B Dark energy might not be constant after all
Recent findings from the Dark Energy Spectroscopic Instrument (DESI) suggest that dark energy may not be constant, as it measures the universe's expansion through optical spectra of millions of galaxies and quasars. The discussion revolves around the upper limits of the sum of neutrino masses, with two values presented: 0.072 eV and 0.113 eV, which depend on the assumed lower bounds for neutrino masses. The choice of these values is debated, with some arguing that the Bayesian prior used is not meaningful and should be disregarded. The conversation also touches on the implications of using degenerate cases in neutrino mass measurements, questioning their validity against existing data. Overall, the results highlight the complexities in understanding dark energy and neutrino masses in cosmology.
Filip Larsen
https://arstechnica.com/science/2024/04/dark-energy-might-not-be-constant-after-all/
https://www.desi.lbl.gov/2024/04/04...recise-measurement-of-the-expanding-universe/
Interesting preliminary indications from DESI (which I did not know about until now).
The Dark Energy Spectroscopic Instrument (DESI)​
The Dark Energy Spectroscopic Instrument (DESI) will measure the effect of dark energy on the expansion of the universe. It will obtain optical spectra for tens of millions of galaxies and quasars, constructing a 3D map spanning the nearby universe to 11 billion light years.
Likes pinball1970, pines-demon, exponent137 and 1 other person
Space news on Phys.org
One question:
In https://arxiv.org/pdf/2404.03002.pdf
it is written in the abstract:
"upper limit Sum mν < 0.072 (0.113) eV at 95% confidence for a Sum mν > 0 (Sum mν > 0.059) eV prior."
To which value we can believe more, 0.072 eV, or to 0.113 eV?
exponent137 said:
One question:
As noted in the main text,
Likes exponent137
So, is 0.113 eV the more correct answer? Let us ignore IH. What is the point of 0.072 eV? To show that the results are more precise?
It's not that it's 'more correct'. The result is dependent on what one assumes is the correct lower bound for the sum of neutrino masses. If you assume one thing, it's that. If you assume another, it's the other thing.
They have to assume something, because it's not known. But there are good reasons to pick some specific values, for which they show the corresponding results.
The relevant bit is in section 7.1 (second paragraph).
Likes exponent137
exponent137 said:
One question:
The second. The merely non-zero Bayesian prior for the sum of the three neutrino masses is contrary to the whole point of using Bayesian statistics (which is to incorporate information that you already know in a prior), and should just be ignored as meaningless.
Likes exponent137
I read. One option is for the degenerate case. I suppose that this option is contrary to the measured mass differences of neutrinos? If it is in contradiction with measurements, why it is used? Maybe because it gives some simplified information?
