MHB David's Math: Solving a Non-Linear System in 2 Variables
The discussion focuses on solving a non-linear system of equations involving two variables, x and y. The equations provided are x² + y² + x + y = 530 and xy + x + y = 230. A step-by-step solution is outlined, starting with isolating x in the second equation and substituting it into the first. This leads to a fourth-degree polynomial in y, which is factored to find roots, revealing y = 10 and y = 20 as solutions. The final results yield four pairs of solutions for (x, y), including (10, 20) and (20, 10).
MarkFL
MHB
Here is the question:
David said:
Very hard math problem.?
Please I need help. Could someone calculate this, please.
xy + x + y = 230
I know that x= 10, y=20, but I need how to calculate it step by step. please please please :)
I have posted a link there so the OP can view my work.
Mathematics news on Phys.org
Hello David,
We are given the two equations:
$$x^2+y^2+x+y=530$$
$$xy+x+y=230$$
If we solve the second equation for $x$, we obtain:
$$x=\frac{230-y}{y+1}$$
And then substituting for $x$ into the first equation, we get:
$$\left(\frac{230-y}{y+1}\right)^2+y^2+\frac{230-y}{y+1}+y=530$$
Multiplying through by $(y+1)^2$, and factoring a little and rearranging, there results:
$$(230-y)^2+y(y+1)^3+(230-y)(y+1)-530(y+1)^2=0$$
Distributing and collecting like terms, we obtain:
$$y^4+3y^3-527y^2-1290y+52600=0$$
Utilizing the rational roots theorem, we find that $y=10$ and $y=20$ are roots, and performing the division, we find the equation may be factored as:
$$(y-20)(y-10)\left(y^2+33y+263\right)=0$$
Using the quadratic formula on the quadratic factor, we find the remaining two roots:
$$y=\frac{-33\pm\sqrt{37}}{2}$$
And thus, using the formula for $x$ as a function of $y$ we found earlier, we find the four solutions:
$$\bbox[10px,border:2px solid #207498]{(x,y)=(10,20),\,(20,10),\,\left(-\frac{33+\sqrt{37}}{2},\frac{-33+\sqrt{37}}{2}\right),\,\left(\frac{-33+\sqrt{37}}{2},-\frac{33+\sqrt{37}}{2}\right)}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
