Dark Matter, Energy-Momentum Tensor & Galaxies
In summary: Evidently you didn't try Google. I suggest...In summary, astrophysicists accurately account for all of the energy and pressure within a galaxy by using the Energy-Momentum tensor. General relativity predicts that space-time curvature is a consequence of mass, energy, and pressure as expressed in the Energy-Momentum tensor. The accepted explanation of the excessive rotation speed of stars in the outer periphery of galaxies is due to some kind of dark matter that accounts for the needed mass necessary to keep the stars in orbit. But could it be that there has not been an adequate accounting of the total pressure and energy, across the full electromagnetic spectrum, including energy associated with quantum particles and states, that is contained within a galaxy
e2m2a
359
How do astrophysicists accurately account for all of the energy and pressure within a galaxy? How is it tabulated? My understanding of general relativity predicts that space-time curvature is a consequence of mass, energy, and pressure as expressed in the Energy-Momentum tensor.
But could it be that there has not been an adequate accounting of the total pressure and energy, across the full electromagnetic spectrum, including energy associated with quantum particles and states, that is contained within a galaxy to account for the additional curvature or gravitonal force necessary to keep the stars in their orbits?
e2m2a said:
... could it be that there has not been an adequate accounting of the total pressure and energy, across the full electromagnetic spectrum, including energy associated with quantum particles and states, that is contained within a galaxy to account for the additional curvature or gravitonal force necessary to keep the stars in their orbits?
Yeah, it's possible that all the thousands of physicists who have studied this issue never thought of that and just made up "dark matter" to cover their ignorance. But I doubt it. Also, you'd need to show how that accounts for the gravitational lensing that is clearly caused by dark matter, plus other things like the bullet cluster.
OK. Take the Andromeda galaxy as an example. What is the total amount of energy and pressure in Joules associated with that galaxy? Where can this be looked up?
I have no idea but someone else here may.
In general, that's correct. However, for the specific case you're asking about, a galaxy, energy (other than rest mass) and pressure are completely negligible as sources of gravity; the only significant source is rest mass. The only situation in which energy other than rest mass and pressure are significant as sources of gravity is inside neutron stars.
If you're intending this to be a separate category, in addition to energy (other than rest mass) and pressure, it isn't. "Energy associated with quantum particles and states" is just another way of saying "energy and pressure".
No. There are several lines of reasoning involved here. First, there is what I said above, that the only significant source of gravity for a large system like a galaxy is rest mass. Then there are the following additional items:
We can count stars in nearer galaxies, and we can measure the luminosities of more distant galaxies. Over large numbers of stars, we can get accurate estimates of the total mass in stars from the total luminosity.
We can get good estimates of how much mass in the entire universe is contained in baryons (i.e., in the kind of matter that stars are made of) from measures of light element abundances, which put fairly tight constraints on how many baryons were present at the end of Big Bang nucleosynthesis (when light elements--mainly deuterium, helium, and lithium, with a small smattering of a few others--were made).
Comparing the two estimates above tells us that practically all baryonic matter in the universe is contained in the stars and galaxies we see. There isn't any room for significant baryonic mass that isn't visible. That means that whatever the invisible stuff is that is keeping stars contained in galaxies whose visible matter isn't enough to hold them in, it can't be anything that is accounted for by our current theories. That's why cosmologists have postulated dark matter.
Evidently you didn't try Google. I suggest that you try it.
Ok. Thanks for your explanation.
Related to Dark Matter, Energy-Momentum Tensor & Galaxies
1. What is dark matter?
Dark matter is a type of matter that makes up about 85% of the total mass of the universe. It does not emit or absorb light, making it invisible to telescopes, but it can be detected through its gravitational effects on visible matter.
2. How does dark matter affect galaxies?
Dark matter plays a crucial role in the formation and evolution of galaxies. Its gravitational pull helps to hold galaxies together and allows them to rotate at high speeds without flying apart. Without dark matter, galaxies as we know them would not exist.
3. What is the energy-momentum tensor?
The energy-momentum tensor is a mathematical object used to describe the distribution of matter and energy in space and time. It is a key concept in Einstein's theory of general relativity and is used to calculate the curvature of spacetime.
4. How does the energy-momentum tensor relate to dark matter?
The energy-momentum tensor plays a role in the equations used to describe the behavior of dark matter. It is used to calculate the gravitational effects of dark matter on the movement of galaxies and other astronomical objects.
5. Can dark matter be detected?
While dark matter cannot be directly observed, scientists have developed several methods for detecting its presence. These include observing the gravitational lensing effects on light from distant galaxies, studying the rotation curves of galaxies, and using particle detectors to search for interactions with dark matter particles.
  • Astronomy and Astrophysics
