Dc 8t14 product to sum indentity
In summary, using the power to sum formula, we can simplify the expression $\frac{\sin(3\theta)+\sin(5\theta)}{\cos(3\theta)+\cos(5\theta)}$ to $\tan(4\theta)$. This is done by using the sum to product formulas for sine and cosine and simplifying to get the final answer.
karush
MHB
3,269
4Use the power to sum formula to simplify the expression
$\frac{\sin\left({3\theta}\right)+\sin\left({5\theta}\right)}
{\cos\left({3\theta}\right)+\cos\left({5\theta}\right)}$
The answer is $\tan(4\theta)$
$$\sin\left({3\theta}\right)+\sin\left({5\theta}\right)
=2\sin\left({\frac{3\theta+5\theta}{2}}\right)\cos\left({\frac{3\theta-5\theta}{2 }}\right)$$
$$\cos\left({3\theta}\right)+\cos\left({5\theta}\right)
=2\cos\left({\frac{3\theta+5\theta}{2}}\right)\cos\left({\frac{3\theta-5\theta}{2 }}\right)$$
Hopefully I'm going in the right direction... But couldn't get the answer earlier
Mathematics news on Phys.org
We are given:
\(\displaystyle \frac{\sin(3\theta)+\sin(5\theta)}{\cos(3\theta)+\cos(5\theta)}\)
We have the following two applicable sum to product formulas:
\(\displaystyle \sin(x)+\sin(y)=2\sin\left(\frac{x+y}{2}\right)\cos\left(\frac{x-y}{2}\right)\)
\(\displaystyle \cos(x)+\cos(y)=2\cos\left(\frac{x+y}{2}\right)\cos\left(\frac{x-y}{2}\right)\)
So, how can we use these to rewrite the given expression?
edit: I see you've now edited your post and have the correct identities. So, using what you've written, we would have:
\(\displaystyle \frac{\sin(3\theta)+\sin(5\theta)}{\cos(3\theta)+\cos(5\theta)}=\frac{2\sin\left(\frac{3\theta+5\theta}{2}\right)\cos\left(\frac{3\theta-5\theta}{2}\right)}{2\cos\left(\frac{3\theta+5\theta}{2}\right)\cos\left(\frac{3\theta-5\theta}{2}\right)}\)
Now, just simplify. :)
$$\frac{2\sin\left({4\theta}\right)\cos\left({-\theta}\right)}
{2\cos\left({4\theta}\right)\cos\left({-\theta}\right)}
=\frac{\sin\left({4\theta}\right)}{\cos\left({4\theta}\right)}=\tan\left({4\theta}\right)$$
Well, $3\theta-5\theta=-2\theta$ and the using the identity $\cos(-x)=\cos(x)$ you would have $\cos(2\theta)$ in the numerator and denominator, but I wouldn't even bother with that...I would write:
\(\displaystyle \frac{\sin(3\theta)+\sin(5\theta)}{\cos(3\theta)+\cos(5\theta)}=\frac{\cancel{2}\sin\left(\frac{3\theta+5\theta}{2}\right)\cancel{\cos\left(\frac{3\theta-5\theta}{2}\right)}}{\cancel{2}\cos\left(\frac{3\theta+5\theta}{2}\right)\cancel{\cos\left(\frac{3\theta-5\theta}{2}\right)}}\)
\(\displaystyle \frac{\sin(3\theta)+\sin(5\theta)}{\cos(3\theta)+\cos(5\theta)}=\frac{\sin\left(\frac{8\theta}{2}\right)}{\cos\left(\frac{8\theta}{2}\right)}\)
\(\displaystyle \frac{\sin(3\theta)+\sin(5\theta)}{\cos(3\theta)+\cos(5\theta)}=\frac{\sin\left(4\theta\right)}{\cos\left(4\theta\right)}=\tan(4\theta)\)
Well, that was helpful, didn't see that, Nice thing about MHB, learn shortcuts
How do you do the strike through? (Cool)​
You can use the \cancel command...there is also the \xcancel{} command which will x out a factor. Both of these can be found in our Qucik $\LaTeX$ element in the "Algebra" section.
FAQ: Dc 8t14 product to sum indentity
What is the "Dc 8t14 product to sum identity"?
The "Dc 8t14 product to sum identity" is a mathematical rule that states that the product of two numbers can be rewritten as the sum of those two numbers. This is also known as the distributive property.
How is the "Dc 8t14 product to sum identity" used in mathematics?
The "Dc 8t14 product to sum identity" is used in algebra and other areas of mathematics to simplify equations and expressions. It is particularly useful when dealing with polynomials and factoring them.
What are the benefits of using the "Dc 8t14 product to sum identity"?
Using the "Dc 8t14 product to sum identity" can help make complex equations and expressions easier to solve. It can also help identify patterns and relationships between numbers.
Are there any limitations to the "Dc 8t14 product to sum identity"?
The "Dc 8t14 product to sum identity" can only be used when multiplying two numbers. It cannot be applied to other operations such as division or addition.
How can the "Dc 8t14 product to sum identity" be applied in real-life situations?
The "Dc 8t14 product to sum identity" can be used in various real-life situations such as calculating the cost of items in bulk, finding the total number of items in a group, or determining the total area of a rectangle made up of smaller squares. It can also be used in engineering and physics to simplify equations and make calculations easier.
