Damaging lithium ion batteries
In summary: In order for a circuit to draw 10+ amps from a 3.7 volt source the total resistance must be 3.7/10 ohms or less, so your observation of 10+ amps with a load of 0.3 ohms is plausible.
nlaham
44
So I have learned that all batteries have an internal resistance which will limit the current that it can output, so that you can't discharge a huge battery in a split second because of that internal resistance. But what I am wondering is, at what point is it dangerous to draw too much current on lithium ion batteries.
I took an 3.7V iPhone battery out (1900 mAh) and found the internal resistance to be very low through a couple tests, around 0.2 ohms or something. Later, I attached the leads to a very low ohm resistor and measured the current (like 0.1 ohms, barely anything). I actually maxed out the current on my ammeter, which is 10 amps, so I went over that mark. Hopefully I didn't mess up my meter, but I removed it quickly. The resistor also burnt out, but basically this tells me, I can pull a TON of current from this tiny little battery when it's not hooked to all the circuitry in the phone. Normally, it would be limited to only allow 500mA or something of the like.
I am wondering, is there a good rule of thumb that will tell me what current is unsafe to draw off a lithium ion battery? I would think at some point, if I shorted the battery out for more than a few seconds, the internal resistance in the battery would get very hot and destroy, explode or catch the battery on fire.
I just want to be safe here. I am not into short circuiting batteries, but I want to know how much current I can safely draw off of a lithium ion battery without causing it damage.
That internal resistance is not a separate component, it is an effective description of the battery itself and emerges from its way to store and release energy.
Try to find some data sheet. The maximal current the iPhone requires gives a (weak) lower limit for maximal current.
There is no general rule. For model car/aircraft use some batteries are sold with a "C rating". eg for a battery rated to "20C" the max recommended current is 20 times the AH capacity of the battery.
These cells are rated 60C 800mAH so are good upto 0.8*60 = 48A
http://www.overlander.co.uk/extreme-800-2s-7-4v-40c.html
These are 60C 5AH... Do the sums yourself!...
http://www.overlander.co.uk/batteries-chargers/lipo-battery-4400mah-3s-11-1v-60c-extreme-pro-1010.htmlThey may well be capable of delivering higher than that if abused. Take care now...
Thanks guys. I think the iPhone requires at most 1 to 2 amps when it's being used heavily (high processing power). Are you saying that the the battery then will have that as its max as a lower limit? What is the upper limit then? I am hoping I can draw 3-4 amps off of it safely, but there is no "C" rating on it.
If the iPhone can draw 1-2A (that is a lot), I doubt that this value is dangerous for the battery (otherwise it would be a poor design). However, it could tolerate higher currents, too.
Maybe you can use multiple batteries in parallel?
That is a good idea, I didn't consider that. I might be able to arrange 2 smaller batteries easier that way too.
Thanks for the tips.
In order for a circuit to draw 10+ amps from a 3.7 volt source the total resistance must be 3.7/10 ohms or less, so your observation of 10+ amps with a load of 0.3 ohms is plausible. I'm just wondering how you measured the cells internal resistance. I may be wrong but from your post it doesn't sound like ohms law is something you were familiar with, but that's the only way I can think of to measure a cells internal resistance.
I have been familiar with Ohm's law, just not too familiar with batteries and internal resistance. Well, I should say I was more familiar when I was in school, but forgot all of those things and needed a refresher, I'm only a Mechanical Engineer. I also have never really applied these principals to actual applications so I am sort of relearning some concepts.
Anyway, I measured the internal resistance using the second equation here. http://en.wikipedia.org/wiki/Output_impedance#Batteries
I measured no load voltage, then put a load on it, and measured current and loaded voltage. I had to measure the two separately since I only had one multimeter. Since the voltage keeps dropping off as I keep the current running and draining the battery, I can't be sure my loaded voltage and current measurements matched up exactly, but it was pretty close. The best way to do it would be to use two meters, and record my values at the same time. Hence the reason I said ABOUT 0.2 ohms. It could have been 0.15 or 0.25.
I want to test it again, but as of now I believe it's a really low internal resistance, so low that the max current I can draw off the battery would in fact be a dangerous level for a Li-Ion batery. I have been reading that 1C to 3C is a safe discharge rate for most Li-Ion batteries. (C being the capacity which I think is 1900mAh for iPhone 4, so anywhere from 1.9A to 5.7A would be safe for this battery, probably closer to the middle). Thanks to CWatters for this explanation on discharge rates.
I may start using a Lipo battery, since those can discharge at much higher currents, some as high as 60C (or 300 amps according to the battery CWatters pointed out.http://www.overlander.co.uk/batteries-chargers/lipo-battery-4400mah-3s-11-1v-60c-extreme-pro-1010.html
Something else to watch is the discharge voltage - you may need to build a voltage cut off to prevent the cells being over discharged. They can react badly to that.
Related to Damaging lithium ion batteries
1. Why do lithium ion batteries become damaged?
Lithium ion batteries can become damaged due to a variety of reasons, such as overcharging, exposure to extreme temperatures, physical damage, or manufacturing defects. These factors can cause the battery to overheat, leak, or lose its capacity to hold a charge.
2. What are the signs of a damaged lithium ion battery?
Some common signs of a damaged lithium ion battery include swelling or bulging, the battery not holding a charge for as long as it used to, and the device turning off unexpectedly. If you notice any of these signs, it is important to stop using the battery and seek a replacement.
3. Can a damaged lithium ion battery be repaired?
In most cases, a damaged lithium ion battery cannot be repaired. It is recommended to replace the battery to ensure the safety and proper functioning of your device. Attempting to repair a damaged battery can be dangerous and may cause further damage to the device.
4. How can I prevent my lithium ion battery from becoming damaged?
To prevent your lithium ion battery from becoming damaged, it is important to follow the manufacturer's instructions for charging and storing the battery. Avoid overcharging the battery and exposing it to extreme temperatures. It is also important to use the correct charger and avoid using damaged or counterfeit batteries.
5. What should I do with a damaged lithium ion battery?
If you have a damaged lithium ion battery, it is important to dispose of it properly. Do not throw it in the trash or attempt to open or repair it yourself. Instead, contact your local waste management facility or electronics retailer for information on how to safely recycle the battery.
