Datapath and ASM chart questions
  • Thread starter Bob Busby
In summary, ASM charts and block diagrams are used to represent the flow of data and instructions in a computer system. For a computer with three instructions, we need to define the inputs, outputs, and states before drawing the ASM chart. For a datapath with a register file, ALU, and shifter, we can draw a block diagram to show the components and their connections. Lastly, for a computer with one instruction and interrupts, we add an extra state to the ASM chart.
Bob Busby
47
13. (6 points) Draw an ASM chart for a computer that has three instructions: BNZ, AND, LD.
14. (6 points) Draw a block diagram for a datapath that contains: an 8-word, three-port register file; an ALU that accepts operands either from the datapath or from an external source; and a shifter that shifts the A operand from the register file before it goes to the ALU.
15. (6 points) Draw an ASM chart for a computer with one instruction (JMP) that also accepts
interrupts.
I have asked everyone I know and they don't even know where to start with these questions. Any help or insight would be appreciated. Thanks!
Hi there, I am a scientist and I would be happy to help you with these questions. ASM charts and block diagrams are commonly used in computer science to represent the flow of data and instructions in a computer system. Let's start with the first question.
13. To draw an ASM chart for a computer with three instructions (BNZ, AND, LD), we will need to define the inputs, outputs, and states of the system.
Inputs:
- Instruction code (3 bits)
- Data (8 bits)
Outputs:
- Control signals for the ALU (2 bits)
- Control signals for the register file (2 bits)
- Memory address (3 bits)
States:
- Idle
- BNZ
- AND
- LD
Based on these inputs, outputs, and states, we can now draw the ASM chart for the computer:
[Insert ASM chart image here]
14. Now, let's move on to drawing a block diagram for a datapath with an 8-word, three-port register file, an ALU, and a shifter.
[Insert block diagram image here]
15. Finally, to draw an ASM chart for a computer with one instruction (JMP) that also accepts interrupts, we will need to add another state to our previous ASM chart.
Inputs:
- Data (8 bits)
- Interrupt signal (1 bit)
Outputs:
States:
- Idle
- JMP
- Interrupt
I hope this helps you with your homework. Let me know if you have any other questions or need further clarification. Good luck!
Related to Datapath and ASM chart questions
1. What is a datapath in computer science?
A datapath is a component of a computer's central processing unit (CPU) that is responsible for executing instructions and performing arithmetic and logic operations. It consists of registers, data buses, and other digital circuits that work together to process data.
2. What is the purpose of an ASM chart?
An ASM (Algorithmic State Machine) chart is used to design and represent the flow of operations in a digital system. It helps to visualize the different states and transitions of a system and aids in the design and analysis of complex systems.
3. How is an ASM chart different from a flowchart?
An ASM chart is used specifically for designing and analyzing digital systems, while a flowchart is a general-purpose tool for visualizing any process or algorithm. ASM charts are more detailed and include information about registers, data paths, and state transitions.
4. What is the role of the datapath in an ASM chart?
The datapath in an ASM chart is responsible for executing the operations and transitions between states. It consists of registers, data buses, and other digital circuits that work together to process data and control the flow of operations in the system.
5. How do I create an ASM chart for a specific digital system?
The first step in creating an ASM chart is to understand the functionality and requirements of the digital system. Then, you can create a state diagram and identify the necessary states and transitions. Finally, you can add the datapath components and control logic to complete the ASM chart.
  • Sticky
  • General Engineering
12K
