Dark matter is "normal" matter in black holes?
In summary, the article suggests that: - There is no definitive evidence that dark matter is made up of black holes. - The relationship between visible-ordinary matter and the calculated sum of ordinary + dark matter is not accurate. - The concentration of dark matter in galaxies is not a reliable indicator of its existence.
Alfredo Tifi
68
I read that
1. dark matter has to be concentrated in galaxies;
2. McGaugh & Co discovered a precise relationship between visible-ordinary matter and the calculated sum of ordinary + dark matter from thorough observation of actual acceleration of more than 150 galaxies.
3. First experiments to reveal effects or interactions of dark matter have failed.
4. Galaxies have giant black holes in their cores.
Before going ahead with Modified-Gravity Theories, why does not anybody take into account the hypothesis that dark matter is nothing else but normal matter in black holes, thus invisible? MacGaugh's relationship could be the result of a correlation between visible mass and black hole dimension. The four points would agree.
Space news on Phys.org
That is not in good agreement with measurements. Of course people considered it, but it doesn't work well. So many or so large black holes should be detectable, but they don't seem to exist. There is also no plausible mechanism for them to form. We can't fully rule out primordial black holes but they don't work well.
With a tiny fraction of the galactic mass.
Do we know the "tiny" ratio of black hole mass to total mass in the milky galaxy? How do we measure the mass of other galaxies' black holes?
Yes. We have been able to directly observe stars orbiting very close to our SMBH.
Their orbital periods tell us the mass of the BH.
At the same time, it also puts an upper limit on the physical size of the BH (since clearly it cannot be larger than the closest approach of the stars).
Likes Alfredo Tifi
Alfredo Tifi said:
I read that
Is not a suitable source until you tell us where.
Not universally true. M33 (the nearest example) does not - or if it does, it is very small for a "giant".
If you mean in the core, because it's in the wrong place. If you mean not in the core, why did you bring up cores?
The reading is from Scientific American article "Is Dark Matter Real?", by Sabine Hossenfelder and Stacy S. McGaugh, August 2018 (published in December in the Italian version).
Alfredo Tifi said:
I read that
1. It would be more accurate to say that DM concentrates around galaxies ( the majority of dark matter is in regions where we see no visible matter.
2. While there may be a relationship between the relative ratio of dark matter to luminous matter per in galaxies ( though this recent discovery seems to cast doubt on that assertion in for all cases;
https://Earth'sky.org/space/ngc-1052-df2-galaxy-without-dark-matter )
This doesn't mean that the distribution of dark matter mirrors that of the luminous matter. In fact, in order to explain the rotation curves, it can't.
3. This is a case of where lack of evidence, is not evidence of lack. We are looking for something that would only react weakly (if at all) with other matter, with the exception of gravity. Gravity is such a weak force, that you would need a lot of Dark matter to detect it that way. (like when it effect the rotation curves of a galaxy. For years, critics kept claiming that the failure to detect Gravitational waves was evidence of their non-existence, but we have now detected them.
4. Don't be misled by the "supermassive" " in supermassive black hole", this is relative term used to compare them to stellar sized BHs. a typical supermassive black hole only has a small fraction of the mass of the total luminous matter in its galaxy. To explain galaxy rotation curves you need amounts in excess of the luminous matter mass.
Trying to squeeze all that extra mass into the central black hole doesn't solve the problem. It would actually cause the predicted rotation curve to deviate even further from what we measure. In order to match what we measure, the extra mass has to be spread out into a spherical volume that the visible galaxy sits in. So for a spiral galaxy like our own, a good deal of it would have to be in the regions above and below the visible disk. If this were to be explained by DM being BH, you would have to explain why all those black holes formed out where there are hardly any stars.
Another problem has to do with the fact that those black holes would have had been formed, as you put it, from "normal matter". But or models of the formation of the universe preclude that. It goes back to the early universe and to when the elements first started forming. If the universe had very much more baryonic matter in it that we see now, this process would have been effected. The result we would see today would be a different relative distribution of elements. In other words, the fact that universe is now made up of 74% hydrogen, 24% Helium, 10.4% oxygen, and so on, means that the universe can't have too much matter hiding in black holes. The limit of how much matter could be hiding in Black holes is much less that needed to account for the effects attributed to dark matter.
The point is, astronomers are not going to pick a complicated answer over a simple one if there is a chance of the simple one being right. They'll look for simple solutions first, and move on to more complicated ones if they don't pan out. So don't assume that they "overlooked" the simple answer. It is much more likely that is was considered and then rejected for failing to pass muster.
Likes Imager and Alfredo Tifi
Thank you Janus. I really appreciated your perfectly convincing arguments. So now two options only remain open: a) dark matter exists; b) relationship between mass and gravitational field has to be corrected (Scientific American article "Is Dark Matter Real?", by Sabine Hossenfelder and Stacy S. McGaugh, August 2018).
Related to Dark matter is "normal" matter in black holes?
1. What is dark matter?
Dark matter is a type of matter that does not interact with light or other forms of electromagnetic radiation. It is thought to make up about 27% of the total mass of the universe.
2. How is dark matter related to black holes?
Dark matter and black holes are two separate concepts. Dark matter is a type of matter that is believed to exist throughout the universe, while black holes are extremely dense objects that form when a massive star dies.
3. Is dark matter the same as normal matter?
No, dark matter is not the same as normal matter. Normal matter, which includes atoms and subatomic particles, interacts with light and other forms of electromagnetic radiation, while dark matter does not.
4. Why is dark matter sometimes referred to as "normal" matter in black holes?
Dark matter is sometimes referred to as "normal" matter in black holes because it is believed that some of the dark matter in the universe may have been pulled into black holes through their gravitational pull.
5. How do scientists study dark matter in black holes?
Scientists study dark matter in black holes through indirect methods, such as observing the effects of dark matter on the motion of stars and galaxies. They also use simulations and mathematical models to understand the behavior of dark matter in the presence of black holes.
  • Astronomy and Astrophysics
  • New Member Introductions
