Dawn distance to Ceres ≈ distance to moon
  • Thread starter Thread starter marcus
    Moon
The Dawn probe is currently about 1.5 light seconds from Ceres, which is roughly 28% the size of the Moon. As it approaches, Ceres will begin to appear more comparable in size to the Moon, currently looking about one-fourth its angular size. Ceres is believed to contain approximately 30% water, making it a significant potential resource for future space exploration. The escape velocity from Ceres is much lower than that of Mars, suggesting easier access to its surface. Ongoing observations and data from the Dawn mission will provide more insights into Ceres' composition and potential for liquid water beneath its surface.
  • #31
marcus said:
For some reason I started shaking with laughter. Not even sure you meant to be humorous. Yesss, they are rocket scientists, and rocket scientists do like their bottle of xenon. They wouldn't want to run out of xenon, noooo. :D
I'll have to send Greg a PM regarding the anonymity of our 2014 Awards.
I got mine for humour. :oldgrumpy:
*** ******* ****-**, I want to be a scientist! :oldcry:
ps. I was very nervous when I first saw that the 4 orbital distances were published 2 years ago, and was quite relieved that they are still planning them, given the gyro troubles.
Though, even if they are only able to orbit from 13000 km, it will be an exquisite view. Trust me.
Astronomy news on Phys.org
  • #32
Amaterasu21 said:
Here you go:
The Moon, Mars, Venus and Earth seem to lie in a pretty straight line. Mercury is a lot denser than its predicted value (presumably because of its huge iron core) and Ceres is a lot less dense (presumably because it contains a lot of ice).
I thought a bit about the origin of this straight line:
Surface gravitational acceleration g = GM/r^2.
Because ρ = M/V (where ρ is the density of the planet and V is its volume), for a spherical planet,
g = (4π/3)Gρr.
Surface gravity is therefore proportional to the density of the planet for a given radius, as all other terms are constant. I'm still not entirely sure where the straight line comes from though, since the Moon, Mars, Venus and Earth have very different radii. Or am I missing something key here?
So looks like we have
Rho ~ constant + constant x G
Rho ~ A + B rho R
So I guess we could solve for R as a function of density... Or gravity...
Using normalized units ( Earth = 1 ) might make the mathematics a lot easier
  • #33
I don't have a computer
But maybe applying this analysis to exoplanets from the exoplanets database would reveal some exoplanets to be over dense like Mercury ( more iron ) or under dense like Ceres ( more ice ) ?
  • #34
I mean terrestrial type rocky exoplanets
  • #35
I would be careful with the interpretation of that plot. We have 6 data points, we remove 2 outliers, and then the 4 remaining points (where 2 are very close to each other) are roughly on a straight line? That is not really surprising.
Distance is down to 261000km, and Dawn is approaching Ceres with 8km/min. We have first images, but still not better than Hubble. Well, one more week and they should be better.
  • #36
From the exoplanets.EU database, only two exoplanets have well defined masses and radii, and are of earthlike size
Kepler-36 & 55 Cnc e
The former closely fits the apparent relation, the other is under dense like Ceres
Perhaps has a Venusian atmosphere maybe with oceans? Some articles online seem to say so
More data than 6 points to plot would be immensely preferable
  • #37
Kepler-93 b: density 7.2 +- 1.3, surface gravity 18.6 +- 3.2 (seems reasonable)
Kepler-138 d: density 1.4 +- 0.7, surface gravity 4.0 +- 1.7 (does not fit at all)
Note that while the individual values show large uncertainties, they are highly correlated as the original measurements are (uncorrelated) radius and mass and we consider M/r^2 and M/r^3. Kepler-138 d is clearly not on the line.
I had a look at all exoplanets in the database smaller than 2 times the radius of earth, where both mass and radius have an uncertainty given and where this uncertainty is not too large (typically below 10%). It is not surprising that more massive planets are more dense due to pressure, but there are also very light planets. Adding our observation bias (light planets rarely have a reliable mass estimate), my conclusion is "we cannot draw a conclusion".
Also note that all the gas giants would fit in this image - they are very light (~1-2 g/cm^3) and have a high surface gravity. They are completely away from any function that could be drawn through rocky planets.
  • #38
Manipulating the data from the exoplanets.eu database is very hard
MS Excel seems to treat error values of INF and NAN and zero as legitimate numbers
Never the less, about 350 exoplanets have well defined masses and radii ( fractional error < 0.12 )
If you scatter plot DENSITY on y vs. GRAVITY on x...
The exoplanets appear to fall on two separate lines...
The plot looks like /_
The flatter line seems to be gaseous planets like Jupiter, having DENSITY ~= 0.1 x GRAVITY utilizing Earth normalized units ( Earth = 1 )
Cp. Jupiter has a surface gravity of about
3, and a density of about 0.3
The more vertical steeper line seems to represent earthy planets, with bulk compositions more like Ceres, Earth, or Mercury
Perhaps basic general rules could help differentiate the two basic kinds of planets??
  • #39
Trying to upload figure
  • #40
Lines through the origin are lines of constant radius. The steeper the line the smaller the planet.
The dominant line corresponds to the radius of Jupiter, or the (nearly) universal size for very massive gas planets.
Likes TEFLing
  • #41
http://www.universetoday.com/25348/what-is-the-smallest-star/
That is a great observation...
R ~ 1 Jupiter ~ 10 Earth's
True all the way out to the ballpark vicinity of
(x,y) = (p,g) ~ (30,300)
Corresponding to the smallest Red Dwarf class stars also ( having approximately 30,000 Earth masses = 30 x 10^3 )
http://solstation.com/images/sol-m-j2.jpg
assuming HSE, and using a single zone
dP/dr = -pg​
Pcenter /R ~ paverage gsurface
P ~ p g R ~ g2
for earth
P ~ 400 GPa​
for a hyper Jupiter, near the transition from brown dwarf to red dwarf, central pressures might be about ~105x higher
the bulk modulus of rocky material is of order 100s GPa
so, for Earth and the other terrestrial planets in our solar system, even core material experiences pressures comparable to their bulk modulii
whereas core conditions in super and hyper Jupiters are exotic
if the least massive stars form the slowest...
then wouldn't they evolve towards the MS in quasi HSE?
so before their First Light of fusion ignition, they ought to resemble sub-stellar brown dwarf ultra Jupiters...
and so they ought to have a rocky metallic ultra Earth core, of say 10-15 Earth masses, or something like that
how would that affect fusion processes inside the protostars?? Would First Light occur in a liquid superfluid H / He shell around a massive rocky metallic core, or anything like that??
http://www.sciencedaily.com/releases/2015/01/150122145418.htm
  • #42
I want to try one more order of magnitude calculation, using the one zone approximation of the HSE equation
if we assume an adiabatic equation for pressure
P = K py
then the scaling relation becomes
P/R ~ p g​
P ~ p ( p R ) R​
P ~ p2
assuming roughly constant radius ( R ~ 1 RJupiter ). That is consistent with the adiabatic approximation, for an adiabatic index of y=2.
I think that would mean, gas in the interior would be hotter than if it was driven down from the surface and simply compressed by the ambient pressures...
i.e. Implies an internal source or reservoir of heat energy
such as fission in the super Earth core, or left over heat from planetary formation and differentiation
  • · Replies 1K ·
36
188K
  • · Replies 19 ·
  • · Replies 37 ·
