectangles for the approximation is
$\displaystyle \begin{align*} \frac{b^4}{4} - \frac{19\,999\,b^4}{80\,000} &= \frac{20\,000\,b^4}{80\,000} - \frac{19\,999\,b^4}{80\,000} \\ &= \frac{b^4}{80\,000} \end{align*}$
and so the percentage error is
$\displaystyle \begin{align*} \frac{\frac{b^4}{80\,000}}{\frac{b^4}{4}} \cdot 100\% &= \frac{b^4}{80\,000} \cdot \frac{4}{b^4} \cdot 100\% \\ &= \frac{100\%}{20\,000} \\ &= 0.005\% \end{align*}$
(ii) and as the limiting value is exactly equal to the integral value, the percentage error is 0%.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
10K
11K
11K
11K
