Dark Matter Gravity: What Do We Know?
In summary, Neil deGrasse Tyson explains that dark matter follows the same gravitational rules as ordinary matter. However, we have no idea what dark matter is, so how can we make such claims? Additionally, even if a single "molecule" of dark matter weighed as much as the sun, it would still exert the same amount of gravity as the sun due to the square fall off of gravity. Dark matter makes up 85% of the matter in the universe, but it is not considered "ordinary" because we tend to view baryonic matter as the norm. When searching for dark matter, we must consider its effect on the orbits of stars and how it behaves gravitationally, as these factors are interconnected.
zuz
87
33
Neil deGrasse Tyson states that "dark matter exerts gravity according to the same rules that ordinary matters follows" How do we know this? If we have no idea what dark matter is, how can we say how it behaves? How do we know that a single "molecule" of the stuff doesn't weigh as much as the sun? Or vise versa? Also, if it makes up 85% of the matter in the universe, shouldn't it be called "ordinary?"
Likes Dr_Nate
If you have a closed box with just a hand hole and you reach inside and what you feel there is just liquid at room temperature, can you say for sure that it is not solid steel? If you CAN say that (and I sure as heck can), HOW can you say that? After all you don't know for sure what's in the box, so what would you base any statement on?
Even if a single molecule of this "stuff" weighed as much as the Sun (effectively making it a black hole). The gravity it produces would be the same as the Sun. What he meant was that it's gravity would fall off by the square of the distance (not by the cube or some other value). It would still obey General relativity, etc.
Or put another way, if you were to squeeze the Sun down to the size of a single molecule, you would not be able to distinguish it gravitationally from a single particle of dark matter.
As to considering dark matter being the "norm" or not, put it down to baryo-centrism. We, and everything we interact with is made of baryonic matter, so we tend to treat it as being "normal", despite the fact that it might be in the minority in terms of mass making up the universe.
Likes pinball1970
I'm not sure this addresses the OP's question though.
'What if all this dark matter is merely one really massive particle per cubic light year?' kind of thing. Wouldn't that change the parameters of how we search for it?
Likes Dr_Nate
How do you know it's gravity would fall off at the square of it's distance when you don't know where it is or what form it takes? Could it be somewhere else and actually be repulsive?
You have this backwards. We know where it is because of how its gravity falls off.
When examining the idea of dark matter, there are two things to consider, Its effect on the orbits of the stars in the galaxy, and its effect on itself. When we assume that it behaves just like other matter gravitationally, everything "fits together". We can work out how it would naturally tend to form around the galaxy due gravity, and we can calculate what type of gravitational effect that distribution would have on the stars. Then we check this prediction against what we see the stars actually behaving.
If we assume that it followed a cube fall off for gravity, then you would have to assume a different distribution to produce the effect we see on the Stars, But a cube fall of for gravity wouldn't result in it naturally assuming that distribution.
You can't just make one arbitrary assumption about how its distributed and another how it acts gravitationally, as the two are interconnected and one depends on the other.
Likes PeroK
Thank you. That almost makes sense to a layman like me. And please understand, I am just a layman. I'm just trying to understand what makes no sense to me
There are various possibilities for what dark matter might be: heavy neutrinos, a completely new sort of particle, lots of primordial black holes, or something that no one has thought of yet. These all fit into the category of things that behave gravitationally normally.
There are other possibilities like a modified theory of gravity (MOND), which you could look up.
I think @zuz has an insightful question. We should ask ourselves: what hidden premises are we assuming when we make our models?
That is often the first thing that is lost when the science is translated into layman-friendly language for popular consumption.
Likes Dr_Nate
It isn’t a hidden premise. It is an up front very clear premise that everything (including dark matter) gravitates according to the normal laws of gravitation.
Likes epenguin
alanpennock said:
So..."if it walks like a duck and quacks like a duck ...it is a duck...If it looks like gravity and acts like gravity..it's gravity...OK so where does gravity come from? ...Matter...Oh and then there's antimatter...both matter ...does that mean both have gravity? Maybe so...I don't know!
Yes, regular matter, including anti-matter, and dark matter all have gravity.
alanpennock said:
dark matter does not interact with matter and therefore does not? & cannot be detected.
Except gravitationally.
I believe that Neil deGrasse Tyson's hidden premise in that statement would be something like: the observations that we label as being due to dark matter are due to matter particles. Thus the models he considers exclude things like modified Newtonian dynamics (MOND).
The term dark matter is often a label similar to electromotive force: it's plain reading isn't necessarily true. We don't actually mean a force when we use the term electromotive force. A dark matter researcher might only be working on models of MOND.
alanpennock said:
I would think so. anti-matter combines with matter and gives off gamma radiation, et. al. and can then be detected...dark matter does not interact with matter and therefore does not? & cannot be detected.
There are many detectors around the world trying to detect dark matter particles directly via some other assumed non-gravitational interaction. So far the evidence points to dark matter particles interacting only via gravity.
On the other hand, there are cosmological simulations that have suggested that dark matter may interact via some other mechanism.
And you call that a “hidden premise”? Uh, ok.
Likes weirdoguy
Related to Dark Matter Gravity: What Do We Know?
1. What is dark matter and how is it related to gravity?
Dark matter is a hypothetical type of matter that does not interact with light or other forms of electromagnetic radiation. It is believed to make up about 85% of the total matter in the universe. While its exact nature is still unknown, scientists believe that dark matter interacts with gravity, which is why it is often referred to as "dark matter gravity."
2. How do we know that dark matter exists?
Scientists have observed the effects of dark matter through its gravitational influence on visible matter, such as stars and galaxies. They have also measured the rotation curves of galaxies and found that they cannot be explained by the amount of visible matter present, indicating the presence of an invisible mass, which is believed to be dark matter.
3. Can dark matter be detected?
Dark matter cannot be directly detected because it does not interact with light. However, scientists are using various methods, such as gravitational lensing and particle accelerators, to indirectly detect and study dark matter.
4. How does dark matter affect the expansion of the universe?
Dark matter plays a crucial role in the expansion of the universe. It provides the necessary gravitational pull to counteract the expansion caused by dark energy, allowing galaxies and other structures to form and maintain their shape.
5. What is the current understanding of dark matter gravity?
While scientists have observed the effects of dark matter gravity, its exact nature is still a subject of ongoing research and debate. Some theories suggest that dark matter is made up of particles that interact with gravity, while others propose modifications to the laws of gravity to explain the observed effects. Further research and observations are needed to fully understand the role of dark matter gravity in the universe.
  • Other Physics Topics
9K
  • Beyond the Standard Models
  • Cosmology
