Dark matter and weighing galaxies
In summary, astronomers use mass to measure galaxies and dark matter in order to be confident of the amount of dark matter in the universe. There are alternative explanations for dark matter, but the most likely one is that it is a type of neutrino. Dark matter likely interacts with gravity the same way as regular matter does, but we cannot see it because the light waves it emits are canceled out by other light sources.
sirchick
51
Hello
I have a question (well its 2 questions)... I'm not hugely knowledged on the subject so i tend to question things in a more ignorant way but i wanted to know two things:
Firstly, how do astronomers weight a galaxy at an accurate level to be confident enough to say there is more stuff that is invisible to us (dark matter) than what we visibly see? How is it done and done accurately that we can be confident on that?
Secondly, with this invisible matter aka dark matter that we cannot see... is it possible that due to the billions of light sources throughout the universe, light phase cancellation causes the matter to go dark...so really its ordinary matter but we cannot see it because the light is canceled out by other light sources ?
Astronomy news on Phys.org
sirchick said:
Hello
We measure mass by its gravitational influence, We can say with confidence that their is "dark mass" due to the gravitational influence of Baryonic matter (visible matter) and the gravitational influence of dark matter. The gravitational influence of dark matter and baryonic matter affects a galaxies rotation curve.
Based on observations if you look at the rotation curve of a galaxy, and the distribution of visible matter the rotation of stars further from the galactic center should be slower the further you get from the center. However stars are moving near the same speed the further from the center you get, as compared the stars near the center. This told scientists that there is missing mass distributed around the galaxy where there are no stars. Also gravitational lensing where there is no visible influence is another indicator of DM
Dark matter is a weakly interactive particle with similar properties as neutrinos. It doesn't interact with the electromagnetic or strong force. We know it interacts with gravity, may or may not interact with the weak force. However it may or may not interact with other weakly interact with other weakly interactive particles such as neutrinos. One candidate is that dark matter is a sterile neutrino. A neutrino is so weakly interactive that it can travel through a 1000 light years of lead without and interaction. here is a recent thread with a recent paper on it
https://www.physicsforums.com/showthread.php?t=750545
here is another thread with a similar paper.
https://www.physicsforums.com/forumdisplay.php?f=68
this article I recommend reading as it explains in a FAQ style what we have learned from observational cosmology, its coverage of dark matter and dark energy is decent and in a layman format.
http://arxiv.org/abs/1304.4446
Regarding the 2nd part of the question - "could it be ordinary matter in which cancellations render it 'dark' to us"
Don't forget that it appears that Dark Matter and Dark Energy comprise roughly 96% of our Universe, with Dark Matter at 70%. If that amazing amount were ordinary matter, do you suppose 4% could block/cancel 70%. See? not likely.
Dark Matter may be hard to swallow as it is so humbling but the only solid competitor is MOND and it has many problems and will continue to until we understand gravity better since it depends on a non-linear, non-constant gravity contrary to Newton and everything we can measure close at hand.
The universe may not be smooth. The distribution of matter could be a result of topology, as opposed to most matter being imperceptible.
This is the second post in which you have suggested that. Can you cite any work on any topology theories that would explain dark matter halos, the Bullet Cluster, and so forth or is this just some personal theory of your own?
While there certainly is room for some speculation, not only is that frowned upon in these forums without some evidence, and even though it is extremely difficult to wrap ones head around sizes smaller than Planck Length, recently chance plus ESA's Integral Gamma Ray Observatory observations deny "graininess", apparently accurate to one-trillionth the size of Planck Length.
Pretty exciting stuff at
http://www.sciencedaily.com/releases/2011/06/110630111540.htm
None of the papers I linked to concern graininess.
Dark matter is an etiology of our observations. It's one of many. We have great data to evidence, describe and predict phenomena. However, I'm aware of no evidence that supports any singular etiology. This is analogous to Newton's gravity. He had great data, but lacked etiology.
actually the last paper does,
"Basically we are considering a symplectic geometry as a commutative limit of noncommutative geometry which is regarded as a microscopic structure of spacetime, like as the classical mechanics in a mundane scale is simply a coarse graining of quantum mechanics at atomic world. Riemannian geometry thus appears at a macroscopic world as a coarse graining of the non commutative geometry"
you must have missed that detail.
http://arxiv.org/pdf/1004.0745.pdf
page 9 section 1.4
I'll bet you also didn't know that MOND uses Dipolar dark matter DDM.
http://arxiv.org/pdf/1301.0623v2.pdf
page 12 section 4.5
It seemed to me that if cancellations can't be responsible for "ordinary matter appearing dark" what is left? Then you brought up "smoothness" and it seemed to me this can only be some sort of blocking since afaik the overwhelming evidence points to a remarkably flat topology, unless I am missing your drift altogether... or are you referring to this purported discovery of immense structures of Quasars that apparently has a few running around worrying that "the sky is falling"? At the very least it seems a little early for that.
For me it just means we can't rule out any possibility, lovely nature about science. There is strong evidence to support dark matter and strong evidence to show the universe is extremely smooth. Doesn't necessarily mean either statement is proven. Just that research and observations currently favors DM and smoothness. As well as dark energy. The LCDM model is extremely strong, but then again the same could be said about LQC.
I try to follow the rule of thumb study everything, you always learn something. I've even studied some utterly ridiculous models.
page 9 section 1.4
That's just an analogy. I guess you didn't read the whole paper.
I'm not concerned with the new observations. The idea of a homogeneous, isotropic universe is too convenient. It's inconsistent with basic ontology and abstract math, which frequently fails to remain abstract.
I think topology makes more sense than DM for simple reasons. We've observed topological deformations. We understand some fluid dynamics. If we apply it to space-time, wave saturation can account for the distribution of matter and expansion without the need for DM or DE.
http://arxiv.org/pdf/1303.0065.pdf
page 9 section 1.4
yeah your correct was on my lunch break reading it on my smart phone.
I'm somewhat skeptic but nonetheless an interesting interpretation that might work. It is mathematically distributed/integrated as part of a whole dynamic system(math) instead of objectively separating all constituent to account for the missing 'thing' -as a mathematical model( fun for mathematicians ^^)not as much as observational/experimental solution. However, DM is more in line with observation as more of a solution and offer success in giving observation data a positive relation and sense (for large structure). Besides, We already have non/-nuetrino's DM as a go-go starting line..
Related to Dark matter and weighing galaxies
1. What is dark matter and why is it important to study?
Dark matter is a hypothetical type of matter that does not emit or interact with electromagnetic radiation, making it invisible to telescopes. It is believed to make up about 85% of the total matter in the universe. Its presence is inferred through its gravitational effects on visible matter. Studying dark matter is important because it can help us understand the structure and evolution of the universe, as well as the formation of galaxies and other large-scale structures.
2. How do scientists weigh galaxies?
Galaxies are weighed by measuring the rotational speeds of stars and gas within them. This is done using the laws of gravity and motion, which allow us to calculate the mass of a galaxy based on the velocity of objects within it. This method is known as galactic rotation curve analysis.
3. What is the role of dark matter in weighing galaxies?
Dark matter plays a crucial role in weighing galaxies because it makes up a large portion of their total mass. Without taking dark matter into account, the calculated mass of a galaxy would be significantly lower than its actual mass. This is because dark matter does not emit or interact with light, so it cannot be detected through traditional observational methods.
4. Can dark matter be directly observed?
No, dark matter cannot be directly observed because it does not interact with electromagnetic radiation. However, scientists are working on ways to indirectly detect dark matter through its effects on visible matter, such as gravitational lensing or the production of high-energy particles.
5. How does the study of dark matter and weighing galaxies contribute to our understanding of the universe?
Studying dark matter and weighing galaxies allows us to better understand the distribution of matter in the universe and its effects on the formation and evolution of galaxies. It also helps us to test and refine our theories of gravity and cosmology, and ultimately leads to a deeper understanding of the fundamental laws that govern our universe.
