Darlington pair question
  • Thread starter likephysics
  • Tags
    Pair
In summary, the first transistor in a Darlington pair is connected to one side of the load in order to supply enough base current for the second transistor to turn on the load. The first transistor requires a Vce of about 3 volts to function properly, so driving the second transistor into saturation is not possible. This is why tapping from the collector rail instead of Vcc provides some negative feedback and makes the amplification more stable. Additionally, using a Darlington pair as a switching application is not ideal due to its high Vce voltage drop in the ON state. Lastly, tapping from the collector instead of Vcc is more efficient and practical for high current applications.
likephysics
636
Why is the first transistor in the D-pair connected to one side of the load and not directly to the Vcc rail.
As I understand, the purpose of the first transistor is to supply enough base current, so that the second transistor has adequate collector current to turn on the load.
Fig here:
http://www.sciencelobby.com/junction-transistors/images/darlington-pair.gif
The first transistor needs ~ 3 volts Vce to perform well, so you cannot drive the Darlington second transistor into saturation. Even with the first transistor fully saturated, the second transistor has a Vce of over a volt (min). Darlington is ok if Vce >=4 volts in my opinion. Darlington is not a good switching application because Vce voltage drop is too high in ON state.
Bob S
Tapping from the collector rail instead of Vcc provides some negative feedback which makes the amplification more stable.
Also, darlington pairs are self contained units. Adding extra resistance to tap from Vcc instead of a collector is a waste of power, especially when they are used in high current applications.
Related to Darlington pair question
1. What is a Darlington pair?
A Darlington pair is a type of electronic circuit that is commonly used to amplify weak signals or to switch high currents. It consists of two bipolar transistors connected in a specific way to increase their overall gain.
2. How does a Darlington pair work?
In a Darlington pair, the first transistor (called the driver transistor) amplifies the input signal and the second transistor (called the output transistor) amplifies the already amplified signal. This results in a high overall gain for the circuit.
3. What are the advantages of using a Darlington pair?
One of the main advantages of using a Darlington pair is its high current gain, which allows for the amplification of weak signals without the need for additional amplification stages. It also has a high input impedance, low output impedance, and good linearity.
4. What are the applications of a Darlington pair?
Darlington pairs are commonly used in audio amplifiers, power supplies, and motor control circuits. They are also used in switch mode power supplies and in high-frequency applications such as radio frequency amplifiers.
5. How do I calculate the values of the components in a Darlington pair circuit?
The values of the components in a Darlington pair circuit can be calculated using standard equations for transistor circuits. These include the base and collector currents, voltage drops, and resistance values. It is important to use the datasheets for the specific transistors being used to ensure accurate calculations.
  • Electrical Engineering
18K
